Page 24 of 24
FirstFirst ... 14 22 23 24
Results 691 to 720 of 720
    Feb 2010
    Italy
    I found the command to compare the second file.
    Also with the space bar you can switch from one image to the other.
    It would be very helpful to include an indexing indicator when loading the file, so as not to incur the misinterpretation of crashes.
    Feb 2010
    Italy
    Good morning.
    When I import the file with ProRes HQ422 codec to do x265 encoding StaRip crashes with the following message.
    I don't understand what it refers to in order to solve this problem.
    Any ideas?
    Thank you
  3. v2.41.6 is released.
    https://github.com/staxrip/staxrip/releases/tag/v2.41.6
    Changelog: v2.41.6 (2024-07-03)
    • UI: Fix "--normalize" and "--gain" are used for qaac at the same time when Pipe is used (#1410)
    • Internal: Fix crash on demuxing command without loaded project
    • Internal: Fix rare crash when closing Processing window right before closing StaxRip (#1414)
    • Internal: Raise event "Before Job Adding" also when adding a batch job (#1407)
    • Internal: Improve valid Dolby Vision metadata recognition for extraction (#1409)
    • NVEncC: Add new "--vpp-fft3d" parameter
    • NVEncC: Add new value "ngx-vsr" for "--vpp-resize" parameter
    • x264: Add "--aq-bias-strength" parameter (#1412)
    • Update tools
    • MediaInfo v24.06
    • NVEncC v7.57
    • QSVEncC v7.67
    • vvencFFapp v1.12.0 r236-d57c73d
    Feb 2010
    Italy
    Release 2.42 Dendraspis released this (2024-09-05)
    https://github.com/staxrip/staxrip/releases/tag/v2.42.0
    Note
    Among many, many changes you can find listed below, it's time for a "little" game changer. After an incredible amount of hours of back and forth the number of audio tracks is optional now, with a default number of six. ���� Because of so many different factors the Main window does currently not change its size automatically when you change the number of audio tracks. Therefore the Main window is sizable now (within some limits) which offers some other benefits. In this context the whole audio file and stream insertion and recognition was also altered, which leads to a better, but maybe different, handling than you were used to.
    The optional number of audio tracks was very challenging to integrate into the existing environment, but I am very sure, that it works wonderful finally. Nevertheless I am also sure that I could not have tested all workflow cases and exceptions. So please pay attention and report any issue.
    The Auto Crop process has also been improved and extended a lot, so there are some new parameters to define what you want to consider to be cropped. The default values should be fine for almost all cases, but feel free to tweak them for your needs. ��
    For everything else check the Changelog below.
    Many thanks to everybody, who helped testing during the development stages as well as @Patman86 for his binaries. Special thanks to the few supporters for their support and kind words!
    Important
    It is highly recommended to start with new/fresh settings, especially because of the change in audio handling! You can avoid unwanted side effects by not using or copying your old settings over.
    Update 2.42.1 Dendraspis released this (2024-09-08)
    https://github.com/staxrip/staxrip/releases/tag/v2.42.1
    Changelog:
    UI: Fix Demuxing Subtitles for ffmpeg (#1466)
    UI: Fix not saving log files (#1467)
    UI: Fix no time display on Crop window (#1470)
    UI: Disable Window Dark Mode when system colors are used (#1470)
    UI: Fix Demux handling for subtitles (#1471)
    NVEncC: Fix incompatible output file type for AV1 encodes
    QSVEncC: Fix incompatible output file type for AV1 encodes
    VCEEncC: Fix incompatible output file type for AV1 encodes
    Aug 2013
    Central Germany
    Thanks a lot for your great efforts.
    Yesterday I used it just to try which CLI you use to handle x265's input. I missed the new audio part, so my first test ended without any audio stream. Then I noticed the area. I discovered easily how to use it, added another audio stream, restarted the job ... and it asked me whether I want it to re-encode or re-use the already present video stream. Smart job!
    Mar 2020
    Germany
    Sorry guys, I'm looking for a forum to discuss recent problems with V2.42.1.
    I use staxrip since the very early days and always found a way for me to manage problems which occur with a new version.
    But now I'm stuck...
    I convert 720p50 content to 480p25 that fails because staxrip counts the frames encoded and realizes a mismatch (of course...!).
    The second is a failure with deinterlacing. I use ffmpeg to impose the delogo filter and so I do all the work within an ffmpeg filter graph that fails completely.
    Can you tell me a forum, where I can discuss my problem(s)?
    Tanks in advance.
    Mar 2020
    Germany
    Thanks, lojelo5,
    I posted my request for help with doom9, but it seems there's nobody to answer.
    Maybe my question was to difficult?
