Results 91 to 120 of 241
How about this one http://www.mtv.nl/nieuws/84984 (the interview)? The page source mp4 only says blankVideo":"/assets/loading-66cdc90809306ed81ca54769512dc674.mp4 which does not work, and livestreamer also doens't. Who can help me out?
Hi, thanks for sharing sysanin, but I need the Common Linnets interview
. How do you get that link?
Hi, thanks but isn't there a way for a direct mp4 link? Because livestreamer does not work on my pc, it says "Is not recognized as an internal or external command, operable program or batch file".
Hi ,
Instead of writing livestreamer , write the exact place , example "d:\livestreamer\livestreamer.exe" .
Cheers .JE SUIS CHARLIE !!! -
Can I please get the HD dl link for this video? Every time I get the message 'permission denied unable for writing errno 13'.
http://www.rtlxl.nl/#!/rtl-late-night-301978/16ddd299-f4ce-3757-b016-889d4636dce1Last edited by Mr. Del Rio; 1st Apr 2016 at 03:34.
Hi Del Rio ,
Cheers .Code:livestreamer "hls://http://manifest.us.rtl.nl/10/v166/aes/adaptive/components/videorecorder/30/301978/357919/16ddd299-f4ce-3757-b016-889d4636dce1.ssm/16ddd299-f4ce-3757-b016-889d4636dce1.ism/16ddd299-f4ce-3757-b016-889d4636dce1-audio=128000-video=2522000.m3u8" best -o rtl-late-night.ts
Hi everyone! This thread has been super useful. However I have not been able to solve my problem.
I am trying to download a video from http://meloman.ru/concert/mezhdunarodnyj-master-klassprofessora-yuisimonovabrzaklyuchi...lassa/#webcast.
The url for this video is http://records.meloman.facecast.net/files/KZCH/14-07-08-19-00-FHD-KZCH.mp4. Although I've found other variants (http://records.meloman.facecast.net/files/KZCH/14-07-08-19-00-HD-KZCH.mp4 and http://records.meloman.facecast.net/files/KZCH/14-07-08-19-00-SD-KZCH.mp4) lurking the source code.
As with previous examples in this thread, the command I've used is:
The output is:Code:livestreamer --http-header "Referer=http://meloman.facecast.net/v/facecast_player.swf" "hls://http://records.meloman.facecast.net/files/KZCH/14-07-08-17-00-FHD-KZCH.mp4" best -o video.mp4
And stays there leaking memory without ever writing to file. I have tried other examples of the same webpage and have worked, but I don't know what the problem is with this particular video.Code:[cli][info] Found matching plugin stream for URL hls://http://records.meloman.facecast.net/files/KZCH/14-07-08-17-00-FHD-KZCH.mp4" best -o video.mp4 [cli][info] Available streams: live (worst, best) [cli][info] Opening stream: live (hls)
I have tried other --http-header variants that I saw in the code ".../v/GrindPlayer.swf" as well as combinations for the different video urls I found (written above).
I have also tried running it as root but hasn't worked either. I'm puzzled and annoyed beyond relief and would greatly appreciate any help you could give.
I should also mention that the file is quite big (20Gb), I'm not sure if there are any limitations in that regard.
Thanks in advance! -
Hi again, can someone please get me a direct DL link for this video http://www.rtlnieuws.nl/boulevard/entertainment/video-bar-douwe-bob-te-klein-voor-common-linnets (the 20 minute video). If possible with a direct DL link please, because livestream does not work here. Would be appreciated!
Anonymous84347344GuestCode:
livestreamer "httpstream://records.meloman.facecast.net/files/KZCH/14-07-08-19-00-FHD-KZCH.mp4" best -o 14-07-08-19-00-FHD-KZCH.mp4 [cli][info] Found matching plugin stream for URL httpstream://records.meloman.facecast.net/files/KZCH/14-07-08-19-00-FHD-KZCH.mp4 [cli][info] Available streams: live (worst, best) [cli][info] Opening stream: live (http)
Can anyone please get me the video from https://twitter.com/dwdd, "DWDD Summerschool: The Common Linnets - Americana", the 20 sec long video.
And can someone please post the DL link for this video? http://dewerelddraaitdoor.vara.nl/media/362217
livestreamer "hlsvariant://l24m776049a0d80057961528000000.bb255238870c5e72.adaptive-e10c4a.npostreaming.nl/lmshieldv2/3/vara/rest/2016/VARA_101379346/VARA_101379346.ism/VARA_101379346.m3u8" best -o VARA.ts [cli][info] Found matching plugin stream for URL hlsvariant://l24m776049a0d80057961528000000.bb255238870c5e72.adaptive-e10c4a.npostreaming.nl/lmshieldv2/3/vara/rest/2016/VARA_101379346/VARA_101379346.ism/VARA_101379346.m3u8 [cli][info] Available streams: 135k (worst), 162p, 234p, 306p, 342p (best) [cli][info] Opening stream: 342p (hls) [download][VARA.ts] Written 1.1 MB (3s @ 331.4 KB/s)
Thanks, but what do I have to do now to download the video ?? I don't see a mp4 link.
