Ok guys, after about two months and a lot of help I finally got virtual dub to capture audio with my built in soud board. Thanks to all who helped me out!!
Now I have another problem. If I capture at any rate above 15fps, I start dropping frames like crazy. If I try 25fps, I drop as many as I catch. I am using uncompressed AVI but seems to happen with pegasus mpg also.
I have the following system...
Win98SE
850 AMD Duron
512 Ram
20 gig HD
VooDooTV100 capture card (with the wdm drivers)
I just got a 40 gig HD that I am going to use for cap only, but not sure if this will help the problem.
Anyone else ever run into this??
TIA!!
Shadow
I only use Virtualdub for editing, subtitles, etc. I recommend Vidcap for capture. Also try using Huffyuv codec and PicVideo MJPEG codec for capture.
Have you tried defragmenting your hard drive. It's always better to capture to a dedicated capture drive than one thats running your operating system, so you may find that your new drive solves the problem.
Craig
Windows 7, Virtual Dub (any Version), BlackMagic Intensity Pro = No Capture
By Digital-Overload in forum Capturing and VCRReplies: 2Last Post: 22nd May 2011, 11:57 -
Need help with Virtual Dub setting
By lost123 in forum Capturing and VCRReplies: 12Last Post: 8th Jul 2010, 22:31 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 04:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36
