Hello. I have installed the MPC-HC but I read that the MPC-BE is more complete because it has more customization options. But when I play an video anime in mkv format does not play the opening and ending into the video (MKV Ordered Chapters). I do not understand why it does not. However, the MPC-HC it does correctly.
	Possibly because the internal Matroska splitter of MPC-BE doesn't support ordered chapters
 You can disable the built-in Matroska splitter and force MPC-BE to use LAV Filters or Haali Media Splitter.
 MPC-HC uses LAV internally, this is the reason why it works as you expected  Last edited by El Heggunte; 13th Feb 2015 at 16:41. Reason: better wording
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
