okay, im new here. hope you dont mind. but i hope someone might read this and help me out, i have pretty much the same problem. its a long story. i downloaded some episodes ranging in 65-100 mb each together in a folder . and they work perfectly but i accidently deleted the folder containing them. and as soon i did . i used system restore to restore to yesterday. but the folder didnt appear and then i used the previous version of the folder and tried to get my files. it only saved 2 resotre points , when i deleted the files. and the second yesterday morning. i could restore to the morning one but none of them had the downloaded files. so i found a software recuva and got my files back from some shadow drive (C) . and all of them were said to be in perfect condition. but when i play it ,it says video and audio format undf . no way of fixing. for vlc player. so i have no idea what to do, and im not much of a expert here. but if you do explain i can still do something. the video format should be H264 MPEG-4 AVC (part 10) (avc1) and audio format is MPEG AAC audio (mp4a) . i hope you can get me a solution . thank you in advace. and sorry for being such a newbie .
this is what i get from one of the files of the video i downloaded
General
Complete name : C:\Users\Shinan\Desktop\New folder (2)\Xiaolin Showdown S2E22 The Apprentice.flv
Format : Flash Video
File size : 105 MiB
Duration : 21mn 6s
Overall bit rate : 696 Kbps
Tagging application : Yet Another Metadata Injector for FLV - Version 1.8
Video
Format : AVC
Format profile : High@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : 7
Duration : 21mn 42s
Bit rate : 546 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.074
Stream size : 84.7 MiB (81%)
Writing library : x264 core 107
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=26.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
Audio
Format : AAC
Format profile : LC
Codec ID : 10
Duration : 22mn 15s
Bit rate : 126 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Delay relative to video : 1ms
Stream size : 20.0 MiB (19%)
	System Restore doesn't "restore" deleted folders/files. And it's not uncommon for data recovery software to "restore" files that are not useable. This usually indicates that data is missing. Data recovery needs to occur immediately before the drive is used for anything. During normal operation, Windows creates and uses temp files (which get written to the HDD) plus whatever other actions were done trying to "restore" the files.
 undf = undefined
 In other words, the player doesn't recognize the file or it's contents.
 Try opening one of the files with mediainfo. If it bombs as well, the "files" are toast.Google is your Friend
	i did that. and i dont know what im supposed to do after. and most of them show the audio and video format. some dont. they just say video stream and audio stream. and i know its undefinied but i wanna know if there is a way to get it back to the oriiginal format. because the size of the file is same. so i thought maybe there is still a way to get it back. if there isnt its okay. but most of them do say h264 avc and aac audio format. and some videos only show for like a second and then it just blanks.
	Give this a try: https://www.videohelp.com/tools/recover-mp4-to-h264 Google is your Friend
	The chances for success are very slim. When you delete files the space they occupy on the drive is marked as "free" but the file data actually remains unchanged. When you then start to system restore and revert to old versions and so on you start to write data to the drive and this might cause the deleted data to be replaced with something that corrupts it. Now, you run a recovery program that finds the old files in the file system table and restores the data - but the restored data has already been corrupted - most likely to a state that is beyond repair.. If you had not attempted the system restore and so on you might have had a slim chance of recovering the files, but now it's too late.. You will probably have more success with attempting to find and download the files again.. Good luck, m8..  I'm the developer behind FFQueue. My posts might reflect this! ;-) I'm the developer behind FFQueue. My posts might reflect this! ;-)
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
