Results 1 to 28 of 28
  1. Member LeoKac's Avatar
    May 2012
    Tbilisi
    Hello, please tell me, at the same video quality, which of these has better compression?
    H.264 (AVC) or x264 ???
    and please tell me, at the same video quality, which of these has better compression?
    H.265 (HEVC) or x265 ???
    Thanks...
  2. h.264 (aka AVC) is a specification. x264 is a particular h.264 encoder.
    h.265 (aka, HEVC) is a specification. x265 is a particular h.265 encoder.
    Which cake is better -- chocolate cake recipe or chocolate cake bought at the store down the street?
  3. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Neither, I like Cheese Cake best...
  4. Member LeoKac's Avatar
    May 2012
    Tbilisi
    so, which one is recipe? and which one is actual cake?
  5. h.264 is a recipe. x264 is a cake.
    Aug 2013
    Central Germany
    You can get the H.264 and H.265 specifications from the ITU-T (International Telecommunication Union - Telecommunication Standardization Sector; formerly known as CCITT).
    Such standards or recommendations describe the "kernels" of the algorithms and bitstream syntax. Video standards managed by the ITU-T usually start with an uppercase H and dot; there are also standards regarding audio formats (e.g. G.723 as early recommendation for ADPCM audio).
    There are several ITU-T video recommendations closely related to milestones of technology and related ISO/IEC specifications and MPEG technology generations:
    H.261: ISO/IEC 11172-2 ~ MPEG-1 Part 2 (early video telephony via ISDN at 64 kbps, VCD)
    H.262: ISO/IEC 13818-2 ~ MPEG-2 Part 2 (SVCD, DVD Video, DVB)
    H.263: ISO/IEC 14496-2 ~ MPEG-4 Part 2 = SP/ASP (DivX / Xvid / Flash Video 1 ~ Sorenson Spark)
    H.264: ISO/IEC 14496-10 ~ MPEG-4 Part 10 = AVC (AVCHD, Blu-ray, DVB-S2)
    H.265: ISO/IEC 23008-2 ~ MPEG-H Part 2 = HEVC
    The higher the number, the more complex these algorithms are, the more computing power is necessary to have an implementation run in sufficient time (in case of a hardware implementation, to possibly encode video in realtime inside a camera). And usually, more modern video compression algorithms will also be able to compress video more efficiently, to lose less subjective quality with the same target bitrate for the same video dimensions and framerate.
    Each of these standards has been implemented in several different kinds of software and even hardware. Just as one example, the encoder x264 is only one (although one of the most popular and elaborate) software implementation of H.264, among many others. HD cameras usually contain AVC hardware encoder chips (which are of course not the same as x264, but create H.264 compliant video streams as well).
  7. GIGO or WYPIWYG - H.264 is better than x264 and H.265 is better than x265 (as both x26x are subset of H.26x)
    Sep 2012
    Australia
    A codec is only as good as it's best implementation...
    And "best" is contingent on the actual goals of those who are judging.
  9. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    In other words....Beauty Is In The Eye Of The Beholder....so the original question is impossible to answer and dumb to ask.
  10. Originally Posted by pandy View Post
    Except that most people can't do anything with a specification.
    Most of people can't do anything with x264/x265 without GUI either...
    However my main point was WYPIWYG.
    Jan 2014
    Kazakhstan
    Hi!
    Still there > q265 (The Next Generation Internet Video (NGIV) Codec project )
    I recently very slow opening / access to the forum videohelp Does anyone experiencing slowdown?
  13. If it is so dumb and one is just a recipe and one a cake, why can I choose between H.264 and X.264 as outcome codec.
    Obviously I can choose if my video file will be H.264 and X.264.
    If thats dumb, then the programs and codecs are programmed in a dumb way and its no surprise if beginners get confused about it.
    Wont get better if you ****in "experts" insult everybody who cant deal with it.
    Thx for no help whatsoever.