    Or the forum is dead at the moment?
  8. v2.44.0 released by Dendraspis (2024-12-20)
    https://github.com/staxrip/staxrip/releases/tag/v2.44.0
    Important
    I highly recommend starting with new settings and templates as VapourSynth and many encoder related parameters have changed and might break your configurations that have to be renewed. Otherwise check your profiles and templates, fix them if necessary and don't forget to save them again. 😉
    Note
    Special thanks to all supporters, especially the few Patreon members, who have been instrumental in making this version available! ❤️
    This is the last release for 2024!
    Thank you for using StaxRip, for reporting issues, for requesting features as well as for supporting StaxRip and keeping it alive. ❤️
    Merry Christmas and a happy new year! See you in 2025.... 🎆✨
    And just in case any of your friends or family still needs a gift for you: 🎄🎅 😉
    Changelog:
    • Audio: Add "Center/Speech Optimized Stereo" option
    • Audio: Demux audio even if all tracks are set to "No Audio" (#1529)
    • Audio: Fix broken audio file addition of demuxed files under some circumstances
    • Audio: Fix Normalize (#1484)
    • Audio: Improve Normalize
    • Macro: Fix %encoder_codec% is not shown on Macro List
    • MP4Box: Add custom switches for video tracks (#1532)
    • MP4Box: Add "Better Seeking" general preset (#1535)
    • NVEncC: Add new value "libplacebo" for "--vpp-resize" parameter
    • NVEncC: Adjust default values for "--vpp-ngx-truehdr" parameter
    • NVEncC: Always show "--vbr-quality" parameter in VBR mode
    • NVEncC: Remove parameters "--level", "--profile" and "--tier" for AV1 codec (#1534)
    • Rav1e: Fix 2-pass execution (#1531)
    • Rav1e: Fix bitrate not being synced with main window
    • Rav1e: Reorganize options
    • SvtAv1EncApp: Set default value for "--chroma-qm-min" to 8
    • SvtAv1EncApp: Adjust default value for "--hierarchical-levels" (#1546)
    • SvtAv1EncApp: Add value "2" to "--fast-decode" parameter
    • SvtAv1EncApp: Add "--noise-norm-strength" parameter
    • SvtAv1EncApp: Add "--kf-tf-strength" parameter
    • SvtAv1EncApp: Rename "Logical Processors" to "Level Of Parallelism"
    • x265: Fix overwriting of set up VBV values when loading a source file (#1539)
    • x265: Adjust new default values for Medium Preset
    • x265: Fix default value for "--limit-tu" for VerySlow Preset
    • x265: Remove deprecated parameters (#1544)
    • Update tools
      • aomenc v3.11.0-145-gc1bcb109d4-x64-msvc1942
      • DoVi_Tool v2.1.3
      • FFmpeg v7.2-dev-N-118074-x64-gcc14.2.0
      • HDR10Plus_Tool v1.6.1
      • MediaInfo v24.12
      • MKVToolNix v88.0
      • MP4Box v2.5-DEV-rev964-ga3c626300-x64-msvc1942
      • NVEncC v7.77
      • Python v3.12.7
      • qaac v2.83
      • QSVEncC v7.75
      • rav1e v0.7.0 (p20241015)-x64-msvc1942
      • Subtitle Edit v4.0.8
      • SvtAv1EncApp v2.3.0-1+12-7ae833c2-.Mod-by-Patman.-x64-msvc1942 [SVT-AV1-PSY]
      • VapourSynth R70
      • VCEEncC v8.24
      • vvencFFapp v1.13.0 r295-0c2c21e
      • x264 v0.164.3198+7-bf259fa-.Mod-by-Patman.-x64-gcc14.2.0
      • x265 v4.1+54+9-0c07fe364-.Mod-by-Patman.-x64-avx2-msvc1942
      • Update AviSynth+ plugins
      • DePan v2.7.46
      • DePanEstimate v2.7.46
      • MVTools2 v2.7.46
      • Update Dual plugins
      • BestSource R8
      • Update VapourSynth plugins
      • AVISource R1
    Tip
    If you want to keep StaxRip alive, support its development, get early access to new releases or just say thanks, please consider visiting:
    Static Badge Static Badge Static Badge
  9. v2.44.1 released by Dendraspis (2025-01-01)
    https://github.com/staxrip/staxrip/releases/tag/v2.44.1
    Note
    Special thanks to all supporters, especially the few Patreon members, who have been instrumental in making this version available for you! ❤️
    🎆 Happy New Year 🥂 🍾
    You have the opportunity to be part of something special. Last year on New Year's Day I have released v2.31.0, so with this release we are starting a new tradition. All you have to do is to download the new release, extract and start it - copying the old Settings folder over is optional. Then you're part of that magical moment. 🥳
