hi
I recorded a video with a crapy cam
and i also recoded the voices and sound separately with a mic and recorder.
I did not succed in adding those voices to the vid .... can WMMaker to this??
Sure, not ideal but it can be done:
http://support.microsoft.com/kb/272955
(Also, there's no such thing as WMM lite.) -
the thing is that it not a music song that it want to add. Ialready did this.
hte thing i want to add is the voices i recorded separetely (just like the pro)
what i call windows movie maker lite is this :Files (x86)\Windows Live\Photo Gallery\MovieMaker.exe" -
There are ways you could do it, but it would be painful.
The next step up would be a low cost NLE (I like Vegas Movie Studio) Where you can sync up the clips and group or lock them together. Higher cost NLEs like Premiere pro, Avid or Vegas Pro make it a little easier and can work in conjunction with Plural Eyes to add some automation to the task.
Actually, PluralEyes has a free trial (and may or may not be able to deal with your footage.) It's not an editor, it's only for syncing. -
is there a free editing software that can do it
ANd if possible that as intuitive as windows movie maker lite
could anyone suggest me a freeware they liked that can do this?
thx -
I suspect free AviUtl can, though I don't use it.
Emphatically no.
If you demux your original source video and audio (with AviDemux or similar,) you may be able to import your video-only track and sync it to your good audio-only track in the WMM timeline. Hopefully you used slates or clapboards as a reference.Last edited by smrpix; 5th Mar 2015 at 14:00.
