dear friends,
i have to write dvd on daily basis. video file. mpeg .
i want that. just select the folder (having all files). start writeinf dvd. one by one dvd will get write. i just change the dvd
Results 1 to 17 of 17
Are you writing your DVDs in DVD format, VIDEO_TS folders? If they are just MPEG files and you want DVD format, then they would need to be 'authored' to DVD format.
If you just want to burn the MPEG as data, then ImgBurn should work. It can also burn authored DVD formats.
And welcome to our forums. -
dear sir
first of all thanku for your reply.
now thing is that i want to make video dvd. yes "video_ts" folder.
generally i m using corel dvd movie factory. every thing is simple.
i want to make it more comfortable . suppose i have 2 mpeg file , & want to burn them on 2 different dvd (1 hour each) . each time i have aad next mpeg file in movie factory(using add option). -
i want to tell the software that this is my folder having no. of mpeg file . plese burn them one by one . i will just change dvd s. one by one
i dont know the meaning of authoring. in my language batch dvd write u can say.
it take 13/mints for 1 dvd to write. each tym i have to add next mpeg file then new dvd insert. i just want to change dvds
AUthoring is making the dvd/video_ts structure so I'm moving you to that forum section.
Nope, I don't know any method to burn/author each mpg as a separate dvd. -
okkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk kkkkkkkk
You can probably create a number of projects and save them ready to go, but you're still going to have to babysit the burning
thanks smrpix
can projects run one by one automatic?? i will just change dvd one by one -
