  1. Finally found an answer to my previous problem, I immediately find a new one. This shouldn't be as hard as that one though (I hope )
    A PAL 576i DVD at 25FPS with ghosting/blending. Audio pitch is fine. SRestore did a good job on a lot of my PAL dvds, but not on these, as you can see:
    Adding FRate="23.976" or 29.97 doesn't help much. TFM()+SRestore or only deinterlacing neither works.
    Commandline:
    x264.exe --profile high --preset veryslow --crf 18 --sar=744:694 --output output.mkv test.avs
    Script:
    LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\masktools2-25.dll")
    LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\dgmpgdec158\DGDecode.dll")
    LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\decomb\Decomb.dll")
    Import("C:\Program Files (x86)\AviSynth 2.5\plugins\QTGMC-3.32.avsi")
    LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\ffms2.dll")
    ffVideoSource("input.mkv")
    QTGMC( Preset="Slower" )
    SRestore()
    Crop(10,4,-14,-8)
    It's a USA (NTSC) production, but I'm not sure if this was made on video or film. Can somebody suggest how to tackle this?
  2. Originally Posted by pub View Post
    Buy the NTSC version as you can forget about unblending this one. Unblenders depend on at least one field of each frame being 'clean'. You don't have that.
    And when uploading samples please don't make them into MKVs. Use DGIndex to cut an M2V from the VOB and upload that.
  3. There's too much blending. I don't think you'll find any way to restore the original film frames.
