I've got a link which isn't accessible through normal web, instead I have to use:
https://web.archive.org/web/20120525054625/http://etv.err.ee/arhiiv.php?id=106205
I am able to get the rtmp address from the source. I found someone's Pastebin entry (http://pastebin.com/dqjch6pe), but I'm unable to find the "ID". I tried the following command, but I had no luck:
Got an error:Code:rtmpdump -r "rtmp://media.err.ee/etv30/2010.05.25_-_19.00-20.05_-_Ringvaade.flv" -v -o "C:\test.flv" -W "http://etv.err.ee/site/js/flowplayer2/flowplayer-3-2-15.swf"
I also tried this link:Code:ERROR: Closing connection: NetStream.Play.StreamNotFound
http://ext.err.ee/iframevideo.aspx?autoplay=false&mediaspace=mediaframe&stream=media.e....flv&width=620
But this also didn't work.
I guess they might've deleted the file or moved it somewhere else. I also noticed, that for older files, the site used "flash.etv.ee". I used tracert on it and got to:
Code:7 1 ms 1 ms 1 ms err.demarc.estpak.ee [195.250.170.82] 8 1 ms 1 ms 1 ms vpn.err.ee [194.36.162.115] 9 vpn.err.ee [194.36.162.115] reports: Destination host unreachable.
I guess my chances are slim if any, but I'm sure you're more experienced than I am.
Can you play the video/Is it still available? It doesn't work here but it might be a country restriction.