    TL;DR: Have fun 😅
    Tip
    Changelog:
    • General: Fix Haali Splitter package
    • General: Fix Package status check
    • General: Disable Dolby Vision metadata extraction for non-HEVC files (#1553)
    • General: Add "Convert bit depth to 10-bit" option
    • Adds a filter to change the bit depth to 10-bit if the source file has a different bit depth
    • Audio: Fix Normalize with Channel change for Opus (#1569)
    • Audio: Fix hidden errors while cutting audio with mkvmerge (#1525)
    • Audio: Override Track Name if specified in template (#1487)
    • UI: Change source and target length format to HH:mm:ss
    • UI: Fix crash and/or missing text when using Thumbnailer
    • UI: Fix missing Assistant warning for no audio
    • UI: Make Audio editing window taller
    • MP4Box: Fix default tag for audio tracks and subtitles (#1530)
    • NVEncC: Add "--vpp-libplacebo-deband" parameter
    • NVEncC: Add "--vpp-libplacebo-tonemapping" parameter
    • QSVEncC: Add new value "libplacebo" for "--vpp-resize" parameter
    • SvtAv1EncApp: Add "--ss" parameter (#1556)
    • SvtAv1EncApp: Fix "--lp" parameter (#1556)
    • SvtAv1EncApp: Fix "--pin" parameter (#1556)
    • SvtAv1EncApp: Add value "2" to "--enable-tf" parameter
    • SvtAv1EncApp: Add "--psy-rd" parameter
    • SvtAv1EncApp: Apply new default value of "1" to "--sharpness" parameter
    • Update tools
      • ffmpeg v7.1-dev-N-116758-x64-gcc14.2.0
      • MKVToolNix v89.0
      • Python v3.12.8
      • Subtitle Edit v4.0.10
      • SvtAv1EncApp v2.3.0-A-0+15-5ea471e2-.Mod-by-Patman.-x64-msvc1942 [SVT-AV1-PSY]
      • vvencFFapp v1.13.0 r298-81a3b6c
    Important
    If you're an SvtAv1EncApp user, please check your settings as the new version brought some new (default) values.
    You also have to pay attention to a current bug in SVT-AV1-PSY, which causes SvtAv1EncApp to crash on (s)lower presets in case the source (and target) file is 8-bit.
  10. I think I've googled sufficiently to say it doesn't exist, but doesn't hurt to ask: Is there any existing way I could convince existing StaxRip releases to add the "-no-check" parameter to any MP4Box command line it needs to generate when demuxing?
    I've encountered more than one MP4 container which ends up throwing error, specifically about "not enough bytes in box colr: 6 left, reading 7":
    StaxRip.ErrorAbortException: MP4Box 2.5-DEV-rev1021-g49a598895-x64-msvc1942
    [isom] not enough bytes in box colr: 6 left, reading 7 (file H:\repos\gpac\src\isomedia\iff.c, line 226) - try specifying -no-check (might crash)
    [iso file] Read Box "colr" (start 10855184763) failed (Invalid IsoMedia File) - skipping
    [iso file] Read Box "avc1" (start 10855184623) failed (Invalid IsoMedia File) - skipping
    [iso file] Read Box "stsd" (start 10855184607) failed (Invalid IsoMedia File) - skipping
    [iso file] Read Box "stbl" (start 10855184599) failed (Invalid IsoMedia File) - skipping
    [iso file] Read Box "minf" (start 10855184535) failed (Invalid IsoMedia File) - skipping
    [iso file] Read Box "mdia" (start 10855184450) failed (Invalid IsoMedia File) - skipping
    [iso file] Read Box "trak" (start 10855184314) failed (Invalid IsoMedia File) - skipping
    [iso file] Read Box "moov" (start 10855184198) failed (Invalid IsoMedia File) - skipping
    Which stops any further processing. In my particular instances, the MP4 files play fine as-is, and even the demux generates valid exports of all the track types when I manually figure out the needed MP4Box commands and then add "-no-check". I'm about to do it for a second time, so I just wanted to ask whether StaxRip might already have a way to add this without me manually doing the work to demux the MP4.
    If it's not already there, does this seem worthy of me making a bug in the tracker, or is there a better place for "enhancement requests." Clearly for any MP4 I'm in control of generating, I would instead want to solve why the generated MP4 isn't valid. But for users of StaxRip receiving an MP4 which they can't otherwise "fix", perhaps having the "use -no-check" option would save them some grief and let StaxRip help them potentially get past the issue.
