Results 1 to 21 of 21
  1. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    I have been purring along with a Core2Duo E8400 3.0 GHz. For complex stuff I just let it run overnight.
    I can get an "upgrade" for $280. It is a Dell with a Xeon X5450...4 cores 3.0Ghz. 4 gig ram.
    Am I going to see much of a speed increase? That is, with 4 cores, will encode time be cut in half?
    thanks!
    'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
  2. Member DB83's Avatar
    Jul 2007
    Common misconception.
    Your CPU is still 3 ghz so will perform at the same speed.
    If you are using software that utilize multi-cores then, yes, it will be faster. Twice the speed ? possibly
  3. Banned
    Oct 2014
    Northern California
    thanks!
    Old and slow stuff, don't bother with it, you would be wasting your money.
  4. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    Slow perhaps...but I can double my speed for under $300...i7 setup would be what...$800-$1,000? For how much quicker...I never like leading edge anyway. I'm not a pro encoder... I just would like a faster machine.
  5. Member DB83's Avatar
    Jul 2007
    I did not say you WOULD double your speed.
    It might help if you stated the software you use.
  6. Member wulf109's Avatar
    Jul 2002
    Any 4 core at 3.0Ghz or more will increase your speed. You should look into what 4 cores will work in your motherboard and just replace the cpu.
  7. Seems a little pricey, off-lease Optiplex 990's with 3.1GHz Core i5, 4GB RAM, 1TB HDD & Win 7 pro go for $330 (another $35 for 8GB). It will give you at least 50% boost in speed on single threaded applications and more than double the speed with multi-threaded with the same power consumption of your current CPU. As DB83 pointed out the Xeon is the same tech as the E8400 so single threaded apps won't benefit and the power consumption is double.
  8. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    Ok...food for thought...
    If I am running handbrake to convert a ton of 1920x1080 movies to 720p (hockey games for our sons hockey team) for either youtube or download. I think handbrake will use all cores right? So I could get some nice increases? The Optiplex route is interesting as well.
  9. Banned
    Oct 2014
    Northern California
    So let me get this straight you need computer power to degrade videos?
    If you don't mind the lower quality then I suggest you simply record 720p, not need for conversion, no need for computer power.
  10. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    I keep the 1080 stuff for myself. I cannot host movies for the other families and 1080 is useless for coaching on an iPad.
    So it needs to be compressed. For example, a 5 gig 1080 file from a 50 minute game can be compressed to 800 meg in 720p for distribution. I'm just looking for a faster way that does not cost too too much. Why don't I record in 720? To keep the best quality I can for posterity.
  11. Banned
    Oct 2014
    Northern California
    Good thinking!
    But you can upload 1080p to YouTube!
  12. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    Yah...but that takes way too long. I find the 700-800 meg encodes are a nice size. I'm not interested in 5 gig uploads.
  13. You can get a Q9550 to put in your current motherboard for well under US$100 (they're going for about $60 on ebay). It will be almost as fast as that X5450 Xeon system and you won't have to set up a new system. Just make sure you have enough PSU.
  14. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    If you replace a CPU, do you have to reactivate windows?
    Aug 2006
    It isn't especially likely that you will need to do that, but you can use manual phone activation if it does. Replacing the motherboard is far more likely to be a problem.
  16. Banned
    Oct 2014
    Northern California
    The nights are long......
  17. No, but you shouldn't be too concerned with that Microsoft will reactivate even if you replaced the whole PC (as long as the old one is out of service).
  18. Originally Posted by ron spencer View Post
    No, not unless you've changed several other components lately.
  19. Banned
    Oct 2014
    Northern California
    Since it is brought up what OS are you running and at what bit depth?
  20. Originally Posted by ron spencer View Post
    thanks!
    I have a Core2Duo E6750 and a Q9450. They're one generation apart (I think) but the same clock speed. For x264 encoding the Q9450 is pretty much twice as fast.
    For the times when it isn't (ie when using slow AVISynth filtering that bottlenecks the encoding process) because the four cores aren't being fully utilised, it's still effectively twice as fast because I can run two encodes simultaneously. The same applies to Xvid encoding because it doesn't utilise multiple cores as efficiently as x264, but I don't do much Xvid encoding these days.
    I see newpball is once again disrupting a thread with irrelevant nonsense. First "too old", then "don't re-encode" (how sad must someone's life be to spend time in a forum dedicated to video telling people not to re-encode?), then "doesn't matter how long it takes" and now we're at OS bit depth. Maybe if you're upgrading a PC that's too old to upgrade while re-encoding video you shouldn't be re-encoding you've at least got to do it using a 64 bit OS?
  21. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    It would be on Windows 7 64 bit.
    I am thinking the off lease idea is good. I could run the unit headless via remote desktop in a hidden room. May be an older PC, but I do not think the large increase in cost of i7 is worth it for this task. I could get 2 handbrake jobs done overnight on the new quad core one plus a single one on the E8400. I would also get a new OS out of it as well.
    Or get a new CPU to replace the E8400
