Results 1 to 23 of 23
  1. Hi cats
    please inside a batch I need to change
    for example
    c:\cats\vid.avi into c : \ c a t s \ v i d . a v i
    or
    filenameandpath into f i l e n a m e a n d p a t h
    and load it on a envoriment variable, how can I do? thanks
  2. Code:
    #include <stdio.h>
    main(int argc, char**argv)
    	int i=0;
    	if (argc <= 1)
    		exit(1);
    	while(argv[1][i] != 0)
    		printf("%c ", argv[1][i++]);
    	exit(0);
    That includes a space at the end.
  3. thanks jagabo
    for example I have a batch that at a certain point I have
    echo %cd%
    where %cd% is a path: for example c:\cats
    with your script where I have to put %cd% so that I can get another string c : \ c a t s ?
  4. Groucho2004
    Guest
    Originally Posted by marcorocchini View Post
    Hi cats
    for example
    or
    It might help if you tell us why you want to do this conversion.
  5. Member Cornucopia's Avatar
    Trust me, it won't help...
  6. It's not for me, a cat tell me how he can do. He have to batch automate using Elecard Converter Studio that save the batch list in a .csb file
    the batch script have to insert a filename and path but it have spaces (it's like "unicode"?)
    I have do the same thing for Mainconcept totalcode, but it don't need spaces in path
    @rem unless otherwise specified for debugging reasons turn echo off
    @if "%EMode%"=="" Set EMode=ON
    @ECHO %EMode%
    @ECHO off
    xcopy /y v:\automazioneclip\system\morgan\m3jpegHD.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\morgan\MMIJG32.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\morgan\m3jpegSD.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\x264VFW.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\pvmjpg40.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\morgan\MMIJG30.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\morgan\m3jpSD.INI c:\windows
    xcopy /y v:\automazioneclip\system\morgan\m3jpHD.ini c:\windows
    if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\m3jpegHD.dll c:\windows\SysWOW64
    if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\MMIJG32.dll c:\windows\SysWOW64
    if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\m3jpegSD.dll c:\windows\SysWOW64
    if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\MMIJG30.dll c:\windows\SysWOW64
    if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\x264VFW.dll c:\windows\SysWOW64
    if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\pvmjpg40.dll c:\windows\SysWOW64
    md c:\windows\spvideo
    xcopy /y v:\automazioneclip\system\wavdest.ocx c:\windows\spvideo
    xcopy /y v:\automazioneclip\system\SamplesDropper.ocx c:\windows\spvideo
    xcopy /y v:\automazioneclip\system\SP_audio.ocx c:\windows\spvideo
    xcopy /y v:\automazioneclip\system\dv_grabber.ocx c:\windows\spvideo
    xcopy /y v:\automazioneclip\system\SP_video.ocx c:\windows\spvideo
    regsvr32 /s c:\windows\spvideo\wavdest.ocx
    regsvr32 /s c:\windows\spvideo\SamplesDropper.ocx
    regsvr32 /s c:\windows\spvideo\SP_audio.ocx
    regsvr32 /s c:\windows\spvideo\dv_grabber.ocx
    regsvr32 /s c:\windows\spvideo\SP_video.ocx
    regedit /s v:\automazioneclip\system\VDreg.reg
    regedit /s v:\automazioneclip\system\PICreg.reg
    regedit /s v:\automazioneclip\system\drivers.reg
    cls
    SetLocal DisableDelayedExpansion
    Set "EXTLIST=*.*"
    Set "DoPop=0"
    Set "ARGLVL=0"
    Set "FileName-DQ="
    Set Totalcode_Loc="C:\Program Files\Mainconcept\TotalCode Studio\tcstudio.exe"
    set "DestFolder=."
