Hi,
My 3GP video was corrupted and I tried to repair it using a Video Repair Tool and luckily it got repaired. But I still have a problem, it has no audio/sound I already tried to play it on different video players such as MS Media Player, VLC, GOM, DivX and Media Player Classic (From K-Lite) but non of them played it with audio.
Is there a way to fix it?
I got some MediaInfo
Details:
General
Complete name : F:\FILE002.3GP
Format : MPEG-4
Format profile : 3GPP Media Release 4
Codec ID : 3gp4
File size : 628 MiB
Duration : 2h 52mn
Overall bit rate : 509 Kbps
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 2h 52mn
Source duration : 2h 52mn
Bit rate mode : Variable
Bit rate : 512 Kbps
Nominal bit rate : 256 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 5.085 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 1.311
Stream size : 627 MiB (100%)
Source stream size : 627 MiB (100%)
Writing library : MTK_ENCODER_V3
Language : English
Audio
Format : AMR
Format/Info : Adaptive Multi-Rate
Format profile : Narrow band
Codec ID : samr
Channel(s) : 1 channel
Sampling rate : 8 000 Hz
Bit depth : 13 bits
Language : English
