  1. The video I'm talking about is sourced from tape but transferred to 16mm film back in the 70s, as far as I know. http://youtu.be/AMG5evgisHw?t=55s
    What do you experts think is the best way to somehow remove or reduce those two vertical moving lines? Thanks.
    (I ripped the video and cut out a small sample with Avidemux, in case anyone wants to play with this. Check the attachment)
  2. Banned
    Oct 2014
    Northern California
    There is an AviSynth DeScratch() filter but I have gotten mixed results with it.
    You can do it in After Effects, also Boris CC has a filter to remove lines that works great.
    But because those vertical lines tend to move you have to key frame and it becomes very labor intensive to do a good job.
    http://www.borisfx.com/bcc/
    Be prepared to take a lot of time if you want to get this right!
  3. I tried DeScratch but it didn't give me desired results.
    I'll try that Boris CC filter, thanks for the advice!