    Set "WorkFolder=%DestFolder%"
    rem process the arguments one by one
    :ARGS
    	rem if there are no further arguments then exit the batch.
    	if [%1]==[] (
    		if "%ARGLVL%"=="0" (
    			CALL :GetTargetName
    			EndLocal
    			pause
    		goto :eof
    	rem wildcard processing
    	Set "FileName=%~1"
    	if "%FileName%"=="" (
    		SHIFT
    		goto :ARGS
    	rem if the argument doesn't exist in the file system in any form skip it.
    	if NOT EXIST %1 (
    		SHIFT
    		goto :ARGS
    	if NOT [%1]==[] if NOT "%FileName:^*=%%FileName:^?=%"=="%FileName%%FileName%" (
    		for %%w in (%1) DO (
    			Set /a ARGLVL+=1
    			CALL :ARGS "%%~fw"
    			Set /a ARGLVL-=1
    		SHIFT
    		goto :ARGS
    	Set "FileName="
    	rem Set search/recursion variables
    	Set "Pattern=%EXTLIST%"
    	Set "STARTLVL=0"
    	Set "FOUNDLVL=1024"
    	rem if the argument is the current directory then process everything in it.
    	if "%~f1"=="%CD%" (
    		rem echo Processing Directory "%CD%"
    		CALL :START %1
    		SHIFT
    		goto :ARGS
    	rem Test if the argument is a directory, if it is move to it then process everything in it, if not then move to the file's parent directory and process the file.  Then return to starting directory.
    	Type NUL
    	pushd "%~f1" 2> nul
    	if NOT "%errorlevel%"=="0" (
    		if NOT "%CD%\"=="%~dp1" (
    			pushd "%~dp1"
    			Set "DoPop=1"
    		Set Pattern="%~nx1"
    	) else (
    		rem echo Processing Directory "%~f1"
    		Set "DoPop=1"
    	CALL :START %1
    	if "%DoPop%"=="1" (
    		popd
    		Set "DoPop=0"
    	SHIFT
    goto :ARGS
    :START <CURRENT_ARG>
    	rem Count is superseded by FOUNDLVL but may still be useful for renaming purposes
    	Set "Count=0"
    	rem Process all files in the current directory fitting the arguments search pattern.
    	for /f "delims=" %%y in ('dir %Pattern% /b /od /a-d') do (
    		if /I NOT "%%~y"=="File Not Found" CALL :Process_File "%%~fy"
    	rem if it didn't find anything search all directories instead
    goto :eof
    	if "%Count%"=="0" if %STARTLVL% LSS %FOUNDLVL% (
    		for /d %%b in (*) do (
    			pushd "%%~fb"
    			rem echo Processing Directory "%%~fb"
    			Set /a STARTLVL+=1
    			CALL :START "%%~fb"
    			Set /a STARTLVL-=1
    			popd
    goto :eof
    :Process_File <FILENAME>
    	Set /a Count+=1
    	Set "FOUNDLVL=%STARTLVL%"
            if exist "%~dpn1.wav" (
            set "Audio=%~dpn1.wav"
            ) else (
            set "Audio=v:\automazioneclip\system\empty.wav")
            rem Find TimeCode Info
         	Set AUCount=0;
    	for /f "tokens=1,2 delims=^=" %%g in ('v:\automazioneclip\virtualdub\FFProbe -hide_banner -loglevel fatal -pretty -select_streams v:0 -show_streams -show_entries stream^=codec_type^,r_frame_rate^,width^,height^,sample_aspect_ratio:stream_disposition^=:format_tags^=timecode^,company_name^,product_name^,product_version "%~1" 2^>^&1') DO (
    		 if "%%~g"=="TAG:company_name" set "T_Company_Name=%%~h"
    		 if "%%~g"=="TAG:product_name" set "T_Product_Name=%%~h"
    		 if "%%~g"=="TAG:product_version" set "T_Product_Version=%%~h"
    		 if "%%~g"=="TAG:timecode" set "TIMECODE=%%~h"
                     if "%%~g"=="r_frame_rate" set "Frame_Rate=%%~h"
    		 if "%%~g"=="width" set "V_Width=%%~h"
    		 if "%%~g"=="height" set "V_Height=%%~h"
                     if "%%~g"=="sample_aspect_ratio" set "V_PAR=%%~h"
    		 if "%%~g"=="codec_type" if "%%~h"=="audio" set /a AUCount+=1
    	if "%V_Width%"=="" (
    		echo  ERROR: Video Width NOT FOUND!
    		pause
    		goto :eof
    	if "%V_Height%"=="" (
    		echo  ERROR: Video Height NOT FOUND!
    		pause
    		goto :eof
           	if "%V_PAR%"=="" (
    		echo  ERROR: Video PAR NOT FOUND!
