Hi Video Masters!
I have a funny looking video with ghosting or blurring. I don't think it's a PAL/NTSC issue, but I can't tell. What are some signs of a bad PAL/NTSC conversion? Are there any tell-tale signs I should be on the lookout for? Here is a link to the clip:
http://files.videohelp.com/u/183506/MAG%203.demuxed.m2v
I suspect interlacing. Is that right? Would one of the better de-interlacers in Virtualdub fix this?
Thank you for your help. It is always appreciated!![]()
It's field blended like many of your other examples . The treatment is the same with some bobber and srestore
You look for the blendsAre there any tell-tale signs I should be on the lookout for?
Use AssumeTFF().SeparateFields() and go field by field in vdub or avspmod -
Hi!
Is field blending a kind of interlacing or is it a different beast? How does a video get blended fields?
Thanks for the help! -
No, as fields aren't interlaced. It's when the fields are combined back into full frames that you get the interlacing.
It's usually (but not always) the result of a standards conversion - PAL<->NTSC. Blended fields are added to go from 23.976/24->25fps or 25->29.97fps. As pdr mentioned, you separate the fields or bob it and look for the blends/ghosts/double-images.How does a video get blended fields?
Your sample was from a PAL source but converted to NTSC. The 'base' framerate is still PAL 25fps.
