Hi SO I Am using SubRip For Ripping The Subs from MY DVD.
This Is What i Did exactly In Pictures
I Entered Every Character/Letter Manually as it asked For And After It Finished The Process i saved it to .srt Format
But when i open the .srt File With Notepad.... I Get This Below.....What Went Wrong
	Hello.
 Which SubRip's version are you using? The latest ones save the text in Unicode - UTF 8 mode.
 To solve this problem you can change settings from that program.
 In my case, I just open the text using Subtitle Edit and save the text using Encoding: 1252.
 After that the text is saved "correctly". You can open it using Notepad, for example, and all the words are arranged just like the common "pattern" below:
 Maybe doing such thing you can solve your problem.1
 00:01:27,650 --> 00:01:28,893
 Surprise!
 2
 00:01:30,338 --> 00:01:32,988
 Thanks for helping this summer.
 Have a great year at school, Paige.
 3
 00:02:25,602 --> 00:02:27,544
 Hey, what happened
 to the Lamborghini?
 Thanks.
 best regards.
	In subrip , Global Options, try to put the settings below:
 Save as Unicode: Never
 Line Breaks: DOS/Windows
 The other setting you can let the way as they are.
 Or, do it as suggested before:or use Subtitle Edit , doing what I told you before, saving the text using Encoding: 1252.Open it with Notepad++
 Maybe this help.
 Best regards.
 devil (johner)Last edited by devilcoelhodog; 14th Feb 2015 at 09:42.
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
