  1. hey! i try to rip subtitles from the movie "The Pyramid" and unfortunately its dont want to rip to me...
    its the first time (and i rip a lot) that is doesnt work.. any way, i remove DRM, and i have unprotected m4v,
    here the Mediainfo:
    Pyramid.m4v
    Format : MPEG-4
    Codec ID : M4V
    File size : 1.41 GiB
    Duration : 1h 29mn
    Overall bit rate : 2 268 Kbps
    Movie name : The Pyramid
    Performer : Gregory Levasseur
    Performer/Sorted by : Gregory Levasseur
    Genre : Horror
    ContentType : Short Film
    Description : The age-old wonders of the world have long cursed explorers who've dared to unlock their mysteries.
    Recorded date : UTC 2014-12-05 08:00:00
    Encoded date : UTC 2015-02-28 10:19:56
    Tagged date : UTC 2015-02-28 10:20:10
    Copyright : © 2014 Twentieth Century Fox Film Corporation. All rights reserved.
    Cover : Yes
    Rating : None
    GenreID : 4408
    AppleStoreCountry : Unknown Country
    PurchaseDate : 2015-03-04 23:22:29
    Title/Sort : Pyramid
    Vendor : foxfilm:vendor_id:031606
    Flavour : 4:640x480LC-128
    ContentRating : ru-movie|16+|375|
    LongDescription : The age-old wonders of the world have long cursed explorers who've dared to unlock their mysteries. But a team of archaeologists get more than they bargained for when they discover a lost pyramid in the Egyptian desert. As they begin to uncover its horrifying secrets, they realize they’re being relentlessly hunted by an ancient evil more nightmarish than anything they could have imagined.
    iTunMOVI : <?xml version="1.0" encoding="UTF-8"?> / <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> / <plist version="1.0"> / <dict> / <key>asset-info</key> / <dict> / <key>closed-captioned</key> / <true/> / <key>file-size</key> / <integer>1519304257</integer> / <key>flavor</key> / <string>4:640x480LC-128</string> / <key>screen-format</key> / <string>widescreen</string> / <key>soundtrack</key> / <string>DD,DS</string> / </dict> / <key>cast</key> / <array> / <dict> / <key>adamId</key> / <integer>505098645</integer> / <key>name</key> / <string>Ashley Hinshaw</string> / </dict> / <dict> / <key>adamId</key> / <integer>57035802</integer> / <key>name</key> / <string>Denis O'Hare</string> / </dict> / <dict> / <key>adamId</key> / <integer>458068903</integer> / <key>name</key> / <string>James Buckley</string> / </dict> / </array> / <key>codirectors</key> / <array/> / <key>copy-warning</key> / <string>&amp;nbsp;</string> / <key>directors</key> / <array> / <dict> / <key>adamId</key> / <integer>253541365</integer> / <key>name</key> / <string>Gregory Levasseur</string> / </dict> / </array> / <key>producers</key> / <array/> / <key>screenwriters</key> / <array/> / <key>studio</key> / <string>20th Century Fox</string> / </dict> / </plist>
    Video #1
    Format : AVC
    Format profile : Baseline@L3.0
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Codec ID : avc1
    Duration : 1h 29mn
    Source duration : 1h 29mn
    Bit rate : 1 489 Kbps
    Width : 640 pixels
    Height : 362 pixels
    Display aspect ratio : 2.35:1
    Frame rate mode : Variable
    Frame rate : 23.976 fps
    Minimum frame rate : 23.976 fps
    Maximum frame rate : 25.836 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.268
    Stream size : 951 MiB (66%)
    Source stream size : 951 MiB (66%)
    Title : Core Media Video
    Language : English
    Color primaries : BT.601 NTSC
    Transfer characteristics : BT.709
    Matrix coefficients : BT.601
    Video #2
    Format : JPEG
    Codec ID : jpeg
    Duration : 1h 29mn
    Bit rate mode : Variable
    Bit rate : 6 872 bps
    Width : 640 pixels
    Height : 271 pixels
    Display aspect ratio : 1.85:1
    Frame rate : 0.005 fps
    Minimum frame rate : 0.003 fps
    Maximum frame rate : 0.011 fps
    Color space : YUV
    Chroma subsampling : 4:4:4
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 7.924
    Stream size : 4.59 MiB (0%)
    Audio #1
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1h 28mn
    Source duration : 1h 28mn
    Bit rate mode : Constant
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Stream size : 79.4 MiB (5%)
    Source stream size : 79.4 MiB (5%)
    Title : Core Media Audio
    Language : Russian
    Audio #2
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1h 28mn
    Bit rate : 128 Kbps
    Stream size : 79.5 MiB (5%)
    Source stream size : 79.5 MiB (5%)
    Language : English
    Audio #3
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : ac-3
    Duration : 1h 28mn
    Bit rate : 384 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 244 MiB (17%)
    Language : Russian
    Audio #4
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1h 28mn
    Bit rate : 128 Kbps
    Stream size : 79.9 MiB (6%)
    Source stream size : 79.9 MiB (6%)
    Language : Ukrainian
    Text #1
    Format : EIA-608
    Muxing mode : Final Cut
    Codec ID : c608
    Duration : 1h 28mn
    Stream size : 0.00 Byte (0%)
    Title : Core Media Closed Caption
    Language : English
    Text #2
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 2 bps
    Stream size : 1.02 KiB (0%)
    Title : Core Media Subtitle
    Language : Russian
    Text #3
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 132 bps
    Stream size : 86.0 KiB (0%)
    Language : Arabic
    Text #4
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 129 bps
    Stream size : 83.9 KiB (0%)
    Language : Bulgarian
    Text #5
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 98 bps
    Stream size : 64.0 KiB (0%)
    Language : Chinese
    Text #6
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 101 bps
    Stream size : 66.0 KiB (0%)
    Language : Chinese
    Text #7
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 98 bps
    Stream size : 63.7 KiB (0%)
    Language : Czech
    Text #8
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 87 bps
    Stream size : 56.8 KiB (0%)
