Results 1 to 9 of 9
  1. Banned
    Oct 2014
    Northern California
    Anyone got this to work.
    Tried this Adobe WebM plugin:
    https://github.com/fnordware/AdobeWebM
    And it gives me sound but no video:
    Video
    Format : VP9
    Codec ID : V_VP9
    Duration : 2mn 4s
    Bit rate : 279 Kbps
    Width : 2 560 pixels
    Height : 1 440 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Bits/(Pixel*Frame) : 0.003
    Stream size : 4.13 MiB (60%)
    Language : English
    Default : Yes
    Forced : No
  2. Member Cornucopia's Avatar
    More details needed: OS version (+bitlevel), PPro version (+bitlevel)
  3. Banned
    Oct 2014
    Northern California
    Windows 8.1 64bit, PPro Caravan 64 bit.
  4. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    I don't use Premiere, but if you need to edit vp9 webm, you can do it in Virtualdub via ffmpeg input driver. You can also edit vp9 webm directly in Aviutl.
    I do have an old version of Premiere (version CS3), but I'm not going to install it just to test out some plugin.
  5. Member Cornucopia's Avatar
    Just a guess, but it seems the API has changed gradually but continually with each version iteration, so it's probably likely that the plugin doesn't (fully) support the most recent version(s).
    ...I tested the WebP plugin in Photoshop (both v7 and CS3). Opens with both. Don't have time for testing WebM ATM.
  6. Banned
    Oct 2014
    Northern California
    I suspect you are right.
    This would just be a nice to have as there are obviously simple workarounds, what is a bigger problem is that the debug frameserver for Avisynth fails on PP but that is another topic.
  7. Banned
    Oct 2014
    Northern California
    Latest version at least let's me start encoding.
    After awhile get 'unknown error', not very helpful!
    But 45 seconds of video did actually render through PP and plays directly in a browser.
    Anyone else playing with this?
    Apr 2015
    San Francisco, CA
    Could you try the release version and let me know if you still have any problems?
    You could also file a bug as an issue in GitHub.
  9. Banned
    Oct 2014
    Northern California
    I will.
    Great job by the way!
