I have created a DVD file, in Video and Audio TS Folders that include numerous VOB files, How can I convert or arrange the files/folders into a single VOB file that will play in the correct order from my HDD disc connected to my TV.
My bad. I mis-read what the OP wants.
From other topics I recall that the OP has a fixation about VOBs being the come-all and end-all of everything.
So what you now do is 'rip' that dvd with dvddecrypter and alter the output setting to '1 vob' or whatever it says. If your player refuses to play it then do not say that you were not warned. -
I suppose I am fixated with VOBs, its all I have ever used really that I know plays fine on the HDD, What format would you chaps go for, i.e. in terms of extracting a DVD as a whole, so that it can play on my HDD connected to the USB port on my TV.
Like I said.
1. Try the rip to a single vob. If that does not play......
2. Create a single mpeg2 file using vob2mpg from the original dvd vobs
If you want an answer to your last question, we really need more info. IIRC you said these vobs are actually stored for playback on a usb stick. But your tv manual should give more guidance and what video it supports for playback. There could be a file size limit etc.