    		pause
    		goto :eof
    	if NOT EXIST %Totalcode_Loc% (
    		echo  Um, where the hell is Mainconcept Totalcode?
    		pause
    	rem Set "V_Q=UD"
    	rem if %V_Width% LEQ 1920 if %V_Height% LEQ 1120 \\
    	Set "V_Q=HD"
    	rem if %V_Width% LEQ 1280 if %V_Height% LEQ 752 Set "V_Q=MD"
    	if %V_Width% LEQ 1024 if %V_Height% LEQ 608 Set "V_Q=SD"
    	echo  Using %V_Q% Mode
    	echo  PAR = %V_PAR%
            if "%TimeCode%"=="" echo Warning! no TimeCode Found!
    	if NOT "%TimeCode%"=="" echo Timecode= %TIMECODE%
    if NOT "%TimeCode%"==""  (
     SET /a total_frames_tc=((1%timecode:~0,2%-100^) * 90000^) + ((1%timecode:~3,2%-100^) * 1500^) + ((1%timecode:~6,2%-100^) * 25^) + (1%timecode:~-2%-100^)
    ) ELSE (SET "result=NOT defined")
    ECHO result with timecode="%timecode%" is %total_frames_tc%)
            if "%TimeCode%"=="" Set "total_frames_tc=0"
            rem *** splitter ***
            v:\automazioneclip\virtualdub\mediainfo.exe "%~1" dumpinfo:unicodefile.txt
            TYPE unicodefile.txt>mediainfo.txt
            set "MJPEGtag=0"
            findstr /c:"Codec ID                                 : MJPG" "mediainfo.txt"
            IF NOT ERRORLEVEL 1 (set "MJPEGtag=1")
            findstr /c:"Codec ID                                 : YUY2" "mediainfo.txt"
            IF NOT ERRORLEVEL 1 (set "UNCOMPRESSED=1")
            Set "TokenS=0"
            Set "isMXF=0"
            IF "%~x1"==".MXF" Set "TokenS=1"
            IF "%~x1"==".mxf" Set "TokenS=1"
            If "%TokenS%"=="1" Set "isMXF=1"
            Set "TokenS=0"
            Set "isAVI=0"
            IF "%~x1"==".AVI" Set "TokenS=1"
            IF "%~x1"==".avi" Set "TokenS=1"
            If "%TokenS%"=="1" Set "isAVI=1"
            Set "TokenS=0"
            echo %~f1>realINPUTfilename.txt
            if "%ISavi%"=="1" echo %Audio%>realAudioINPUTfilename.txt
            echo %~dp1%~n1TotalcodeHDout.mxf>realOUTPUTfilename.txt
            v:\automazioneclip\system\gsar.exe -s\ -r/ "%~dp1/realINPUTfilename.txt" -f "%~dp1/newinputfilename.txt"
            v:\automazioneclip\system\gsar.exe -s\ -r/ "%~dp1/realOUTPUTfilename.txt" -f "%~dp1/newOUTPUTfilename.txt"
            if "%ISavi%"=="1" (v:\automazioneclip\system\gsar.exe -s\ -r/ "%~dp1/realAudioINPUTfilename.txt" -f "%~dp1/newAudioInputfilename.txt")
            set /p INPUTfilenamefortotalcode=<newINPUTfilename.txt
            set /p OUTPUTfilenamefortotalcode=<newOUTPUTfilename.txt
            set /p AudioInputFilenameForTotalcode=<newAudioInputfilename.txt
            echo new INPUT filename for totalcode is %INPUTfilenamefortotalcode%
            echo new OUTPUT filename for totalcode is %OUTPUTfilenamefortotalcode%
            echo new OUTPUT filename for totalcode is %AudioInputFilenameForTotalcode%
            rem *** check if file is a MP4-CONFI
            Set "TokenS=0"
            Set "SD_MP4_CONFI=0"
            Set "HD_MP4_CONFI=0"
            Set "isMP4CONFI=0"
            IF "%~x1"==".MP4" Set "TokenS=1"
            IF "%~x1"==".mp4" Set "TokenS=1"
            If "%TokenS%"=="1" Set "isMP4=1"
            findstr /c:"Width                                    : 720 pixels" "mediainfo.txt"
            IF NOT ERRORLEVEL 1 (set "WidthSD_MP4confi=1")
            findstr /c:"Height                                   : 576 pixels" "mediainfo.txt"
            IF NOT ERRORLEVEL 1 (set "HeightSD_MP4confi=1")
            findstr /c:"Scan type                                : MBAFF" "mediainfo.txt"
            IF NOT ERRORLEVEL 1 (set "MBAAF=1")
            findstr /c:"Frame rate                               : 25.000 fps" "mediainfo.txt"