    Oh, the idea didn't come to mind until writing this: Can I get StaxRip to reveal all the demux command lines it intends to generate for the current file? Because that's really "the issue"; because StaxRip processing aborts on the first demux command line that fails, I can't just "look at the StaxRip log" to see all the command lines needed and add -no-check to them to run them manually myself. Only the first failed command line is in the log. StaxRip is willing to show me the command lines for the encodings it intends to perform, but if it will preview me the demux command lines, I've missed it.
  11. You can add a custom demuxer in the settings, but could be difficult. Otherwise make a feature request.
  12. Does anyone know of any video filters and/or settings to use to correct videos that saturate the color towards red?
    Aug 2013
    Central Germany
    Knowing the reason for wrong chrominance is the most important first step to a solution...
    You mention a reddish tint, so my guess is that it might be a wrong colorimetry (Rec. 601 vs. 709); but seeing your material may be useful to estimate if that reason is probable at all.
    The Avisynth filter "ColorYUV" has a lot of functions to change colors, especially the U (Cb) and V (Cr) balance. But which and how much is hard to guess without knowning your video.
  14. Originally Posted by LigH.de View Post
    Especially in the darker scenes you can see the shift towards red, however the whole video has an unnatural color saturation.
    If you tell me where I find the Avisynth "ColorYUV" filter and those settings, I'll do some tests to see if it improves.
    Aug 2013
    Central Germany
    It is a core filter.
    AviSynth+ ReadTheDocs: ColorYUV
    But you can find more interesting details about RGB/YUV conversion and colorimetry (also the ColorMatrix plugin) here:
    AviSynth+ ReadTheDocs: Colorimetry
  16. I found this, is it the right one?
    Thanks for your patience and help... Image
    [Attachment 84997 - Click to enlarge]
  17. If I wanted I could try to increase the brightness... trying it in playback with KMPlayer it is definitely better and the red color fades,
    But also this, in Staxrip how do I set the output with a higher brightness level?
  18. Member
    Aug 2013
    Central Germany
    You may not win by relying on automatic methods, it may require manual parameters, editing the generated script in a text editor.
    Regarding "brightness": You may not even mean brightness, maybe rather gamma instead. I can't recommend you anything without having your material.
  19. Originally Posted by LigH.de View Post
    I solved it from here:
    [Attachment 85067 - Click to enlarge]
  20. Now instead a million dollar (virtual) question:
    I should convert several films that I have on DVD to .mkv, trying to improve their quality, perhaps upscaling to 1080p
    I have never found how to upload them to Staxrip, it seems to me that it does not digest .vob files
    Is there some procedure and particular settings to do this?
  21. AFAIK you must open or drag&drop the video files all together.
    VTS_*_1.vob, VTS_*_2.vob, ...
    PS: virtual means Bitcoin?
  22. Member
    Aug 2013
    Central Germany
    Decades of experience of converting DVD Video content ignored and forgotten... It all starts with reading the main movie PGC out of the VOB files sequence, using the information stored in the IFO files along with them. That's the job of a good DVD ripper. The video converter comes second.
    One of the best DVD rippers in this generation is makeMKV. It can read the main movie PGC to a whole linear MKV file, perfect as input for converters like StaxRip.
  23. Hello everyone, I have some problem when encoding DV/HDR content. Source file has Dolby Vision & HDR10+ and I want to keep that while encoding to lower bitrate using NVEnnC (hardware encoder). Extraction of both Dolby RPU and HDR10Plus metadata went without any issue but my final file appeared to be grey-ish and not displaying HDR10+ colors correctly. I played both, source and output, files on my phone which supports HDR10+ playback and source file has vivid colors while my encoded file looked grey and washed out.
