I have a lot of scripts for conversion of different videos and I want to AutoEncode all of them using the same settings, codecs etc. Is it possible to add all of them at once instead of queueing one-by-one?
The OneClick encoder does batch converting and I'm pretty sure you can use scripts for the input video. You'll probably need to create a OneClick preset using your preferred encoder presets and tell it not to auto-crop or resize etc.
