Results 31 to 57 of 57
Ballpark is tough because you can spend as little or as much as you want. Maybe $2K to $10K .
Multiple monitors are helpful for screen "real estate". It really helps to have things spread out. You can of course get by with one. Or 4k/UHD monitors are coming down in price
But ideally one of your monitors should be a professional monitor for color work . Not $50 on ebay
Programs like Resolve (the gold standard for color work, and there is a free version available) can utilize multiple GPU's. Some filters scale linearly. So ideally you would have a few cards. - You get the idea. It can get very expensive very quickly -
You can "get by" and spend less if you want. There is a wide price range for components. Like cars.
In general, it 's less expensive to build a PC system using comparable spec components (especially if you do it yourself), and easier to customize or upgrade parts. More difficult with Apple
New stuff is always coming out. New technology, product cycles, etc... So don't invest huge once. Usually it's a better to make more frequent purchases over time -
With a monitor? Are you comparing to a laptop? (because a laptop has a "display" monitor) .
I've used a laptop to edit before on the road. It's "doable" but not preferred. Desktop with monitor(s) are usually much faster for the workflow. A desktop of the same generation will be faster, have better cooling, and cost less.
You can get pretty crazy "laptops" that are desktop replacements. But nobody in their right might would call them "laptops"They have desktop chips, overclocked, desktop cards. Cost about $6-8K fully decked out and are absolutely huge, about 10-12 lbs
The other stuff really isn't important. -
It's usable, but not ideal . It's going to feel sluggish on most HD editing projects with typical media
You need faster processor, more memory, better GPU -
You can "get by" using a cheap monitor or even your current MBP, but you're going to get frustrated and pull your hair out trying to edit with older MBP. Only you can determine if it's "good enough" for you by playing with the software. FCPX has a free trial, so download it and import some footage typical of what you think you're going to be using
"unresponsiveness" is the most frustrating thing for an editor. Slow render times usually aren't a problem (for example you can render overnight) unless you have deadlines
There are "tricks" people use - for example everything is transcoded to prores, and that makes editing smoother, more responsive, but that takes more time, and you incur some negligible quality loss. Another trick is a "proxy edit" - You have low resolution versions that you edit with and you swap back when it's time to do final render -
That's a good example newpball posted. If you can't see the embedded version, view it on the YT page
https://www.youtube.com/watch?v=47dtFZ8CFo8
Even if you're not a fan of the music, or the genre, or visual style - you can appreciate the level of quality. Everything flows and fits together and the effects are nicely done. They don't distract from the main goal (which is the music video). -
You mentioned in a now closed topic that your footage comprises of a lot of sports games.
For that you hardly need any effects. Slow motion, perhaps an occasional frame freeze but that is pretty much it. -
Yes, there are important concepts involved in editing that don't show up in the toy software.
Editing is very geeky. Don't hamstring yourself going for the easy-peasy NLE's. It takes about a year for your mind to open up.
If you use software designed for the unwashed masses, you delay the learning. I don't use this term as an insult, just to describe the "Joe Shmoe" types.Last edited by budwzr; 24th Feb 2015 at 14:12.
Yes, but barely.
Really high end pro tools include specialty apps, such as Davinci.
And Avid is still preferred.
I use Premiere Pro and FCP myself, but I have much more basic needs.Want my help? Ask here! (not via PM!)
Check here for good tutorials:
http://www.lynda.com/Video-Editing-training-tutorials/82-0.html
