    Nov 2012
    Anywhere
    Hi ,
    Installed Smplayer this morning ( the latest ) but text was all in a strange language.
    Reinstalled, but same again.
    No idea how to change the text into English as i can`t make sense of the toobar .
    My os is Ubuntu 14.04 , no problems on Windows - Preferences - Interface but not in Linux ?
    Thanks for any help.
  2. A Member since June, 2004 Keyser's Avatar
    Feb 2013
    Westernmost point of Europe
    If you're using the portable version, open smplayer.ini (located in the program folder) with notepad, look for "language=.." and change to "language=en".
    If you're not using the portable version, the file smplayer.ini may be located in %appdata%. I don't know for sure because I don't use the instalable version.
    "The greatest trick the Devil ever pulled was convincing the world he didn't exist."
  3. A Member since June, 2004 Keyser's Avatar
    Feb 2013
    Oh. You're using Linux. I guess there should be a preferences file somewhere. Try to find it and make the change I suggested above.