    You can see the comparison here: https://slow.pics/c/jcylWa2c?canvas-mode=fit-width
    This is the mediainfo for both files:
    Source file
    General
    Unique ID : 18413228603565579808705897170982220522 (0xDDA4242F2B04E83391DD21950D932EA)
    Format : Matroska
    Format version : Version 4
    File size : 18.9 GiB
    Duration : 1 h 49 min
    Overall bit rate : 24.7 Mb/s
    Frame rate : 23.976 FPS
    Encoded date : 2025-06-18 23:14:06 UTC
    Writing application : mkvmerge v91.0 ('Signs') 64-bit
    Writing library : libebml v1.4.5 + libmatroska v1.7.1
    Video
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : Main 10@L5@High
    HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
    Codec ID : V_MPEGH/ISO/HEVC
    Bit rate : 23.9 Mb/s
    Width : 3 840 pixels
    Height : 1 606 pixels
    Display aspect ratio : 2.40:1
    Frame rate mode : Constant
    Color space : YUV
    Chroma subsampling : 4:2:0 (Type 2)
    Bit depth : 10 bits
    Bits/(Pixel*Frame) : 0.162
    Stream size : 18.4 GiB (97%)
    Language : English
    Default : Yes
    Forced : No
    Color range : Limited
    Color primaries : BT.2020
    Transfer characteristics : PQ
    Matrix coefficients : BT.2020 non-constant
    Mastering display color primaries : BT.2020
    Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
    Maximum Content Light Level : 956 cd/m2
    Maximum Frame-Average Light Level : 381 cd/m2
    Audio
    Format : E-AC-3 JOC
    Format/Info : Enhanced AC-3 with Joint Object Coding
    Commercial name : Dolby Digital Plus with Dolby Atmos
    Codec ID : A_EAC3
    Bit rate mode : Constant
    Bit rate : 768 kb/s
    Channel(s) : 6 channels
    Channel layout : L R C LFE Ls Rs
    Sampling rate : 48.0 kHz
    Frame rate : 31.250 FPS (1536 SPF)
    Compression mode : Lossy
    Stream size : 603 MiB (3%)
    Language : English
    Service kind : Complete Main
    Default : Yes
    Forced : No
    Complexity index : 16
    Number of dynamic objects : 15
    Bed channel count : 1 channel
    Bed channel configuration : LFE
    Encoded file
    General
    Unique ID : 6089208462259403397101721693313322347 (0x494BD27FE6ED020EDE1B7F1F2D84D6B)
    Format : Matroska
    File size : 6.60 GiB
    Overall bit rate : 8 608 kb/s
    Encoded date : 2025-07-03 20:29:09 UTC
    Writing application : mkvmerge v93.0 ('Goblu') 64-bit
    Video
    Format : HEVC
    Format profile : Main 10@L5@Main
    Bit rate : 7 838 kb/s
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Bit depth : 10 bits
    Bits/(Pixel*Frame) : 0.053
    Stream size : 6.01 GiB (91%)
    Default : Yes
    Forced : No
    Audio
    Format : E-AC-3 JOC
    Codec ID : A_EAC3
    Bit rate : 768 kb/s
    Stream size : 603 MiB (9%)
    Language : English
    Default : Yes
    Forced : No
    Here are my NVEnnC settings that were used for encoding
    --qvbr 20 --codec h265 --preset p7 --output-depth 10 --profile main10 --multipass 2pass-full --vbv-bufsize 16500 --max-bitrate 8250 --lookahead 32 --master-display "G(8500,39850)B(6550,2300)R(35400,14600)WP(15635,1 6450)L(10000000,1)" --dhdr10-info FOLDER_TEMP\HDR10PlusMetadata.json --dolby-vision-profile 8.1 --dolby-vision-rpu FOLDER_TEMP\HDRDVmetadata.rpu --colormatrix bt2020nc --colorprim bt2020 --transfer smpte2084 --atc-sei undef --max-cll "956,381" --chromaloc 2 --aud --repeat-headers
    *FOLDER_TEMP - this is the temp folder that StaxRip creates during indexing stage. I always double check these setting and they always correspond to the source file.
    I really don't know what issue is, what can I do (if anything) to fix it or what should I do in the future when encoding to prevent this from happening and correct colors to be displayed.
    If I am missing any important information please ask me and I'll provide it. Thank you all in advance!
  24. Member
    Jul 2024
    Scotland Great Britain
    Format profile : Main 10@L5@High vs Format profile : Main 10@L5@Main in the encoded file is one difference I can see straight off.
    Whether that is enough to cause the problem I don't know.
  25. hi everyone! from 2.46.3 staxrip gui didn't start at all. what might be a reason? win11 64
    thanx
  26. when using multithreading, a warning in green "nlmeans.avs did not load" but after a few seconds staxrip goes on to encode
    Staxrip seems to be working as the encoded h264 video, from a dvd home mpg comes out fine. I'm wondering if there is a timing issue with the warning vs when all the modules loading? When using multithreading, staxrip is sluggish regarding changing settings such the width and height in resize but it does respond. The multithreading is about 2.5x faster. I went by the guide "How to set up a simple multithreaded QTGMC template for AviSynth".
    Did the warning come up too soon? Is this normal behavior?
    The warning comes up after starting the job. The warning, in green text, shows for about 3 seconds and after the program then goes on to encode.
