I have ripped several episodes of a TV show from a BD using MakeMKV. I have been trying to use multiAVCHD to put 2 or 3 episodes at a time into a BD compliant format so they can be burned to a BD-R without compression. It does so with no problems, but the issue is that the subtitles, which are clearly present in the mkv files are not showing up in the .m2ts files it produces. I have tried playing around with all the subtitle options available, but nothing results in the subs being in the final file.
What am I missing???
TIA
SMK
I doubt multiavchd supports the mkv embedded blu-ray subtitles. I would rip to bdmv/m2ts and import it in multiavchd.
BDRebuilder will import MKV files, and I have checked to see that when it does, the output m2ts file will have subtitles. Is there a way to have BDRebuilder import more than one MKV file at a time so that you can put more than one episode of a series on one BD-R?
SMK