  14. Banned
    Freedonia
    Yatsura - WTH, man? This isn't even your thread. It last had a post about 6 weeks ago and you only get your panties in a wad over it TODAY? And again, not YOUR thread.
    One guy, hech54, used the word "dumb" other than you. If that gets you to lose your crap, you might as well leave forever now. That was pretty mild coming from him. I'd hate for you to see it when he really lets it fly! And you're really lucky that this hasn't had a response yet from one of our members for whom H.264 vs X.264 is almost a religious issue. I doubt you'd have enjoyed his diatribes on that subject much. Chill out.
  15. Banned
    Oct 2014
    Northern California
    What is X.264?
    Aug 2013
    Central Germany
    Completely unimportant remark: A FourCC (four character code) is a flag to identify either which specific codec or which general format is related to a video stream embedded in a container like AVI or MOV which use FourCCs as identifiers. A FourCC is not "the codec", though (a codec is a piece of software, not just 4 bytes). There are even codecs where you can select which FourCC shall be embedded to make a specific player recognize the content better.
    So, well, there may be videos compliant to the H.264 standard, encoded with the x264 codec, and identified by FourCCs like "H264" or "X264" or even "AVC1". And as long as there are people which can't tell apart the diagrams, the product, and the brand name, there will be confusion about it.
  17. Banned
    Oct 2014
    Northern California
    Very nice but H264 is not a fourcc code however X264 is.
  18. As usual, newpball has no idea what he's talking about. h264 is a valid fourcc code. Many h.264 encoders use it. Registered by Intel: http://www.fourcc.org/h260-through-h269/
    Aug 2013
    Central Germany
    Well, I can't eliminate completely the chance that there may be any software (or user) using an "uncommon" FourCC; neither the possibility that an enraged forum user didn't understand his own expression of smattering, so how shall we?
  20. Banned
    Oct 2014
    Northern California
    Here is a list of fourcc codes:
    http://www.fourcc.org/codecs.php
    As you can see H264 is not on that list.
    So if someone codec uses 'H264' drop the author of that list a line!
  21. Originally Posted by newpball View Post
    H264 is on the list under "H260 through H269".
  22. Banned
    Oct 2014
    Northern California
    Ok you are right.
  23. Member
    Aug 2013
    Central Germany
    Maybe slightly more interesting question: Is this FourCC actually used (by an encoder) or recognized (by a decoder), in other words: "in the wild"? Or is it just a noncommittal recommendation?
  24. Banned
    Oct 2014
    Northern California
    Good point!
    I thought a fourcc referred to a codec not a standard.
    If it is mixed we have yet another zoo in the video world.
  25. Member
    Aug 2013
    Central Germany
    It really depends ... there are FourCCs for plain video formats too (which do not even need a "codec", but are rather directly used as DIBs or 2D/3D API textures, without elaborate conversions). And there are, on the other hand, video formats which are practically identical, just the codec prefers an unusual FourCC, and changing the FourCC is all it requires to allow decoding by any other similar codec (e.g. among SD DV codecs).
  26. Encoders don't need a fourcc -- they know what they're doing. The fourcc exists so other programs (OS, application, decoder) can recognize what encoding scheme was used. Even if a video contains uncomrpessed RGB24, RGB32, YUY2, YV12, etc. other programs need some way of knowing what's in the file.
    In my opinion encoders that implement an internationally agreed upon stanadard, like h.264, should not use their own fourcc code. If the encoder unintentionally outputs data that is not compliant with the standard the encoder should be fixed. If it intentionally outputs non compliant data it should use its own fourcc.
  27. Originally Posted by LeoKac View Post
    Thanks...
    [Attachment 30069 - Click to enlarge]
    H.264 and H.265 are standards, x264 and x265 are the actual software.
    x265 has better compression at the same video quality but it's still too early to guarantee this for all scenes and situations. On some samples it's better quality on some it's worse and on some you can't really tell. Wait a bit longer.
  28. Originally Posted by -Habanero- View Post
    Thanks...
    Thanks for the only sensible reply that a layman can understand!