  27. ------------------------- System Environment -------------------------
    StaxRip : v2.50.4
    Settings : v2.50.4
    Windows : Windows 10.0.26200 25H2 Professional
    Language : English (United States)
    CPU : Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz
    RAM : 32GB
    GPU : Intel(R) UHD Graphics 630
    Resolution : 1920 x 1080
    DPI : 96
    Code Page : 1252
    ----------------------- Media Info Source File -----------------------
    C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg
    General
    Complete name : C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg
    Format : MPEG-PS
    File size : 4.35 GiB
    Duration : 1 h 32 min
    Overall bit rate : 6 712 kb/s
    Frame rate : 29.970 FPS
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings : BVOP
    Format, BVOP : Yes
    Format, Matrix : Default
    Format, GOP : Variable
    Bit rate mode : Variable
    Bit rate : 6 386 kb/s
    Maximum bit rate : 7 500 kb/s
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 29.970 (30000/1001) FPS
    Standard : NTSC
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.617
    Time code of first frame : 00:00:00;00
    Time code source : Group of pictures header
    Stream size : 4.14 GiB (95%)
    Audio
    ID : 189 (0xBD)-128 (0x80)
    Format : AC-3
    Format/Info : Audio Coding 3
    Muxing mode : DVD-Video
    Bit rate : 192 kb/s
    Channel(s) : 2 channels
    Stream size : 127 MiB (3%)
    Dialog Normalization : -31 dB
    dialnorm_Average : -31 dB
    dialnorm_Minimum : -31 dB
    dialnorm_Maximum : -31 dB
    Menu
    Format : DVD-Video
    -------------------- DGIndex: Demux & Index MPEG-2 --------------------
    DGIndex 3.0.0.0
    C:\Users\fluffy\Documents\PROGRAMS\StaxRip-v2.50.4-x64\Apps\Support\DgMpgDec\DGIndex.exe -i "C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg" -ia 2 -fo 0 -yr 1 -tn 1 -om 2 -drc 2 -dsd 0 -dsa 0 -o "C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5" -hide -exit
    Indexing source file...
    Indexing done.
    Start: 8:43:10 AM
    End: 8:43:38 AM
    Duration: 00:00:28
    ------------------------------ Auto Crop ------------------------------
    AutoCrop 2.5
    C:\Users\fluffy\Documents\PROGRAMS\StaxRip-v2.50.4-x64\Apps\Support\AutoCrop\AutoCrop.exe "C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5_new_source.avs" 3 15 8337 8337 1000 0
    0,0,0,0
    Start: 8:43:45 AM
    End: 8:43:49 AM
    Duration: 00:00:03
    ---------------------------- Configuration ----------------------------
    Template : 1280 720 borders 60 variable input nlmeans sharpen MT
    Video Encoder : x264Enc
    Video Encoder Profile : x264
    Container/Muxer Profile : MKV (mkvmerge)
    Audio Tracks...
    1. Copy/Mux (AC3) [und] : AC3 2ch 48kHz 192Kbps (Buzinsky5 T80 2_0ch 192Kbps DELAY 0ms.ac3)
    AviSynth/VapourSynth Mode : Portable/Portable
    Process Priority : BelowNormal
    Delete Temp Files : Permanent
    Delete Temp Files Selection : Include
    C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5.d2v
    General
    Complete name : C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5.d2v
    File size : 769 KiB
    --------------------------- AviSynth Script ---------------------------
    AddAutoloadDir("C:\Users\fluffy\Documents\PROGRAMS \StaxRip-v2.50.4-x64\Apps\FrameServer\AviSynth\plugins\")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\masktools2\masktools2.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\RgTools\RgTools.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\AddGrainC\AddGrainC.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\Bwdif\BWDIF.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\DFTTest\dfttest.dll")
    Import("C:\Users\fluffy\Documents\PROGRAMS\StaxRip-v2.50.4-x64\Apps\Plugins\AVS\Dither\dither.avsi")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\Dither\dither.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\EEDI2\EEDI2.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\EEDI3\eedi3.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\JPSDR\Plugins_JPSDR.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\mvtools2\mvtools2.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\NNEDI3CL\nnedi3cl.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\TDeint\TDeint.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\vinverse\vinverse.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\yadifmod2\yadifmod2.dll")