            IF NOT ERRORLEVEL 1 (set "mp4FPS25_confi=1")
            findstr /c:"Width                                    : 1 920 pixels" "mediainfo.txt"
            IF NOT ERRORLEVEL 1 (set "WidthHD_MP4confi=1")
            findstr /c:"Height                                   : 1 080 pixels" "mediainfo.txt"
            IF NOT ERRORLEVEL 1 (set "HeightHD_MP4confi=1")
            IF "%isMP4%"=="1" IF "%WidthSD_MP4confi%"=="1" IF "%HeightSD_MP4confi%"=="1" IF "%MBAAF%"=="1" IF "%mp4FPS25_confi%"=="1" (set "SD_MP4_CONFI=1")
            IF "%isMP4%"=="1" IF "%WidthHD_MP4confi%"=="1" IF "%HeightHD_MP4confi%"=="1" IF "%MBAAF%"=="1" IF "%mp4FPS25_confi%"=="1" (set "HD_MP4_CONFI=1")
            Set "TokenS=0"
            IF "%SD_MP4_CONFI%"=="1" Set "TokenS=1"
            IF "%HD_MP4_CONFI%"=="1" Set "TokenS=1"
            IF "%TokenS%"=="1" set "isMP4CONFI=1"
            Set "TokenS=0"
            rem *** check if file is a GOPRO MP4 fullHD 50fps progressive
            Set "TokenS=0"
            Set "isMP4GOPRO=0"
            findstr /c:"Title                                    : GoPro AVC" "mediainfo.txt"
            IF NOT ERRORLEVEL 1 (set "GoPROAVC=1")
            if "%ismp4%"=="1" if "%Goproavc%"=="1" (set "MP4gopro=1")
            findstr /c:"Frame rate                               : 50.000 fps" "mediainfo.txt"
            IF NOT ERRORLEVEL 1 (set "gopro50fps=yes")
            findstr /c:"Scan type                                : Progressive" "mediainfo.txt"
            IF NOT ERRORLEVEL 1 (set "goproProgressive=yes")
            IF NOT ERRORLEVEL 1 (set "gopro1920=1")
            IF NOT ERRORLEVEL 1 (set "gopro1080=1")
            IF "%MP4gopro%"=="1" IF "%gopro1920%"=="1" IF "%gopro1080%"=="1" if "%gopro50fps%"=="yes" if "%goproProgressive%"=="yes" (set "MP4goproFullHD50fpsProgressive=1")
            rem *** check if file is a GOPRO MP4 FullHD 25fps progressive
            Set "TokenS=0"
            Set "isMP4GOPRO=0"
            IF NOT ERRORLEVEL 1 (set "gopro25fps=yes")
            IF "%MP4gopro%"=="1" IF "%gopro1920%"=="1" IF "%gopro1080%"=="1" if "%gopro25fps%"=="yes" if "%goproProgressive%"=="yes" (set "MP4goproFullHD25fpsProgressive=1")
            Set "TokenS=0"
            Set "isMXF_OR_GOPROfullHD25_50fps_ORmp4Confi=0"
            IF "%MP4goproFullHD25fpsProgressive%"=="1" set "TokenS=1"
            IF "%MP4goproFullHD50fpsProgressive%"=="1" set "TokenS=1"
            IF "%isMP4CONFI%"=="1" set "TokenS=1"
            IF "%isMXF%"=="1" set "TokenS=1"
            IF "%TokenS%"=="1" set "isMXF_OR_GOPROfullHD25_50fps_ORmp4Confi=1"
            IF "%isMXF_OR_GOPROfullHD25_50fps_ORmp4Confi%"=="1" (CALL :Make_File_STANDARD "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1")
            if "%ISavi%"=="1" (IF NOT "%MJPEGtag%"=="1" if not "%UNCOMPRESSED%"=="1" (CALL :Make_File_GENERIC "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1"))
            if "%ISavi%"=="1" if "%MJPEGtag%"=="1" (CALL :Make_File_fromAviMjpeg "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1")
            if "%ISavi%"=="1" if "%UNCOMPRESSED%"=="1" (CALL :Make_File_fromAviUNCOMPRESSED "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1")
            if not "%ISavi%"=="1" if not "%UNCOMPRESSED%"=="1" if not "%isMXF_OR_GOPROfullHD25_50fps_ORmp4Confi%"=="1" (CALL :Make_File_GENERIC "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1")
            if exist "%~dp1mediainfo.txt" del "%~dp1mediainfo.txt"
            if exist "%~dp1unicodefile.txt" del "%~dp1unicodefile.txt"
    echo  FATTO
    	echo.
