Of course you don't want to "get in that one". There aren't any Blu-Ray "authoring tricks" that will change 480p 59.94 frames per second video from the Rocket into 480i at 59.94 fields per second for output from an authored Blu-Ray disc. The only way to produce an authored Blu-ray disc from that video is to re-interlace, or upscale to 720p before authoring.
Results 61 to 66 of 66
Yes that is true but that does not exclude the source being progressive, on a modern display it simply remains progressive despite that fields instead of frames are displayed sequentially.
Yes and not only film sources but also 25/30p video.
And I learned from you and others that that is 100% conform the DVD standard. Right?
No there isn't an authoring trick for Blu-Ray that will work as you say for 480p 59.94 frames-per-second video. I asked about that in the Blu-Ray authoring forum. https://forum.videohelp.com/threads/370912-Possible-to-author-Blu-Ray-with-480p-59-94-f...nd-H-264-video
