I was using the CamStudio to record a video, so when I finish, I pause and stop the record and when I'll go to save, an error occurred and the program close alone, don't letting me save my video...
The CamStudio don't save my video in "My CamStudio Videos" but it's in "My CamStudio Temp Files" but I'am not able to open this with any player.
I've tried with some players and nothing...
- GOM Player (Cannot play the media file)
- MPC-HC (Was not possible to render a file)
- Nero Show Time (Impossible to play this file. the file is corrupted or the program does not support the format you are trying to play)
- The KMPlayer (Nothing)
- Windows Media Player (Is not possible to run the file. perhaps the player does not support the file type or the codec used to compress the file.)
- VLC Media Player (The only player who opened and ran the video, but without video only the time count, the display goes dark with the VLC's icon.)
The video has almost 3 hours long and the size is almost 4.2 GB.
There's a way to play or repair this file?
	Do you get any info from mediainfo / mediainfoxp ?
 What video and audio codec did you use in camstudio?
	Doesn't appear to be useable, especially if codec tools and multiple media players can't open/view the contents. Not all tools create temp files in a useable form. Google is your Friend
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