    	echo ---------------------------------------------
    	echo.
    	EndLocal
    goto :eof
    :Make_File_STANDARD <txt_FILENAME> <txt_FILENAME> <FILENAME> <ORG_FILENAME>
    cls
    echo use STANDARD_____________MXF MP4confidenziali GOpro fullHD25/50fps_____________
    timeout /t 6
            copy /y "v:\automazioneclip\core\HD.mpj" "%~dp1%~n1.mpj"
            v:\automazioneclip\system\fart.exe "%~dp1%~n1.mpj" W:/inputdirectory/inputfilename.MXF "%INPUTfilenamefortotalcode%"
            v:\automazioneclip\system\fart.exe "%~dp1%~n1.mpj" V:/uscitaTotalcode/fileoutputtedfromtotalcode.mxf "%OUTPUTfilenamefortotalcode%"
            v:\automazioneclip\system\fart.exe "%~dp1%~n1.mpj" thisisthetcstringtoinsertinthebatch "%total_frames_tc%"
            del realINPUTfilename.txt
            del realOUTPUTfilename.txt
            del newinputfilename.txt
            del newOUTPUTfilename.txt
            if exist "%~dp1tempbatchprocess" del /q "%~dp1tempbatchprocess"
            %Totalcode_Loc% "%~dp1%~n1.mpj" -transcode -quit
            del "%~dp1%~n1.mpj"
    set "name=admin"
    set "password=pdw-f800"
    set "server=192.168.0.18"
    ping %server% |find /i "TTL=" >nul || (echo camera offline, aborting&goto :EOF)
    set "ftpScript=%~dp1%~n1.ftp.tmp"
        echo open %server%
        echo %name%
        echo %password%
        echo cd clip
        echo dir
        echo quit
    ) > "%ftpScript%"
    for /f "tokens=8*" %%A in ('ftp -s:"%ftpScript%" ^| findstr /i /e ".mxf"') do @echo %%B >> "%~dp1%~n1.txt"
    del "%ftpScript%"
    md "%~dp1tempbatchprocess"
    ren "%~dp1%~n1.txt" CamFiles.txt
    for /f "tokens=* delims= " %%a in (CamFiles.txt) do type nul >"%~dp1tempbatchprocess\%%~na.cam"
    rem for /F "tokens=1 delims= " %%f in (%~dp1%~n1.txt) do (copy nul c:\folderD\%%f /y > nul & @echo Creating File %%f )
    echo "%~dp1%~n1"
    echo "%~dp1"
    for /L %%a in (700,1,999) do (
       if not exist "%~dp1tempbatchprocess\C0%%a.cam" if not exist "%~dp1C0%%a.mxf" (ren "%~dp1%~n1TotalcodeHDout.mxf" "C0%%a.mxf"
    if exist "%~dp1C0%%a.mxf" set "FilenameForCameraOnline=%~dp1C0%%a.mxf">"%~n1"_rinominato_in_"C0%%a_MXF".log)
    cls
    set "putToCam=putToCam.ftp"
        echo user admin pdw-f800
        echo cd /clip
        echo put "%FilenameForCameraOnline%"
        echo bye
    ) > "%putToCam%"
    ren %putToCam% OutPutToCam.ftp
    ftp -d -n -i -s:OutPutToCam.ftp %server%
           if exist "%putToCam%" del "%putToCam%"
           del CamFiles.txt
           del OutPutToCam.ftp
           if exist "%~dp1tempbatchprocess" RD /S /q "%~dp1tempbatchprocess"
           goto :eof
    :Make_File_GENERIC <txt_FILENAME> <txt_FILENAME> <FILENAME> <ORG_FILENAME>
    cls
    echo procedura GENERIC GENERIC GENERIC GENERIC GENERIC GENERIC GENERIC GENERIC GENERIC GENERIC  Make_File_GENERIC (including mpeg-in-avi) using avisynt and ffvideosource as InputDriver
