Results 481 to 510 of 720
Guys, please up vote my request for direct VapourSynth support for x265:
https://github.com/msg7086/x265-Yuuki-Asuna/issues/11 -
Thanks, we're a small team working on staxrip and try to keep things going.
Dear stax76, I've posted all available plugin updates here for your convenience:
QSVEnc 4.12
VCEEncC 6.07
AVSMeter 3.0.7.0
D2VSource 1.2.0
D2VWitch v5
FFT3dFilter 2.8 -for AVS
KNLMeansCL 1.1.1e
masktools2 2.2.26
mvtools2 2.7.44-with-depans
neo-minideen r10
TDeint 1.8
TIVTC 1.0.25
TMM2 0.1.5
VSFilterMod 5.2.3
DFTTest r7 for VS
ffmpeg N-99558-g703c8f3349-g00772ef4f7-x64-gcc10.2.0 Patman
x264M 0.161.3018-4c9b076-gcc11 Patman
havsfunc r33
JPSDR 3.2.4
rav1e 0.4.0-alpha
Subtitle-Edit 3.5.18
aomenc 2.0.0-918
QTGMC.avsi 3.376 https://github.com/realfinder/AVS-St...0up/QTGMC.avsi
LSFmod.avsi 2.192 https://github.com/realfinder/AVS-St...up/LSFmod.avsi
Zs_RF_Shared.avsi 1.143 https://github.com/realfinder/AVS-St...RF_Shared.avsi
Thank you.Last edited by hevron; 14th Dec 2020 at 18:46.
StaxRip 2.1.5.1 Beta. The D2V Witch v5 folder is missing. The D2V Witch.conf file is in place.
2.1.5.2 Beta (2020-12-15)
- StaxRip authors in about page updated. (stax76)
- Fix progress bar not working for rav1e encoder. (stax76)
- Tool updates (stax76, hevron)
- Fix tool auto update crash in case of missing download URL. (stax76)
- AVSMeter 3.0.7.0
- D2VSource 1.2.0
- KNLMeansCL 1.1.1e
- masktools2 2.2.26
- mvtools2 2.7.44
- neo-minideen r10
- TDeint 1.8
- TIVTC 1.0.25
- VSFilterMod 5.2.3
- DFTTest r7
- L-Smash-Works 2020-07-28 HolyWu
- havsfunc r33
- x264 M-0.161.3018-db0d417-x64-gcc10.2.0
- ffmpeg N-99558-g00772ef4f7-x64-gcc10.2.0 Patman
- JPSDR 3.2.4
- rav1e 2020-12-08
- Subtitle-Edit 3.5.18
- aomenc 2.0.0-918-g75a47cc18-gcc10.2.0
2.1.5.1 Beta (2020-12-15)
- Job processing issue fix (stax76, 44vince44)
- Audio filename collision fix (stax76, Dendraspis, 44vince44)
- The apps dialog has a new auto update feature, works for many but not for all tools. (stax76)
- nvenc new options added (stax76)
- qsvenc new options added and reorganized (stax76)
- Removed '--analysis-reuse-level' from x265 options, because deprecated (Dendraspis)
- Fixed x265 wrong output params in 3-pass mode (Dendraspis, 44vince44)
- vceenc 6.07
- qsvenc 4.12
- ffms2 87bae19 2020-11-23 StvG
- L-Smash-Source 2020-12-11 StvG -
Thank you for this awesome app.
But I miss one function. I would like to enter fixed times when work is allowed. So for me that would only be at night. How can I do that? I've seen you can start and stop it, but I can't find anything in the settings that makes this time automatically each, it's mainly about saving electricity costs.
Would be great if someone could tell me how I can set this. -
It's possible but requires a certain amount of advanced knowledge.
https://www.top-password.com/blog/5-ways-to-open-task-scheduler-in-windows-10
https://staxrip.readthedocs.io/cli.html#cmdoption-startjobs -
Ok there I am definitely too less versed.
I know how to create BAT files and execute them as a task, but I don't know what the commands should be. Can someone help me?
It's really only about stopping x265 each time, if the sound is done that's ok, that never takes long and much power but the 4K files do, so I want to stop this each time at 06.00 clock and start again at 21.00 clock. -
Stopping x265 or putting the PC into standby mode?
There should be a CLI tool that can pause all threads in a given application, but it's more a hack than a real solution. -
Actually, it is enough to pause you. Actually I would like to select only the Suspend function at 06.00 o'clock and at 21.00 o'clock again on Resume. So that he just works only at night. How that finally goes I do not care, as long as it works reliably
You can try to pause x265.exe with the following tool:
https://docs.microsoft.com/en-us/sysinternals/downloads/pssuspend -
2.1.5.3Beta
Changelog
https://github.com/staxrip/staxrip/blob/master/Changelog.md
Download
https://staxrip.readthedocs.io/introduction.html#beta -
ok I have the tool
How must I now set the command line that this then also works as a task? -
I provide only support for issues directly related to staxrip, please create a new thread 'How to pause x265 using windows task manager and pssuspend?'.
What I don't like about StaxRip, to many options.
Any denoiser recommendations? I would like to kill most of the noise, to get better compression. MCTemporalDenoiser looked good at first glance, but maybe someone knows better or faster one.Last edited by Bob.Dig; 24th Dec 2020 at 03:48.
Great thanks to all the authors of the program.
I wish you health and success in the New Year. -
@hevron Thank you, I wish this also for you and everybody else following this thread.
Hello everyone and best wishes for this new year.
I did a fresh install of Windows and the newest beta of staxrip (2.1.5.5). I noticed that it doesn't want to have administrative privileges anymore.
I wanted to encode an audio track with AAC, but staxrip says that Apple Quicktime is not installed...
The download buttton brings me to the MS Store and I should download the itunes app. But even after doing this, the needed dll is still not found. -
Where did the QT setup install CoreAudioToolbox.dll?
And where is the DLL?
About
StaxRip is a video encoding GUI for Windows, it executes and controls console apps like x265, NVEnc, mkvmerge or ffmpeg and uses the scripting based frame servers AviSynth and VapourSynth for video processing.
Website
https://github.com/staxrip/staxripLast edited by stax76; 23rd Feb 2021 at 23:37.
Staxrip: DirectoryNotFoundException
By hisaishi in forum EditingReplies: 2Last Post: 1st Jul 2019, 14:25 -
StaxRip AudioTrim
By aradmey in forum EditingReplies: 7Last Post: 23rd Jun 2019, 12:24 -
StaxRip and A/V desync
By Krasnal82 in forum Blu-ray RippingReplies: 0Last Post: 21st May 2018, 13:00 -
StaxRip 1.7.0.0 with Vapoursynth ?
By locky in forum Video ConversionReplies: 6Last Post: 24th Jan 2018, 19:08 -
Where is 'sharpen' in new Staxrip?
By The.King in forum Video ConversionReplies: 0Last Post: 2nd Sep 2015, 07:44
