Results 1 to 13 of 13
  1. Source audio is 5.1 DTS but FFmpeg (in AVSTODVD) audio input is stereo PCM. AC3 output as radio buzzing sound.
    MediaInfo of source file:
    Video
    Format profile                           : High@L4.1
    Format settings, ReFrames                : 12 frames
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 2h 8mn
    Bit rate                                 : 4 123 Kbps
    Width                                    : 1 280 pixels
    Height                                   : 532 pixels
    Display aspect ratio                     : 2.40:1
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 fps
    Bits/(Pixel*Frame)                       : 0.253
    Stream size                              : 3.61 GiB (83%)
    Writing library                          : x264 core 130 r2273 b3065e6
    Encoding settings                        : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=4123 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=2:1.00
    Default                                  : Yes
    Forced                                   : No
    Audio
    Format                                   : DTS
    Format/Info                              : Digital Theater Systems
    Mode                                     : 16
    Format settings, Endianness              : Big
    Codec ID                                 : A_DTS
    Duration                                 : 2h 8mn
    Bit rate mode                            : Constant
    Bit rate                                 : 755 Kbps
    Channel(s)                               : 6 channels
    Channel positions                        : Front: L C R, Side: L R, LFE
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 24 bits
    Stream size                              : 692 MiB (15%)
    Title                                    : English DTS 5.1@755Kbps
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    FFMpeg in AVSTODVD "say":
    Input #0, avisynth, from 'C:\DOCUME~1\User\AppData\Local\Temp\DVD_A Team_1.avs':
    Duration: 02:08:18.16, start: 0.000000, bitrate: N/A
    Stream #0:0: Video: rawvideo <I420/0x30323449>, yuv 420p, 720x576, 23.8 fps, 23.98 tbr, 23.98 tbc
    Stream #0:1: Audio: pcm_s16le, 48000Hz, stereo, s16, 1536kb/s
    SOLUTION:
    If you definitively need to convert only 3 minutes, you can cut that portion of the souce title with Avidemux and then feed AVStoDVD with the new small mkv. Doing that, the DTS track will be retained as well.
  2. DECEASED
    Jun 2009
    Heaven
    { e r a s e d }
    Last edited by El Heggunte; 9th Feb 2015 at 07:52. Reason: the king has entered the building
  3. @Mark22
    input audio is pcm_s16le because the AviSynth script frameserves raw audio to FFmpeg. That's normal. Buzzing sound from the resulting AC3 is not normal
    Could you post the complete AVStoDVD project log file?
    Bye
    MrC
    AVStoDVD Homepage
  4. Code:
    <2/9/2015 17:02:07>
    START PROCESS
    <2/9/2015 17:02:07>
    PROJECT SETTINGS
    DVD Video Standard: PAL
    DVD Titles number: 1
    DVD Size: 95/4450 MB (2%)
    DVD Output Setup: DVD Folder
    DVD Label: DVD
    DVD Menu: No Menu
    Output Folder: C:\Documents and Settings\User\My Documents\My Videos
    Delete Temp Assets Files: Yes
    Delete Temp Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    MultiThread: 1
    AVS Video Source Filter: A2DSource
    AVS Audio Source Filter: A2DSource
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
    Frame Adjust Strategy: 1
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video BitRate Min: 2500
    Video BitRate Level 1: 6500
    Video Profile Level 2: 4500
    Video BitRate Max: 8500
