  1. Hi.
    My MP4BOX GUI is out of date.
    I need mux and demux mp4 files, so I need software similar to My MP4BOX GUI but updated.
    Thanks.
    Aug 2004
    PA USA
    It's not important the problem be solved, only that the blame for the mistake is assigned correctly
    I haven't seen any newer/updated mp4box gui. Let me know if you find something.
  4. Since MP4Boxs command line calls haven't changed for quite some time I'm wondering how is "My MP4Box GUI" out of date?
    (not using it, since I use Hybrid for all my mp4 needs, but wondering)
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    mympb4boxgui is a bit buggy and it would be nice with some new features.
  6. My "My MP4Box GUI" just stopped working. I see it in the taskbar and systray, but nothing else..
  7. Megui has a built in mp4 muxer where you can add h264 or h265 , audio and subs and then mux..
    or else cmd or ffmpeg based gui like ffmpeg batch https://www.videohelp.com/software/FFmpeg-Batch
