I have some mp4 files i'd like to convert to play on a dvd to play on dvd players, , if i convert those to wmv or wav on zamzar will they play on a dvd player or what format should they be put in? i don't know for sure the model of the player/s and what format is supported, so what might be the most likely?
i did not see NTCS listed ? It seems these formats don't play on dvd players so again what should i be converting them to.?
tks
Make a standard dvd, https://www.videohelp.com/dvd#struct . It will work on most players.
With for example avstodvd, convertxtodvd, dvd flick, etc. -
yes. convertxtodvd can burn. avstodvd requires imgburn.
