I forgot to mention that the subtitles are .PGS format. I started with an .M2TS file and converted to mkv that has the pgs subtitles in it.
The obvious answer is to extract them from the M2TS or MKV file and add them in separately. Apparently both Handbrake and VidCoder accept Blu-Ray subs as input. I wouldn't know for sure because I don't use those programs. Try MKVExtract or maybe BDSup2SUB.
From https://trac.handbrake.fr/wiki/Subtitles
With MP4, you can burn ONLY 1 subtitle track into the video. You can not pass-through PGS into MP4 as this file format does not support it
So you can use the burn-in or convert PGS to IDX/SUB (BDSup2Sub) and mux those in (MyMP4Box GUI) or you could perform OCR of the PGS to ttxt (Subtitle Edit) and mux those.
But why re-encode the m2ts? You could re-mux the .m2ts to .ts (tsMuxeR GUI) and use that in My MP4Box GUI together with idx/sub or has it to be h.264 video? -
I have an update and a different problem. I have successfully created an srt file that I muxed into the mkv with mkvtoolnix. When I play the movie with vlc, the subtitles are there. The frustrating problem, and for the life of me, I cannot get this sort into an mp4 and have the subtitles play. I tried the following: Using vidcoder to convert the mov to mp4 and selecting the srt from the source. I also loaded the mkv and then imported the .srt separately. I read somewhere to used subedit to convert the srt to ssa then mux the ssa with the mkv. I also tried muxing the mp4 and .srt with mp4boxgui. NONE OF THESE WORKED. I did notice something consistent with everything I tried. In the .mkv file, MediaInfo shows the subtitle as a UTF-8 file ID: 3. In the .mp4, it is showing it as a Timed Text and the codec ID is tx3g and is not retaining the UTF-8.
One other thing: when the .mp4 and .srt are in the same folder, the .mp4 plays the subtitle. Not sure if this is a factor, but I can't imagine it being this difficult when I've come this far with the information I provided above. Please help!!