    timeout /t 5
            Set "genericProgressive=0"
            Set "genericInterlaced=0"
            Set "genericFPS25=0"
            Set "goproFile=0"
            Set "Morgan1088=0"
            Set "MBAAF=0"
            v:\automazioneclip\virtualdub\mediainfo.exe %4 dumpinfo:unicodefile.txt
            IF NOT ERRORLEVEL 1 (set "genericProgressive=1")
            findstr /c:"Scan type                                : Interlaced" "mediainfo.txt"
            IF NOT ERRORLEVEL 1 (set "genericInterlaced=1")
            IF NOT ERRORLEVEL 1 (set "genericFPS25=1")
            IF NOT ERRORLEVEL 1 (set "goproFile=1")
            findstr /c:"Original height                          : 1 088 pixels" "mediainfo.txt"
            IF NOT ERRORLEVEL 1 (set "Morgan1088=1")
            rem *** TRY extract audio from *.* OTHER TYPE ***
            v:\automazioneclip\core\ffmpeg.exe  -y -i %4 -af "pan=stereo:c0=c0:c1=c1,volume=1" -c:a pcm_s16le "%~dp1%~n1_gen_SD.wav"
            for %%v in ("%~dp1%~n1_gen_SD.wav") do (
    		if %%~zv LSS 128 (
    			echo  ERROR!!!  Extra Small File Wav Size Detected!!!
    			timeout /t 5
                            del "%~dp1%~n1_gen_SD.wav"
            if exist "%~dp1%~n1_gen_SD.wav" (
            set "AudioGeneric=%~dp1%~n1_gen_SD.wav"
            ) else (
            set "AudioGeneric=v:\automazioneclip\system\empty.wav")
            echo %AudioGeneric%>realAudioGenericINPUTfilename.txt
            v:\automazioneclip\system\gsar.exe -s\ -r/ "%~dp1/realAudioGenericINPUTfilename.txt" -f "%~dp1/newAudioGenericInputfilename.txt"
            set /p AudioGenericInputFilenameForTotalcode=<newAudioGenericInputfilename.txt
            rem *** building .AVS file ***
            echo Import("C:\Program Files\AviSynth\plugins\IResize.avsi")>%2
            echo FFVideoSource^(%4^)>>%2
            IF "%genericProgressive%"=="1" (echo ConvertToYUY2^(interlaced=false^)>>%2) else (echo ConvertToYUY2^(interlaced=true^)>>%2)
            IF "%Morgan1088%"=="1" echo crop^(0,0,1920,1080^)>>%2
            if "%dvcam%"=="1" echo ReverseFieldDominance^(^)>>%2
            echo src = last >>%2
            echo src = src.width==720^&^&src.height==608?src.crop^(0,32,0,0^):src >>%2
            echo src = src.width^<721 ^|^| src.height^<609?src.ColorMatrix^(mode="Rec.601->Rec.709"^): src >>%2
            Set "TokenS=0"
            IF "%goproFile%"=="1" set "TokenS=1"
            IF "%MBAAF%"=="1" set "TokenS=1"
            IF "%TokenS%"=="1" set "goproFileORmbaaf=1"
            IF "%goproFileORmbaaf%"=="1" (echo src.width!=1920 ^|^| src.height!=1080 ? src.IResize^(1920,1080^): src >>%2 ) else (echo src.width!=1920 ^|^| src.height!=1080 ? src.LanczosResize^(1920,1080^): src >>%2 )
            IF NOT "%genericFPS25%"=="1" echo SmoothFPS2^(50000,1000^)>>%2
