  1. Hi cats
    please I wonder
    my camera is becomed a ftp site so that files are
    ftp://192.168.0.18/Clip/C0001.MXF
    ftp://192.168.0.18/Clip/C0002.MXF
    ftp://192.168.0.18/Clip/C0003.MXF
    ftp://192.168.0.18/Clip/C0004.MXF
    etc..
    Can I tell to ffmpeg that it have to directly open the files in camera without download (get) .mxf files in my local pc?
    for example:
    ffmpeg -i ftp://192.168.0.18/Clip/C0001.MXF -vcodec etc...
    but it don't work
    my username: admin
    password: pdw-f800
    thanks!!
  2. Click image for larger version
  3. you need login/ password for ffmpeg
    see this
    https://www.ffmpeg.org/ffmpeg-protocols.html#ftp
    Add the user and password in the url like
    ffmpeg -i ftp://admin:pdw-f800@192.168.0.18/Clip/C0001.MXF -vcodec etc...
  5. mmm useful thanks
    but it strange that ffmpeg report: "invalid data found when processing input" even if i try to download the C0002.mxf and put on c:\
    so that I have c:\c0002.mxf and if I do:
    ffmpeg -i c:\c0002.mxf etc...
    it works well
    but via ftp I get alwais the "invalid data found when processing input" error
    Is there a way to resolve? thanks
    please consider that the camera, as ftp, does not allow to anyone to write data on his xdcam disc. But in this case ffmpeg have only to read, not to write, so that I think the "invalid data found when processing input" is not related to the impossible of write on the camera-disk
  6. What about trying vlc or potplayer??
  7. @marcorocchini:
    a. using a higher loglevel (https://www.ffmpeg.org/ffmpeg-all.html#toc-Generic-options) might help getting additional info about what is causing the problem.
    b. this will probably not work with linked mxf files (mxf files which link to other resources)