Never mind I got it working
Hello! I need some help downloading the video (best quality) and can't figure our how to convert it to the right command for livestreamer
Thank you in advance!Last edited by ParfaiT; 26th Jul 2016 at 07:21.
Hi ParfaiT ,
Give us the link for your video .
( NB : normally 'best' , sometimes 'live' , or xxxk , or yyyp ) .
Hi Mr. Del Rio ,
My tries :
TRANSCODAGES !!! do a choice !!! The first one seems to be the best .Code:livestreamer "hlsvariant://http://l24m341da0395b00579a7c93000000.f1a842a0d9e2a057.adaptive-e10c4a.npostreaming.nl/lmshieldv2/3/vara/rest/2016/VARA_101379346/VARA_101379346.ism/VARA_101379346.m3u8" best -o VARA.ts --- [cli][info] Found matching plugin stream for URL hlsvariant://http://l24m341da0395b00579a7c93000000.f1a842a0d9e2a057.adaptive-e10c4a.npostreaming.nl/lmshieldv2/3/vara/rest/2016/VARA_101379346/VARA_101379346.ism/VARA_101379346.m3u8 [cli][info] Available streams: 135k (worst), 162p, 234p, 306p, 342p (best) [cli][info] Opening stream: 342p (hls) [download][VARA.ts] Written 267.2 MB (10m17s @ 477.8 KB/s) [cli][info] Stream ended --- !!! GOT 'VARA.ts'
orCode:ffmpeg -i "VARA.ts" -vcodec copy -bsf:a aac_adtstoasc -f mp4 "VARA_1.mp4" --- Output #0, mp4, to 'VARA_1.mp4': Metadata: encoder : Lavf56.30.100 Stream #0:0: Video: h264 ([33][0][0][0] / 0x0021), yuv420p, 608x342 [SAR 1:1 DAR 16:9], q=2-31, 25 fps, 25 tbr, 90k tbn, 90k tbc Stream #0:1(eng): Audio: aac (libvo_aacenc) ([64][0][0][0] / 0x0040), 48000 Hz, stereo, s16, 128 kb/s Metadata: encoder : Lavc56.35.101 libvo_aacenc Stream mapping: Stream #0:1 -> #0:0 (copy) Stream #0:0 -> #0:1 (aac (native) -> aac (libvo_aacenc)) Press [q] to stop, [?] for help frame=47414 fps=1072 q=-1.0 Lsize= 262232kB time=00:31:36.56 bitrate=1132.7kbits/s video:231386kB audio:29634kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.464309% --- !!! GOT 'VARA_1.mp4'
Cheers .Code:ffmpeg -i "VARA.ts" -vcodec libx264 -acodec libmp3lame -f mp4 "VARA_2.mp4" --- Output #0, mp4, to 'VARA_2.mp4': Metadata: encoder : Lavf56.30.100 Stream #0:0: Video: h264 (libx264) ([33][0][0][0] / 0x0021), yuv420p, 608x342 [SAR 1:1 DAR 16:9], q=-1--1, 25 fps, 1 2800 tbn, 25 tbc Metadata: encoder : Lavc56.35.101 libx264 Stream #0:1(eng): Audio: mp3 (libmp3lame) (i[0][0][0] / 0x0069), 48000 Hz, stereo, fltp Metadata: encoder : Lavc56.35.101 libmp3lame Stream mapping: Stream #0:1 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:0 -> #0:1 (aac (native) -> mp3 (libmp3lame)) Press [q] to stop, [?] for help frame=47415 fps= 62 q=-1.0 Lsize= 152906kB time=00:31:36.57 bitrate= 660.5kbits/s dup=1 drop=0 video:121944kB audio:29634kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.876132% --- !!! GOT 'VARA_2.mp4'JE SUIS CHARLIE !!! -
I really don't have any idea what all that is you just posted. There are no links that can be opened as to where I can see the video and DL it. So how do I do that?!
Use youtube-dl on the command line to dump the json if you want the direct url to the m4v:
The m4v can be also be obtained manually, but you'll have to get a token and then do three more steps to get the m4v. Much faster using youtube-dl.Code:youtube-dl "http://www.npo.nl/dwdd-summerschool/21-07-2016/VARA_101379346"
Hi everyone!
I wonder if there are more options to download this program aside from the .mp4 option.I downloaded this option with youtube-dl and downloadgemist but the file I get has audio delay. Maybe other options (best quality) works well.Code:http://www.rtlxl.nl/#!/de-sterkste-man-8661/d8beaf7c-578c-47aa-a397-8a6ff921db6a
Thanks -
Hi kurek ,
I can't help , as we need a registered account .
Can you guys get this one too?
http://www.mtv.com/video-clips/xa04vj/vma-2016-beyonce-lemonade-medley-live-performance-vma-2016-mtv -
I'm trying to wrap my head around how to do this but I cannot. Is anyone able to tell me where I can grab the link to the video on this page? It's embedded a bit differently then what people are explaining here
http://nbc24.com/news/local/haunted-nw-ohio-a-ghost-hunt-with-meteorologist-kimberly-newman