            IF NOT "%genericFPS25%"=="1" echo AssumeTFF^(^).SeparateFields^(^).SelectEvery^(4,0,3^).Weave^(^) >>%2
            echo AssumeFPS^(25^)>>%2
            type "%2">"avstemp.avs"
            copy /y "v:\automazioneclip\core\daAVIgenericProgressiveVersusHD.mpj" "%~dp1%~n1.mpj"
            v:\automazioneclip\system\fart.exe "%~dp1%~n1.mpj" inputvideopartstring "%~dp1%avstemp.avs"
            v:\automazioneclip\system\fart.exe "%~dp1%~n1.mpj" inputaudiopartstring "%AudioGenericInputFilenameForTotalcode%"
            v:\automazioneclip\system\fart.exe "%~dp1%~n1.mpj" W:/casadei/MXForg/PRIME/C0049videopart_out.mxf "%OUTPUTfilenamefortotalcode%"
            del realAudioINPUTfilename.txt
            del newAudioInputfilename.txt
            del realAudioGenericINPUTfilename.txt
            del newAudioGenericInputfilename.txt
            if exist "%~dp1%~n1_gen_SD.wav" del "%~dp1%~n1_gen_SD.wav"
            del "%~dp1%~n1.mpj"
            del "avstemp.avs"
            del "%~dp1%~n1.avs"
            del *.ffindex
    set "name=admin"
        echo open %server%
        echo %name%
        echo %password%
        echo cd clip
        echo dir
        echo quit
    ) > "%ftpScript%"
    del "%ftpScript%"
    echo "%~dp1%~n1"
    echo "%~dp1"
    cls
        echo cd /clip
        echo bye
    ) > "%putToCam%"
           del CamFiles.txt
           del OutPutToCam.ftp
           goto :eof
    :Make_File_fromAviMjpeg <txt_FILENAME> <txt_FILENAME> <FILENAME> <ORG_FILENAME>
    cls
    echo procedura Make_File_fromAviMjpeg
            echo ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
            echo ³      AVI MJPEG INPUT PROCEDURE       ³
            echo ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
            echo.
    timeout /t 3
            Set "Morgan1088=0"
            echo AviSource^(%4^)>>%2
            echo AssumeTFF^(^)>>%2
            copy /y "v:\automazioneclip\core\daAVImjpegversusHD.mpj" "%~dp1%~n1.mpj"
            v:\automazioneclip\system\fart.exe "%~dp1%~n1.mpj" W:/casadei/MXForg/PRIME/C0049videopart.avi "%~dp1%avstemp.avs"
            v:\automazioneclip\system\fart.exe "%~dp1%~n1.mpj" W:/casadei/MXForg/PRIME/C0049audiopart.wav "%AudioInputFilenameForTotalcode%"
            del "%~dp1%~n1.mpj"
            del "avstemp.avs"
            del "%~dp1%~n1.avs"
    set "name=admin"
        echo open %server%
        echo %name%
        echo %password%
        echo cd clip
        echo dir
        echo quit
    ) > "%ftpScript%"
    del "%ftpScript%"
    echo "%~dp1%~n1"
    echo "%~dp1"
    cls
        echo cd /clip
        echo bye
    ) > "%putToCam%"
           del CamFiles.txt
           del OutPutToCam.ftp
           goto :eof
    :Make_File_fromAviUNCOMPRESSED <txt_FILENAME> <txt_FILENAME> <FILENAME> <ORG_FILENAME>
    cls
    echo procedura Make_File_fromAviUNCOMPRESSED
            echo ³   AVI UNCOMPRESSED INPUT PROCEDURE   ³
            echo.