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 1
    Force FFmpeg for Long Audio: 1
    DVD Audio Format: 0
    DVD Audio BitRate: 192
    Keep DVD Compliant Audio: 1
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Audio Language (Primary): EN - English
    DVD Audio Language (Secondary): EN - English
    DVD Subs Language (Primary): EN - English
    DVD Subs Language (Secondary): EN - English
    DVD Subs Font: Tahoma 16pt (255,255,255)
    Chapters Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: F: Optiarc DVD RW AD-7173A 1-01
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Unload ActiveMovie library: 0
    Adjust DirectShow Filters at runtime: 1
    Save General Settings: 0
    SYSTEM INFO
    Processor Name: AMD Athlon(tm) 64 X2 Dual Core Processor 5200+
    Operating System: Windows XP Service Pack 3 (32 bit)
    AviSynth is installed: YES (release 2.6.0)
    LAV Filters is installed: YES (release 0.63.0)
    ffdshow is installed: YES (release 1.3.4500)
    <2/9/2015 17:02:07>
    TITLE 1 SOURCE FILES
    Video: D:\Filmovi\Body Of Lies 2008 720p BluRay DTS x264-SilverTorrentHD\Body Of Lies by The Vortex.mkv
    Info: AVC - 4123 kbps - 1280x532 - DAR 2.406 - 23.976 fps (CFR) - Progressive - 2:08:18 hours - 184571 frames
    Audio 1: D:\Filmovi\Body Of Lies 2008 720p BluRay DTS x264-SilverTorrentHD\Body Of Lies by The Vortex.mkv
    Info: DTS - 754 kbps - CBR - 6 ch - 48000 Hz - 24 bit - 2:08:18 hours (0 ms delay) - EN
    [MediaInfoLib - v0.7.69]
    <2/9/2015 17:02:07>
    AVISYNTH SCRIPT
    Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("D:\Filmovi\Body Of Lies 2008 720p BluRay DTS x264-SilverTorrentHD\Body Of Lies by The Vortex.mkv", CacheFolder="C:\DOCUME~1\User\AppData\Local\Temp", FrameRate=23.976, VFR=false)
    # Audio is frameserved by AviSynth just for Preview and Edit purposes.
    Audio = A2DAudioSource("D:\Filmovi\Body Of Lies 2008 720p BluRay DTS x264-SilverTorrentHD\Body Of Lies by The Vortex.mkv", CacheFolder="C:\DOCUME~1\User\AppData\Local\Temp")
    Video = Video.ConvertToYV12()
    Video = Video.AddBorders(0,214,0,214)
    Video = Video.Spline16Resize(720,576)
    #Using DGPulldown/HCenc to upsize FPS
    AudioDub(Video, Audio)
    Trim(0,4325)
    <2/9/2015 17:02:07>
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: FFmpeg CBR 1-pass
    Target Video FileSize: 85.1 MB
    Encoding Parameters: -i "C:\DOCUME~1\User\AppData\Local\Temp\DVD_Body Of Lies by The Vortex_1.avs" -threads 2 -aspect 4:3 -c:v mpeg2video -b:v 3967k -minrate 3967k -maxrate 3967k -bufsize 2000k -dc 8 -y "C:\Documents and Settings\User\My Documents\My Videos\DVD_Body Of Lies by The Vortex.m2v"
    <2/9/2015 17:03:26>
    END VIDEO ENCODING OPERATIONS
    Video Source Filter: A2DSource (DirectShowSource)
    Created File: C:\Documents and Settings\User\My Documents\My Videos\DVD_Body Of Lies by The Vortex.m2v (85.3 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 3967 kbps - 720x576 - DAR 4:3 - 23.976 fps (CFR) - Progressive - 3:00 minutes - 4320 frames
    <2/9/2015 17:03:26>
    START PULLDOWN OPERATIONS
    DGPulldown Parameters: "C:\Documents and Settings\User\My Documents\My Videos\DVD_Body Of Lies by The Vortex.m2v" -srcfps 23.976 -destfps 25 -inplace -tff
    <2/9/2015 17:03:36>
    END PULLDOWN OPERATIONS
    DGPulldown executed on File: C:\Documents and Settings\User\My Documents\My Videos\DVD_Body Of Lies by The Vortex.m2v (85.3 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 3967 kbps - 720x576 - DAR 4:3 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 3:00 minutes - 4510 frames
    <2/9/2015 17:03:37>
    DIRECTSHOW AUDIO MIXER OPERATIONS:
    No mixer adjustment required at runtime.
