  1. I am using TSCV 084 beta Rel. 1 to build chapters and menus for my VCD. I got to the part to import chapters from Chapterx and that goes successfully following the doom9 guide. I clik on send to TSCV and I see that the did get sent. Now, the problem. The guide says "
    Here's the result of your import. When you click on a chapter time now you'll see the chapter start frame in the preview window"
    I click on any of the chapter times and all I get is a black screen, nothing else. Any ideas?
  2. Do you have the "Show MPEG in Preview Window" option selected in the options or settings tab? I'm not too sure about the names of stuff because I don't have it open right now, but I think that should fix your problem.
  3. The option under settings is Enable Preview with media player on Chapter-Tab is checked and it does not work.
    Any ideas?
    Aug 2001
    Västerås, Sweden
    is there any reason you wnt to see that?
    If the chapters ar in the list, i will work
    Well, I am the slime from your video.
    Oozin' along on your livin'room floor.
  5. The reason is that by viewing the specific fram that is relevant to that chapter, you can attach it to the menu builder using TSCV. That is the only reason
    Aug 2001
    Västerås, Sweden
    Ok, i still do the menus 'by hand' in PS or simply rip them of the disc or even capture frame from them with powerdvd
  7. Do you have Media Player and are you sure that it works?
    If so then I have no idea what's wrong. I've been having pretty many problems with TSCV myself.