    Import("C:\Users\fluffy\Documents\PROGRAMS\StaxRip-v2.50.4-x64\Apps\Plugins\AVS\Zs_RF_Shared\Zs_RF_Shared.avs i")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\FFT3DFilter\fft3dfilter.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\Dual\FFT3D Neo\neo-fft3d.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\TMM2\TMM2.dll")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\AVS\D2VSource\D2VSource.dll")
    Import("C:\Users\fluffy\Documents\PROGRAMS\StaxRip-v2.50.4-x64\Apps\Plugins\AVS\FineSharp\FineSharp.avsi")
    LoadPlugin("C:\Users\fluffy\Documents\PROGRAMS\Sta xRip-v2.50.4-x64\Apps\Plugins\Dual\KNLMeansCL\KNLMeansCL.dll")
    Import("C:\Users\fluffy\Documents\PROGRAMS\StaxRip-v2.50.4-x64\Apps\Plugins\AVS\QTGMC\QTGMC.avsi")
    SetFilterMTMode("DEFAULT_MT_MODE", 2)
    D2VSource("C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5.d2v")
    Crop(2, 0, -6, -8)
    ChangeFPS(30000, 1001)
    QTGMC(preset="Medium",EdiThreads=4)
    KNLMeansCL(D=1, A=1, h=2, device_type="auto")
    FineSharp(mode=2, sstr=2.0, cstr=1.3, xstr=0.0, lstr=1.49, pstr=1.472)
    BicubicResize(960, 720)
    Tweak(hue=0, sat=0.82, bright=-2, cont=0.90, coring=false, realcalc=true)
    AddBorders(160, 0, 160, 0) #left, top, right, bottom
    Prefetch(12)
    ------------------------- Source Script Info -------------------------
    Width : 720
    Height : 480
    Frames : 166755
    Time : 01:32:44.059
    Framerate : 29.970029 (30000/1001)
    Format : YUV420P8
    ------------------------- Target Script Info -------------------------
    Width : 1280
    Height : 720
    Frames : 333510
    Time : 01:32:44.059
    Framerate : 59.940059 (60000/1001)
    Format : YUV420P8
    ---------------------- Media Info Audio Source 1 ----------------------
    General
    Complete name : C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5 T80 2_0ch 192Kbps DELAY 0ms.ac3
    Format : AC-3
    File size : 127 MiB
    Overall bit rate mode : Constant
    Overall bit rate : 192 kb/s
    Audio
    Format : AC-3
    Bit rate : 192 kb/s
    Stream size : 127 MiB (100%)
    --------------------------- Video encoding ---------------------------
    x264 0.165.3222+17-93998b2-[Mod-by-Patman]-x64-gcc15.2.0
    C:\Users\fluffy\Documents\PROGRAMS\StaxRip-v2.50.4-x64\Apps\Support\avs2pipemod\avs2pipemod64.exe -dll=C:\Users\fluffy\Documents\PROGRAMS\StaxRip-v2.50.4-x64\Apps\FrameServer\AviSynth\AviSynth.dll -y4mp "C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5_nlmeanssharpen.avs" | C:\Users\fluffy\Documents\PROGRAMS\StaxRip-v2.50.4-x64\Apps\Encoders\x264\x264.exe --crf 20 --level 4.1 --vbv-maxrate 20000 --vbv-bufsize 15000 --b-adapt 2 --b-pyramid strict --keyint 60 --min-keyint 1 --slices 4 --sar 1:1 --videoformat ntsc --colorprim bt709 --colormatrix bt709 --transfer bt709 --range tv --bluray-compat --nal-hrd=vbr --demuxer y4m --frames 333510 --output "C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5_nlmeanssharpen_out. h264" -
    avs2pipemod[info]: writing 333510 frames of 60000/1001 fps, 1280x720,
    sar 0:0, YUV-420-planar-8bit progressive video.
    y4m [INFO]: 1280x720 1:1 @ 60000/1001 fps (cfr)
    y4m [INFO]: color matrix: bt709
    x264 [INFO]: using SAR=1/1
    x264 [INFO]: AVC Encoder x264 core 165 r3222+17 93998b2 [Mod by Patman]
    x264 [INFO]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
    x264 [INFO]: profile: High, level: 4.1, subsampling: 4:2:0, bit-depth: 8-bit
    x264 [INFO]: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=18 lookahead_threads=3 sliced_threads=0 slices=4 nr=0 decimate=1 interlaced=0 bluray_compat=1 constrained_intra=0 bframes=3 b_pyramid=1 b_adapt=2 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=60 keyint_min=1 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=20.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=20000 vbv_bufsize=15000 crf_max=0.0 nal_hrd=vbr filler=0 ip_ratio=1.40 aq=1:1.00
    avs2pipemod[info]: total elapsed time is 5985.671 sec.
