  1. Hi, when i trying to import avi file to ripbot, this error is shown :
Name:	rip error.jpg
    avi media info :
    General
    Complete name                            : C:\The.Goodbye.Girl_1977.DVDRip.avi
    Format                                   : AVI
    Format/Info                              : Audio Video Interleave
    File size                                : 1.47 GiB
    Duration                                 : 1h 50mn
    Overall bit rate                         : 1 904 Kbps
    Writing application                      : VirtualDubModRus 1.5.10.2 (build 2542/release)
    Writing library                          : VirtualDubMod build 2542/release
    Video
    Format                                   : MPEG-4 Visual
    Format profile                           : Advanced Simple@L5
    Format settings, BVOP                    : 1
    Format settings, QPel                    : No
    Format settings, GMC                     : No warppoints
    Format settings, Matrix                  : Default (MPEG)
    Codec ID                                 : XVID
    Codec ID/Hint                            : XviD
    Duration                                 : 1h 50mn
    Bit rate                                 : 1 634 Kbps
    Width                                    : 720 pixels
    Height                                   : 416 pixels
    Display aspect ratio                     : 1.731
    Frame rate                               : 23.976 fps
    Bits/(Pixel*Frame)                       : 0.228
    Stream size                              : 1.26 GiB (86%)
    Writing library                          : XviD 1.2.1 (UTC 2008-12-04)
    Audio #1
    Format                                   : AC-3
    Format/Info                              : Audio Coding 3
    Mode extension                           : CM (complete main)
    Format settings, Endianness              : Big
    Codec ID                                 : 2000
    Duration                                 : 1h 50mn
    Bit rate mode                            : Constant
    Bit rate                                 : 128 Kbps
    Channel(s)                               : 1 channel
    Channel positions                        : Front: C
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 16 bits
    Stream size                              : 101 MiB (7%)
    Alignment                                : Split accross interleaves
    Interleave, duration                     : 42 ms (1.00 video frame)
    Interleave, preload duration             : 500 ms
    Audio #2
    Format                                   : AC-3
    Codec ID                                 : 2000
    Duration                                 : 1h 50mn
    Bit rate                                 : 128 Kbps
    Bit depth                                : 16 bits
    I already enabled Desktop Experience on my windows (Windows Server 2008)
    Did you install ffdshow when you installed ripbot264?
    Or else install the xvid codec and ac3 filter.
  3. when i install ripbot, it asked me to install some requisite plugins. except those, i did't install any plugin.
    though mostly i have not problem with importing files to ripbot.Just some avi files like this make error.
