i have two movies which are 1200 big
but i cant seem to cut them in half
i made them using gordian knot and have tried avi chop
which does seperate them but the file are damaged and wont play
and i have tried virtualdub
which cuts the video fine but loses the audio near the start
also i have tried avi edit and that dos'nt work
help me please
Well im not an expert i done my first rip the other day so i may b wrong.
U could use a converter and convert it to mpeg and make it a lower bit rate and audio rate so it would b smaller.
Or u could encode it again, i used DVDx, then select a smaller bit rate, and less quality, worse sound etc. That would make it smaller, but ud have to re-encode it.
Problems w/ SRT subs cutting out half way through film...
By dark_lord in forum Newbie / General discussionsReplies: 2Last Post: 11th Mar 2012, 11:00 -
ripbot only converts half the movie
By AmDD in forum DVD RippingReplies: 8Last Post: 11th Feb 2012, 06:50 -
remove subtitles from half SBS movie
By sportflyer in forum SubtitleReplies: 2Last Post: 1st Jan 2012, 22:27 -
problem with cutting AVI in half with VirtualDub.
By eroy in forum EditingReplies: 1Last Post: 27th Dec 2007, 06:53 -
MPLEX.exe only creates HALF the movie.
By supermannnnn in forum Video ConversionReplies: 5Last Post: 19th Aug 2007, 22:45