    x264 [INFO]: frame I:5587 Avg QP:16.73 size: 42023
    x264 [INFO]: frame P:89963 Avg QP:22.84 size: 16195
    x264 [INFO]: frame B:237960 Avg QP:26.09 size: 4061
    x264 [INFO]: consecutive B-frames: 3.1% 2.7% 8.2% 86.1%
    x264 [INFO]: mb I I16..4: 31.8% 58.6% 9.6%
    x264 [INFO]: mb P I16..4: 3.1% 7.1% 0.5% P16..4: 36.7% 15.6% 5.8% 0.0% 0.0% skip:31.2%
    x264 [INFO]: mb B I16..4: 0.1% 0.2% 0.0% B16..8: 29.8% 3.8% 0.5% direct: 3.0% skip:62.5% L0:40.6% L1:51.7% BI: 7.7%
    x264 [INFO]: 8x8 transform intra:63.6% inter:83.9%
    x264 [INFO]: coded y,uvDC,uvAC intra: 47.0% 66.0% 20.4% inter: 10.6% 20.9% 0.2%
    x264 [INFO]: i16 v,h,dc,p: 53% 16% 8% 22%
    x264 [INFO]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 21% 20% 5% 6% 7% 7% 6% 7%
    x264 [INFO]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 24% 10% 5% 8% 8% 9% 6% 5%
    x264 [INFO]: i8c dc,h,v,p: 56% 17% 18% 10%
    x264 [INFO]: Weighted P-Frames: Y:1.2% UV:0.6%
    x264 [INFO]: ref P L0: 82.2% 17.2% 0.6%
    x264 [INFO]: ref B L0: 98.2% 1.8%
    x264 [INFO]: ref B L1: 98.1% 1.9%
    x264 [INFO]: kb/s:3821.89
    encoded 333510 frames, 55.72 fps, 3821.89 kb/s, duration 1:39:45.45
    Start: 8:48:51 AM
    End: 10:28:43 AM
    Duration: 01:39:51
    General
    Complete name : C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5_nlmeanssharpen_out. h264
    Format : AVC
    File size : 2.48 GiB
    Frame rate : 59.940 FPS
    Writing library : x264 core 165 r3222+17 93998b2 [Mod by Patman]
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings : CABAC / 3 Ref Frames
    Format, CABAC : Yes
    Format, Reference frames : 3 frames
    Format, Slice count : 4 slices per frame
    Maximum bit rate : 20.0 Mb/s
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate : 59.940 (60000/1001) FPS
    Standard : NTSC
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Progressive
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    ---------------------------- Muxing to MKV ----------------------------
    mkvmerge 95
    C:\Users\fluffy\Documents\PROGRAMS\StaxRip-v2.50.4-x64\Apps\Support\MKVToolNix\mkvmerge.exe -o "C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5_nlmeanssharpen.mkv" "C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5_nlmeanssharpen_out. h264" --audio-tracks 0 --language 0:und --default-track-flag 0:0 --forced-display-flag 0:0 --commentary-flag 0:0 "C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5 T80 2_0ch 192Kbps DELAY 0ms.ac3" --engage append_and_split_flac --ui-language en
    mkvmerge v95.0 ('Goodbye Stranger') 64-bit
    'C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5_nlmeanssharpen_out. h264': Using the demultiplexer for the format 'AVC/H.264'.
    'C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5 T80 2_0ch 192Kbps DELAY 0ms.ac3': Using the demultiplexer for the format 'AC-3'.
    'C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5_nlmeanssharpen_out. h264' track 0: Using the output module for the format 'AVC/H.264 (unframed)'.
    'C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5 T80 2_0ch 192Kbps DELAY 0ms.ac3' track 0: Using the output module for the format 'AC-3'.
    The file 'C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5_nlmeanssharpen.mkv' has been opened for writing.
    'C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5.mpg_temp\Buzinsky5_nlmeanssharpen_out. h264' track 0: Extracted the aspect ratio information from the video bitstream and set the display dimensions to 1280/720.
    The cue entries (the index) are being written...
    Multiplexing took 10 seconds.
    Start: 10:28:43 AM
    End: 10:28:53 AM
    Duration: 00:00:09
    ----------------------- Media Info Target File -----------------------
    General
    Complete name : C:\Users\fluffy\Videos\Buzinsky Family Video 5 of 7\Buzinsky5_nlmeanssharpen.mkv
    Format : Matroska
    File size : 2.60 GiB
    Overall bit rate : 4 017 kb/s
    Encoded date : 2025-12-07 15:28:43 UTC
    Writing application : mkvmerge 95.0 ('Goodbye Stranger') 64-bit
    Video
    Format : AVC
    Format, CABAC : Yes
    Codec ID : V_MPEG4/ISO/AVC
    Bit rate : 3 822 kb/s
    Height : 720 pixels
    Standard : NTSC
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.069
    Stream size : 2.48 GiB (95%)
    Default : Yes
    Forced : No
    Audio
    Format : AC-3
    Codec ID : A_AC3
    Bit rate : 192 kb/s
    Stream size : 127 MiB (5%)
    Default : No
    Forced : No
    ---------------------------- Job Complete ----------------------------
    Start: 8:48:45 AM
    End: 10:28:53 AM
    Duration: 01:40:07
