Have an LG Blu-Ray writer that burns both BD-R and BD-RE as well as CD-R/RW & DVD-R/+R/RW. Sony DVD Architect Studio (which does both BR and DVD projects) recognizes the drive, can tell you the stats of BD-RE media in it, but won't actually burn to a BD-RE, but will burn to a BD-R. Same with FreeISOBurner. The only app that will burn a BD-RE disc is the Cyberlink Blu-Ray Disc Suite that came with the drive.
The disks I'm using are Color Research
Any insight as to why this is?
Running XP SP3
Thanks.
It may be the media brand, believe it or not. About 3 years ago I bought one Sony BD-RE disc because I wanted one RE disc. I didn't need a pack of them, just needed one. Sony was easy to find in local stores, so I bought it. None of my BluRay players would play it and I seem to recall it was troublesome to burn to as well, although I did finally pull that off. I bought a Verbatim BD-RE disc and that was a lot better. My players had no problems with it. I'd suggest trying a Verbatim disc and see if it works better. Try ImgBurn too as if it doesn't work then for sure you'll have to try my Verbatim suggestion.
