I try some one like this "avidemux_cli.exe --load test.mkv --video-process --720p-res --video-codec x264 --save test720.mkv --quit"
not working.
I need to keep the two sound track in video i think this is the easy one to use. but looks i am wrong?
I need to conver many files.
can some one help please....
I am first time using video edit program.
thank you for all.
Results 1 to 10 of 10
You can adjust the other encoding settings (e.g. quality , speed, presets, etc...)
Once you are happy, you can use a ffmpeg GUI to batch convert with a preset e.g. ffqueue or tencoder
or use a dos command to batch convert all the MP4's in a folder e.g.
Code:for %a in ("*.mp4") do ffmpeg -i "%a" -map 0:0 -map 0:1 -map 0:2 -c:v libx264 -s 1280x720 -c:a copy -c:a copy "%~na.720p.mp4"
thank you update the command,
i am good with this one "for %%a in ("1080\*.*") do ffmpeg -i "%%a" -map 0:0 -map 0:1 -map 0:2 -c:v libx264 -s 1280x720 -c:a copy -c:a copy "720\%%~na.mp4""
just put all video file in 1080 and come out 720 folder.
thank you again. help me a lot