    timeout /t 3
            Set "Morgan1088=0"
            echo DirectShowSource^(%4^)>>%2
            del "%~dp1%~n1.mpj"
            del "avstemp.avs"
            del "%~dp1%~n1.avs"
    set "name=admin"
        echo open %server%
        echo %name%
        echo %password%
        echo cd clip
        echo dir
        echo quit
    ) > "%ftpScript%"
    del "%ftpScript%"
    echo "%~dp1%~n1"
    echo "%~dp1"
    cls
        echo cd /clip
        echo bye
    ) > "%putToCam%"
           del CamFiles.txt
           del OutPutToCam.ftp
           goto :eof
    :GetTargetName
    	Set "FileName="
    	Set /p FileName=InputFileName:
    	rem Add or remove double-quotes if necessary
    	if NOT DEFINED FileName (
    		Set "FileName-DQ="
    		CALL :ExitPrompt
    		goto :DQSkip
    	Set "FileName-DQ=%FileName:"=%"
    	if NOT DEFINED FileName-DQ (
    		Set "FileName="
    		Set "FileName-DQ="
    		CALL :ExitPrompt
    		goto :DQSkip
    	if EXIST "%FileName-DQ%" (
    		if "%FileName-DQ%"=="%FileName-DQ: =%" (
    			Set "FileName=%FileName-DQ%"
    		) else (
    			Set FileName="%FileName-DQ%"
    :DQSkip
    	if /I "%FileName-DQ%"=="CD" Set FileName="%CD%"
    	if /I "%FileName-DQ%"=="EXIT" goto :eof
    	if /I "%FileName-DQ%"=="NOEXIT" goto :GetTargetName
    	if DEFINED FileName (
    		Set /a ARGLVL+=1
    		CALL :ARGS %FileName%
    		Set /a ARGLVL-=1
    goto :GetTargetName
    :ExitPrompt
    goto :eof
  7. Groucho2004
    Guest
    Ibut it have spaces (it's like "unicode"?)
    It's not "like" Unicode, it is Unicode. The file in the screen shot is a UTF-16 encoded XML. The "spaces" you see are not spaces but filler bytes with the value 0. You have to convert your path names properly from ASCII/ANSI to UTF-16.
  8. Originally Posted by marcorocchini View Post
    It's an ANSI C program. You have to compile and link it. At runtime in converts the first argument on the command line and outputs to stdout -- the console.
    If Groucho2004 is right you need to convert ASCII to UNICODE (not add spaces):
    http://www.robvanderwoude.com/type.php
  9. I think is enough add a space between every character
    example: HELLO --> H E L L O
  10. Originally Posted by marcorocchini View Post
    It's easy enough for you to test. Just hard code one filename with spaces and see if it works.
  11. Banned
    Freedonia
    Second this.
    The OP loves cats. He really really really loves cats. He REALLY REALLY REALLY REALLY loves cats. For all I know he may be a felinophile. I was going to point out that putting spaces in names is really stupid if the files will ever be on a non-Windows system, but you know what? I really do not care at all if he wants to do this, so screw it. Just know that he REALLY gots him some love for the cats.
    And the OP may have reached the end of jagabo's patience and THAT, my friends, is quite hard to do.
  12. Member DB83's Avatar
    Jul 2007
    To quote that famous pop song "Who let the cat out ?"
  13. I don't love cats, I'm a cat: it's simple
    fart search "Thisistheinputfilenamefield" and "thisisthepath" inside the .csb and replace the filename and path with the one suggested as argument by the batch
    fart.exe "ConverterStudioProject.csb" Thisistheinputfilenamefield "c a t . a v i"
    fart.exe "ConverterStudioProject.csb" thisisthepath "c : \ m y c a t s"
    the problem is generating c a t . a v i from cat.avi
    and c : \ m y c a t s from c:\mycats
  14. Groucho2004
    Guest
    So you simply ignore what I told you above? Or do you not understand it? The "spaces" you see may seem like spaces when you open the file in notepad but they are not. Notepad (at least the one in XP) cannot handle Unicode. Open the file in a hex editor and all will become clear.
  15. maybe I'm mistake, but using fart.exe over the .csb file I need to replace the string with spaces
    for example
    Using fart.exe I'm forced to replace string with spaces because it manage only ascii
    I'm a stupid cat but also fart.exe is stupid, so I'm looking for a string manupulator that convert
    c:\mycats
    into
    c : \ m y c a t s
  16. Groucho2004
    Guest
    D'oh. Look up the term "logical fallacy" on Wikipedia.
    You have to use a replacement tool that can handle Unicode. You may be able to do it with Python, see here.
    Just be careful, Python loves cats, preferably for breakfast.
  17. mmmm
  18. Member DB83's Avatar
    Jul 2007
    Are we allowed to say 'fart' on here ?
  19. Originally Posted by DB83 View Post
    well - it may be substituted as "natural smoke" (similar principle to cigarets smoking)...
  20. can anyone help a cat?
  21. I'm a MEGA Super Moderator Baldrick's Avatar
    No. Please wait 3 days before you bump.
  22. I was bored the other day.
  23. Click image for larger version
    thanks!!!!!!!!!!!!!!!!!!!! :=)
