    Oct 2005
    Florida, United States.
    Hello,
    I have a QuickTime MOV file that I would like to convert to MPEG2 for DVDR burning. Thus far, I have tried using DVDFlick, Aimersoft Video Converter, and ConvertXtoDVD. However, when each of these software applications opens the MOV file, there are black bars along the bottom and ride side of the video. Attempts to convert result in MPEG2 files with these same black bars. However, if I play the video in QuickTime, the bars aren't there. I can only surmise that the software is not loading the video at the correct resolution. Any suggestions on how to get around this?
    Thanks.
  2. Banned
    Oct 2014
    Northern California
    If you need this on a DVD then crop/resize it to SD resolution and be done with it!
  3. Member Cornucopia's Avatar
    It wasn't stated that the footage is NOT already SD, so that kind of response is totally unhelpful.
    First, post a MediaInfo text readout of your stuff. It probably is just a misunderstanding of the AR, but we cannot tell without further details.
    Aug 2006
    Originally Posted by justin81 View Post
    Hello,
    Thanks.
    The maximum resolution allowed for DVD is 720x480 for NTSC or 720x576 for PAL, and there are only two aspect ratios allowed, 4:3 or 16:9. A DVD converter will normally use black bars (when necessary) to pad video so it matches the aspect ratio you choose (either 4:3 or 16:9) and will re-size the video so it has the correct resolution for DVD. If you dislike black bars, you will need to crop the video to either a 4:3 or 16:9 aspect ratio before converting to DVD. I haven't used DVDStyler all that much much, but it does MOV to DVD conversion, plus DVD authoring, and includes a user-friendly crop function.
    Oct 2005
    Here are the specs. Let me know if you need more info...
    General
    Complete name : C:\Users\Justin\Desktop\FAUM.mov
    Format : QuickTime
    Format/Info : Original Apple specifications
    File size : 332 MiB
    Duration : 22mn 55s
    Overall bit rate : 2 023 Kbps
    Encoded date : UTC 2007-12-11 07:54:52
    Tagged date : UTC 2007-12-11 08:42:38
    Writing library : Apple QuickTime
    Video
    Format : H.263
    Codec ID : h263
    Duration : 22mn 55s
    Bit rate : 483 Kbps
    Width : 320 pixels
    Original width : 352 pixels
    Height : 240 pixels
    Original height : 288 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.210
    Stream size : 79.1 MiB (24%)
    Language : English
    Audio
    Format : PCM
    Format settings, Endianness : Big
    Format settings, Sign : Signed
    Codec ID : twos
    Duration : 22mn 55s
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 252 MiB (76%)
    Language : English
  6. Member Cornucopia's Avatar
    Ok, you've got an "interesting" file there...
    Problems:
    1. The file's original HxW was 352x288. AKA, this was a (PAL?) CIF file which had a 4:3 DAR (ITU-type PAR). However,
    2. The file's current resize/"aperture"window in Quicktime MOV format is 320x240. This makes it still 4:3 DAR (and in square pixels), but it has been resized down. Also,
    3. The file's framerate is not consistent with PAL (25fps), but instead with NTSC, even though it was not originally NTSC resolution.
    4. The file uses h.263 encoding.
    5. Also, the file's audio is Big-Endian (most likely because this was saved on a Mac?)
    Sounds like this was from some videoconference, right?
    Your list of apps attempted leads me to believe that you are now using a PC - is this truly the case?
    Your choices are: conform the framerate to match the (original) resolution, or conform the resolution to match the framerate. Since you do live in the US, I think the latter would be better (you tell me).
    Another choice is whether to uprez it to full D1 to encode (to MPEG2) and author for DVD, or to leave the rez as-is and encode as CIF MPEG1/2 and author. DVD does support that resolution, but some apps don't/won't take advantage of it.
    If it were me, I'd resize the resolution to 352x240 @ 29.97 with 4:3 DAR (aka NTSC CIF), encode to MPEG2 @ ~4-6Mbps (no need to go higher - the source quality won't show it, shouldn't go much lower even with CIF, in order to retain what little quality there is). Leave the LPCM audio as is.
    With a supporting authoring app this should work out fine and give you a normal full-screen 4:3 image on a 4:3 display when played on a DVD.
    <edit>I would:
    A. Using QT Pro, convert the h.263 video to Uncompressed AVI at same dimensions (no resizing). Also demux the LPCM audio to WAV.
    B. Using AVISynth script & HCEnc, convert the Uncompressed AVI to suggested dimensions & encode to MPEG2 (2pass VBR - Max 7.9Mbps, Avg ~4-6Mbps, Min 0.5Mbps).
    C. Author, using whichever works for you stylistically & complexity-wise (as well as supporting CIF-rez sources). Start by trying DVDFlick, DVDStyler, DVDAuthorGUI, etc. (I would use DVDArchitect, Encore or DVDMaestro, but I have those tools).
    Oct 2005
    Scott, thanks very much your advice. I'll give it a shot!
