Results 1 to 11 of 11
  1. Hi there,
    I have six good quality 45 min .avi files that I'd like to burn to DVD. Normal 4.7GB DVDRs makes the video quality look terrible. Would using a dual layer 8.5GB disc keep the output looking sharpish, or will it always go bad when it converts to the MPEG2?
  2. Member Cornucopia's Avatar
    6 x .75Hours = 4.5Hours (270 min. or 16200 sec.).
    DL disc = 7.95GB = 65126.4Mb. 65126.4 / 16200 = ~4.0Mbps (slightly less for the video if you intend to include audio).
    4Mbps, if that is an AVG 2pass VBR rate (max 9Mbps, min 0.5Mbps), and if the footage is cleverly noise filtered, can still be of decent quality. Use something like HCEnc.
  3. Banned
    Oct 2014
    Northern California
    Originally Posted by philglew View Post
    Hi there,
    There is absolutely no reason why it should, as long as it is not a movie of running water or burning fire a dual layer DVD should have no problem with 6x45 minutes of video. Of course it is SD video, incomparable to HD.
    But, why try to compress it all on one disk? Disks are dirt cheap, what is the problem spreading this out on at least two disks?
    I take it you took great care in making sure the frame rates, aspect ratios and flags where all unchanged.
  4. Originally Posted by Cornucopia View Post
    Thanks very much. That's great. I'll give it a go.
    Out of interest, when professionally made DVDs are released of TV series with like 6 episodes on one disc, what format is the raw video in order for the DVD output to still look great?
  5. Banned
    Oct 2014
    Northern California
    It depends if the series was produced on video or on film.
  6. Originally Posted by newpball View Post
    Hi there,
    There is absolutely no reason why it should, as long as it is not a movie of running water or burning fire a dual layer DVD should have no problem whatsoever with 45 minutes of video.
    Post a few seconds of the original and a few seconds of the DVD encoded video.
    Thanks for your reply. When I burn all six to one DVDR (single layer) the quality is poor. Haven't tried DL DVDR yet. All six on one DL DVDR?
  7. Banned
    Oct 2014
    Northern California
    Oh I misread that, no 270 minutes of video is typically too much for single layer.
    I am curious, why not put each episode on a single layer DVD?
    You have a problem that can be easily solved by just throwing some more DVD disks at it.
    Nov 2003
    West Texas
    All six on a DL DVD should work. Putting three on a single layer DVD, then the other three on another would be slightly better, as you'd have a little more room. (4.3gb per each single layer, 7.9 for DL)
    I'd try AVStoDVD and see if you like the results. You can make a menu with it so that you can select each video.
  9. Thanks. Is there a Mac equivalent?
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    Maybe dvdstyler.
  11. you can also stretch it using 2 dual layers with 3 episodes on each disc and that should help with the quality a bit more, or as others suggested 1 or 2 eps per single layer dvd
