Problem: audio is out of sync by some 3-4 secs, pretty much a constant through the movie. I used dvd2svcd, which i've used with no probs before. I tried dup-dvd but the audio was still out of sync. With dvdx it came up with an error saying that sometimes at the beginning of movies or the end that the audio was fuxored. Anyways it didn't have any audio.
So I've got all the files made by dvd2svcd, I should be able to rejoin/mux the audio and video...........right. Just have to figure out how to do this and compensate for that synch difference.
Please detail the steps needed. I've had no luck doing svcds manually, so.........;)
thx
I was converting a divx movie to svcd and the audio was in AC3 so i had to encode it seperately. I ran into the same type of problem. Audio was out of sync. This was mainly because I encoded audio and video seperately. (I also discovered that TMPGEnc does poor audio encoding.)
Anyways... If you have the audio and video seperated, use besweet to re-encode the audio and to set a delay on the audio as well. I just kept re-encoding the audio and re-muxing the files together to see if i came closer to a result. Then I would study certain things like people clapping or doors shutting for synchronization.
Let me know if this helps.Mike of DHI Music Group
darklink.org -
thx xeromark for that suggestion. Umm........ besweet seems to be a line command app. Could you please give me an example of doing this especially on how to implement the delay.
thx -
if you check out doom9, they have a GUI for besweet.
darklink.org
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