    Language : Danish
    Text #9
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 100 bps
    Stream size : 65.2 KiB (0%)
    Language : German
    Text #10
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 123 bps
    Stream size : 80.0 KiB (0%)
    Language : Greek
    Text #11
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 23mn
    Bit rate : 109 bps
    Stream size : 66.7 KiB (0%)
    Language : English
    Text #12
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 98 bps
    Language : Spanish
    Text #13
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 99 bps
    Stream size : 64.7 KiB (0%)
    Language : Spanish
    Text #14
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 96 bps
    Stream size : 62.3 KiB (0%)
    Language : Estonian
    Text #15
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 83 bps
    Stream size : 54.0 KiB (0%)
    Language : Finnish
    Text #16
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 104 bps
    Stream size : 67.6 KiB (0%)
    Language : French
    Text #17
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 80 bps
    Stream size : 52.3 KiB (0%)
    Language : French
    Text #18
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 132 bps
    Stream size : 85.7 KiB (0%)
    Language : Hebrew
    Text #19
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 186 bps
    Stream size : 121 KiB (0%)
    Language : Hindi
    Text #20
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 97 bps
    Stream size : 62.8 KiB (0%)
    Language : Croatian
    Text #21
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 87 bps
    Stream size : 56.5 KiB (0%)
    Language : Hungarian
    Text #22
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 100 bps
    Stream size : 65.0 KiB (0%)
    Language : Icelandic
    Text #23
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 101 bps
    Language : Italian
    Text #24
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 106 bps
    Stream size : 68.7 KiB (0%)
    Language : Korean
    Text #25
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 95 bps
    Stream size : 62.1 KiB (0%)
    Language : Lithuanian
    Text #26
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 98 bps
    Language : Latvian
    Text #27
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 79 bps
    Stream size : 51.7 KiB (0%)
    Language : Dutch
    Text #28
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 99 bps
    Stream size : 64.1 KiB (0%)
    Language : Norwegian
    Text #29
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 77 bps
    Stream size : 50.4 KiB (0%)
    Language : Polish
    Text #30
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 103 bps
    Stream size : 67.0 KiB (0%)
    Language : Portuguese
    Text #31
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 106 bps
    Stream size : 68.9 KiB (0%)
    Text #32
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 99 bps
    Language : Romanian
    Text #33
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 136 bps
    Stream size : 88.8 KiB (0%)
    Language : Russian
    Text #34
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 91 bps
    Stream size : 59.3 KiB (0%)
    Language : Slovak
    Text #35
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 89 bps
    Stream size : 58.0 KiB (0%)
    Language : Slovenian
    Text #36
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 92 bps
    Stream size : 60.2 KiB (0%)
    Language : Serbian
    Text #37
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 98 bps
    Stream size : 63.9 KiB (0%)
    Language : Swedish
    Text #38
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 172 bps
    Stream size : 112 KiB (0%)
    Language : Thai
    Text #39
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 103 bps
    Stream size : 66.8 KiB (0%)
    Language : Turkish
    Text #40
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 138 bps
    Stream size : 89.8 KiB (0%)
    Text #41
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 123 bps
    Stream size : 80.2 KiB (0%)
    Language : Vietnamese
    Text #42
    Format : Timed Text
    Muxing mode : sbtl
    Codec ID : tx3g
    Duration : 1h 28mn
    Bit rate : 91 bps
    Stream size : 58.9 KiB (0%)
    Language : Chinese
    Menu
    Codec ID : tx3g
    Duration : 1h 29mn
    Title : Core Media Text
    Language : Russian
    Bit rate mode : VBR
    when i try put it in MyMp4box, to dumex some subtitle, that errro it is give me:
    any idea guys?????? please help me to extract!
  3. try it, doesnt work..
  4. PHP Code:
    mp4box.exe -ttxt 4 Pyramid.m4v -out "subtitle.ttxt"
    PHP Code:
    ffmpeg.exe -y -loglevel quiet -i Pyramid.m4v -f srt -map 0:4 -c:s srt "subtitles.srt"
  5. i dont know what to do man, you have maybe skype? and thx for help!
  6. Post a snippet of film {100MB}.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    Download mp4box and ffmpeg. THen can you run the commands directly from windows start>run but you must add the folder locations like:
    Put for example ffmpeg.exe and mp4box in c:\programs and your movies in c:\movies and run these from the start->run or from a command prompt.
    "c:\programs\mp4box.exe" -ttxt 4 "c:\movies\Pyramid.m4v" -out "c:\movies\subtitle.ttxt"
    "c:\programs\ffmpeg.exe" -y -loglevel quiet -i "c:\movies\Pyramid.m4v" -f srt -map 0:4 -c:s srt "c:\movies\subtitles.srt"
  8. Originally Posted by Baldrick View Post
    its say:
    [iso file] Read Box "xstt" failed (Out Of Memory)
    [iso file] Read Box "tx3g" failed (Out Of Memory)
    [iso file] Read Box "stsd" failed (Out Of Memory)
    [iso file] Read Box "stbl" failed (Out Of Memory)
    [iso file] Read Box "minf" failed (Out Of Memory)
    [iso file] Read Box "mdia" failed (Out Of Memory)
    [iso file] Read Box "trak" failed (Out Of Memory)
    [iso file] Read Box "moov" failed (Out Of Memory)
    whyy????
