  1. Could anyone tell me if I'm correct about this. I've noticed that when searching for movies(especially TS)on p2p I see in the notes- bitrate numbers. Is it true that the higher he bitrate the better the quality? Also If The higher the bitrate Then the file will be larger? Thanks in advance Ed
    Jul 2001
    Maryland
    yes, higher bitrate, better quality, bigger file
  3. thanks greg12
