Page 7 of 9
FirstFirst ... 5 6 7 8 9 LastLast
Results 181 to 210 of 241
    May 2014
    Germany
    Can someone please help me and get DL links (if possible highest quality) from these links?
    Would be appreciated.
    https://www.rtl.nl/video/ee182fdf-7dcb-378d-87b9-1020efd8d07a/
    https://www.rtlboulevard.nl/video/tv-fragmenten/video/4400456/eindelijk-nieuwe-muziek-...n-ilse-delange
  2. Mp4 - 1280p x 720p @ 4289 kb/s 16:9 @ 25 - 90 fps (var) High@L4.1 Audio: AAC 128 kb/s @ 48 khz
    http://filecloud.io/j17w9zspy
    Mp4 - 1280p x 720p @ 3320 kb/s 16:9 @ 25 - 90 fps (var) High@L4.1 Audio: AAC 128 kb/s @ 48 khz
    http://filecloud.io/ti35raesb
    May 2014
    Germany
    Thx.
    May 2014
    Germany
    Anyone ??
    Oct 2018
    Deutschland
    Hi!
    I have this video here: https://www.meloman.ru/concert/bah-strasti-po-matfeyu-12-03-2016/
    Can someone tell me how to download this?
    I tried it like this
    livestreamer --http-header "Referer=https://player.meloman.facecast.net/?key=16-03-12-19-00-KZCH&lang=en" "hls://https://records.meloman.facecast.net/files/6sAGEw0jki4Gg_ICqGeqcA/0/KZCH/meloman/16-03-12-19-00-HD-KZCH.mp4" best -o video.ts
    Looks like I do not get the correct source here since it just provides live (worst, best) and nothing else.
    Thanks!
  6. Hi friends
    I have problems with recording TV streams from here https://ustreamyx.com/stream.php?id=italia-1
    I did all what U wrote, but only mistakes
    Pls help!
    May 2014
    Germany
    Can someone please provide me a DL link in the 720p quality from this link?
    https://www.facebook.com/ilsedelange/videos/327683894810536/
    Would be greatly appreciated.
  8. Use youtube-dl.
    youtube-dl https://www.facebook.com/ilsedelange/videos/327683894810536/
    youtube-dl guide: https://forum.videohelp.com/threads/382524-How-to-get-started-with-youtube-dl-from-the...command-prompt
    May 2014
    Germany
    I have tried that very often, but every time I get errors of "0" videos, and if it is able to find it, doesn not convert it. That's why I ask for assistance.
  10. youtube-dl -F https://www.facebook.com/ilsedelange/videos/327683894810536/
    [facebook] 327683894810536: Downloading webpage
    WARNING: unable to extract thumbnail URL; please report this issue on https://yt-dl.org/bug . Ma
    ke sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtub
    e-dl with the --verbose flag and include its complete output.
    [info] Available formats for 327683894810536:
    format code extension resolution note
    2256231884594547ad m4a audio only DASH audio 65k , m4a_dash container, mp4a.40.5
    (48000Hz)
    2394772063954463v mp4 426x240 DASH video 200k , mp4_dash container, avc1.4D40
    1E, video only
    2357632744524354vd mp4 640x360 DASH video 401k , mp4_dash container, avc1.4D40
    1E, video only
    271484653703200v mp4 854x480 DASH video 681k , mp4_dash container, avc1.4D40
    1E, video only
    336150880668571v mp4 1280x720 DASH video 1345k , mp4_dash container, avc1.4D40
    1F, video only
    dash_sd_src mp4 unknown
    dash_sd_src_no_ratelimit mp4 unknown (best)
    May 2014
    Germany
    When I enter the provided codes it says "ERROR cannot parse data", even after updating in the command prompt. Therefore I also am not able to even select the 720p option for download.
  12. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    Streamlink works fine too:
    code
    streamlink "https://www.facebook.com/buzzfeedtasty/videos/1841707432748564/?__mref=message_bubble" best -o fb_video.mp4
    result:
    [cli][info] Found matching plugin facebook for URL https://www.facebook.com/buzzfeedtasty/videos/1841707432748564/?__mref=message_bubble
    [cli][info] Available streams: sd (worst), hd (best)
    [cli][info] Opening stream: hd (http)
    [download][fb_video.mp4] Written 30.7 MB (17s @ 1.8 MB/s)
    [cli][info] Stream ended
    [cli][info] Closing currently open stream...
    Downloads 1080x1080 which seems better than youtube-dl can give.
    May 2014
    Germany
    code
    result:
    So what do I have to type exactly if I have this open in cmd??
  14. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    The first code i gave you. just copy paste this in CMD:
    May 2014
    Germany
    When I type that link into cmd after Streamlink then I get these errors ...
    http://oi66.tinypic.com/20tgsx3.jpg
  16. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    It says in your screen that you typed hstreamlink instead of streamlink
    (also try running CMD as admin)
    May 2014
    Germany
    Ok, but if I do that (right click on CMD and then select open as admin), I still get thesame message unfortunately.
  18. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    I don't wanna sound stupid,but you are opening the CMD in the bin folder where streamlink.exe is located,right?
    Do you have the portable or installation version of streamlink?
    May 2014
    Germany
    Well I believe I do, but every time I copy the exact address from explorer and paste it in cmd, to enter the code you provided it says "program is not recognized as an internal or external command, operable program or batch file". And I installed the 'installation' version for Windows.
  20. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    This means that the folder where CMD was executed doesn't have streamlink.exe in it.
    when you open cmd it should say:
    C:\Program Files (x86)\Streamlink\bin>
    And then you paste the command.
    May 2014
    Germany
    When I open cmd it says C:\ followed by the windows user name. And when I want to enter "C:\Program Files (x86)\Streamlink\bin>" is also not possible, because cmd has a '>' mark next to the C: that I can't remove.
  22. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    Navigate in explorer to C:\Program Files (x86)\Streamlink\bin and then right click while holding shift and select "open command promt here". If no such option then:
    So you have something like this in CMD?
    C:\Users\myname>
    To get to C:\ type "cd.." twice until you get to C:\
    C:\Users\myname>cd..
    C:\Users>cd..
    C:\>
    Then type:
    cd Program Files (x86)\Streamlink\bin
    Until it reaches: C:\Program Files (x86)\Streamlink\bin>
    Then paste the command i gave you.
  23. Member
    May 2014
    Germany
    C:\Users\myname>
    C:\Users>cd..
    C:\>
    Then type:
    Thanks, I just used the steps you given me, but when I do this I still get thesame type of error. See pic. What am I doing wrong?
    http://oi65.tinypic.com/33fco78.jpg
  24. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    ^ have you actually logged in the facebook on any of the browsers?
  25. Member
    May 2014
    Germany
    You mean being logged in to FB while having cmd open? Yes, I do. When I follow your steps I always get the errors I just presented or it says 'download hd - written' and after one second says 'stream ended, closing current operation'. I just don't get it why it won't download sufficiently.
    Or is it possible the stream code is incorrect? Since this is the video I need in 720p, https://www.facebook.com/ilsedelange/videos/327683894810536/.
  26. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    You can just use VideoDownloadHelper plugin for firefox/chrome then.