    <2/9/2015 17:03:37>
    START AUDIO ENCODING OPERATIONS (Track 1)
    FFmpeg (WAV) Parameters: -i "C:\DOCUME~1\User\AppData\Local\Temp\DVD_Body Of Lies by The Vortex_1.avs" "C:\DOCUME~1\User\AppData\Local\Temp\DVD_Body Of Lies by The Vortex_1.wav"
    Aften (AC3) Parameters: -b 448 -pad 0 -dynrng 5 -bwfilter 0 "C:\DOCUME~1\User\AppData\Local\Temp\DVD_Body Of Lies by The Vortex_1.wav" "C:\Documents and Settings\User\My Documents\My Videos\DVD_Body Of Lies by The Vortex_1.ac3"
    <2/9/2015 17:03:55>
    ffdshow mixer setting restored to '1'
    <2/9/2015 17:03:55>
    END AUDIO ENCODING OPERATIONS (Track 1)
    Audio Source Filter: A2DSource (DirectShowSource)
    Created File: C:\Documents and Settings\User\My Documents\My Videos\DVD_Body Of Lies by The Vortex_1.ac3 (9.6 MB)
    OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 3:00 minutes (0 ms delay)
    <2/9/2015 17:03:57>
    START DVD AUTHORING OPERATIONS
    BatchMux Parameters: -arglist "C:\DOCUME~1\User\AppData\Local\Temp\DVD_BatchMux.ini"
    BatchMux ini file:
    -d "C:\Documents and Settings\User\My Documents\My Videos\DVD\VIDEO_TS"
    -mxp "C:\DOCUME~1\User\AppData\Local\Temp\DVD_MuxMan.mxp"
    -l "C:\DOCUME~1\User\AppData\Local\Temp\DVD_MuxMan.log"
    -muxman "C:\Program Files\AVStoDVD\MuxMan"
    -prio LOW
    -palette "C:\DOCUME~1\User\AppData\Local\Temp\DVD_Palette.txt"
    -v "C:\Documents and Settings\User\My Documents\My Videos\DVD_Body Of Lies by The Vortex.m2v"
    -vidmode 4:3
    -a1 "C:\Documents and Settings\User\My Documents\My Videos\DVD_Body Of Lies by The Vortex_1.ac3"
    -a1lang en
    <2/9/2015 17:04:41>
    END DVD AUTHORING OPERATIONS
    Created Folder: C:\Documents and Settings\User\My Documents\My Videos\DVD (97.2 MB)
    CHECK DVD SIZE
    DVD Folder (actual) Size: 97.2 MB
    vs Estimated Size: 95 MB -> 2.3% oversize
    vs Assets Size: 95 MB -> OK
    <2/9/2015 17:04:41>
    Log file created by AVStoDVD Release 2.8.0
  5. From the log file there are 2 minor issues:
    1. You have installed both ffdshow and LAVFilters as decoders. This may lead to a redundancy in the directshow decoding chain. Check with 'Tools'/'Build DirectShow Filters Graph' if the source title is decoded by either ffdshow or LAVFilters but not both. If both decoders appear in the filters graph (audio path), I suggest you to uninstall one of them
    2. You have selected FFmpeg+Aften instead of the default Wavi+Aften. Any reasons behind this choice? Have you tried with Wavi+Aften?
    Bye
    MrC
    AVStoDVD Homepage
  6. 1.I don't understand but I tried uninstall LAVFilters and ffmpeg and not work
    2.I tried change encoder but not work
  7. Would you try to go to 'Tools'/'Build DirectShow Filters Graph' and report here the screenshot of the resulting filters graph?
    Bye
    MrC
    AVStoDVD Homepage
  8. I don't have Build DirectShow Filters Graph in Tools.
  9. Sorry, it is in 'Codecs' section: 'Codecs'/'Build DirectShow Filters Graph', just few clicks on the right...
    Bye
    MrC
    AVStoDVD Homepage
  10. Here you are!
  11. Originally Posted by _MrC_ View Post
    He can change merit and as such keep them both in system (it is useful sometimes).
  12. Hi Mark22
    the graph is perfect.
    Going back to your project log file, I have noticed that you have trimmed just 3 minutes of the whole title. Hence audio re-encoding is forced by AVStoDVD, neverthless the source audio is DVD-compliant or not. In your case the DTS audio track should be recognized as DVD-compliant by AVStoDVD.
    1. Have you tried to convert the complete source title? The DTS audio track should be kept and the audio issue would be avoided.
    2. If you definitively need to convert only 3 minutes, you can cut that portion of the souce title with Avidemux and then feed AVStoDVD with the new small mkv. Doing that, the DTS track will be retained as well.
    3. If yuo still get troubles, please upload the mkv somewhere (zippyshare, dropbox, mediafire, ...), to be tested.
    Bye
    MrC
    AVStoDVD Homepage
  13. 2. That's it. Thank you!
