Page 2 of 2
FirstFirst 1 2
Results 31 to 34 of 34
  1. Hey, thanks for the continued help! I'll have to take a little break on encoding the episodes because of real life suff... But I appreciate the help you have given me and will try those suggestions when I get back.
  2. Hey, back to start and finish this anime
    In the last few days I've played around with it and came up with the following results below taken in full screen:
    The script for the above image is:
    DGDecode_mpeg2source("I:\New folder (2)\001.d2v", info=3, cpu=6)
    LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\DGDecode.dll")
    LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\DeCross.dll")
    LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\TComb.dll")
    LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\TIVTC.dll")
    LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\RemoveGrain.dll")
    LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\vinverse.dll")
    LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\FFT3DFilter.dll")
    LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\masktools2.dll")
    Import("C:\Program Files (x86)\AviSynth\plugins\Vmtoon-v0.74.avsi")
    LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\warpsharp.dll")
    Import("C:\Program Files (x86)\AviSynth\plugins\LimitedSharpenFaster.avsi")
    DeCross(ThresholdY=30, Noise=110, Margin=1, Debug=false)
    TComb(mode=0, fthreshl=4, othreshl=5)
    TFM(PP=2)
    TDecimate(mode=1)
    RemoveGrain(mode=17)
    Vinverse(sstr=2.7, amnt=255, uv=3, scl=0.25)
    FFT3DFilter(sigma=3,bw=32,bh=32,ow=16,oh=16,plane=4)
    LimitedSharpenFaster()
    vmToon(strength=60)
    crop(4, 0, -6, 0)
    LanczosResize(640,480)
    However now as I've been watching a few episodes I don't want a washed out image and want to keep it as original to the DVD source, but am having trouble with it because I am not 100% sure what the things I want to remove are called so I am just guessing and chaging settings and using filters.
    Here is a DVD source picture taken in full screen:
    I basically want to remove the stuff circled and make the image a little sharper. In the first image at the top I still wasn't able to remove the green stains on the black lines and around the image, however I was able to remove the rainbow with the above setting on moving/still parts almost completely but the stain of green stayed on some parts don't know if it is rainbow aswell.
    I found this post it helped me a bit, but like I said I am unsure what the actual things are called what I want removed to get the correct filters.
    Here is a link to the full episode in a .m2v file.
    Thanks.
  3. You can sharpen the chroma with a sequence like:
    MergeChroma(aWarpSharp(depth=20))
    That will reduce the bleeding of colors into the black lines. The higher you set depth the more sharpening you get. If you go too high you'll lose color in corners and in small objects.
    V channel of one of your images before sharpening chroma:
    and after MergeChroma(aWarpSharp(depth=20)):
  4. Originally Posted by jagabo View Post
    [Attachment 31779 - Click to enlarge]
    [Attachment 31780 - Click to enlarge]
    thanks, i'll give it ago right now
    would you know any filters that can help me with the following:
    DGDecode_mpeg2source("I:\New folder (2)\003.d2v", info=3, cpu=6)
    TComb(mode=0, fthreshl=7, othreshl=8)
    TFM(PP=0)
    TDecimate(mode=1)
    RemoveGrain(mode=5)
    vmToon(strength=60, luma_cap=150, threshold=2, thinning=100, ssw=3,ssh=3)
    crop(4, 0, -6, 0)
    Also I was just wondering how do I go about setting the size/crop of the file to keep it to the original size of the source, below is a picture but am unsure how to write it.
