Page 13 of 24
FirstFirst ... 3 11 12 13 14 15 23 ... LastLast
Results 361 to 390 of 720
  1. Hello,
    I tried to create my .tbn file using your instruction : IT'S WORKING PERFECTLY!!!
    • "Tools/...Advanced/Event Command" : a window called "Event Command" appears
    • "Add" : another window called "EventCommand Editor" appears
    • Give a name to the "Command"
    • "/Command.../Execute/ExecuteCommandLine"
    • Enter the command line in the "Command Line" cell
    • "OK" and "OK"
    The command used is:
    "D:\Yvan\_SoftWare\Creation videos\StaxRip\StaxRip\Apps\Encoders\ffmpeg\ffmpeg" -ss 00:00:02.000 -i "%target_file%" -vcodec mjpeg -vframes 1 -an -f rawvideo "D:\Encodage Vegas\%source_name%.tbn"
    Your software is awesome! It's very powerfull. Good job.
    Thank you very much!!!
    Last edited by Famille_CB; 18th Apr 2021 at 02:12. Reason: Path to the command line instruction
  2. Member stax76's Avatar
    Nov 2009
    On thin ice
    You're welcome. In case you want to move the staxrip location using %app:ffmpeg% gets the executable path of ffmpeg.
  3. Hello,
    I put this:
    "%app:ffmpeg%" -ss 00:00:02.000 -i "%target_file%" -vcodec mjpeg -vframes 1 -an -f rawvideo "%target_dir%\%source_name%.tbn"
    This works also (without the "\" on the target directory between "%target_dir%" and "%source_name%"):
    "%app:ffmpeg%" -ss 00:00:02.000 -i "%target_file%" -vcodec mjpeg -vframes 1 -an -f rawvideo "%target_dir%%source_name%.tbn"
    It's working perfectly and it's more clean.
    Thank you again.
  4. Hello,
    it's me again.
    When I select a MKV as input file the output filename is the same but with the postfix '_new'.
    Input: .\Testfile.mkv
    Output: .\Testfile_new.mkv
    Short question: Is there anywhere an option/way to change this postfix to something else/individual?
    I couldn't find such a setting, but that doesn't mean it doesn't exist or isn't possible.
  5. Member stax76's Avatar
    Nov 2009
    On thin ice
    You can try:
    Main Menu > Options > Paths > Default Target Name: %source_name%-test
    Apr 2020
    espaņa
    hello very good companion program I have been using it for a long time and for me it is the best of all and each update surpasses all thanks
  7. Hello i am trying to streamline the audio encoding process in stax wherein i want the lossless audio to directly be encoded to aac.
    i want the workflow to like this ie megui
    In Staxrip it is Demux tracks>Convert to .wav> Decode using flac > encode using qaac
    i also don't understand what i am supposed to select here
    i selected pipe and i got this error
    System.NotImplementedException: The method or operation is not implemented.
    at StaxRip.AudioProfile.get_ConvertExt() in D:\Projekte\VB\staxrip\General\AudioProfile.vb:lin e 152
    at StaxRip.Audio.Convert(AudioProfile ap) in D:\Projekte\VB\staxrip\General\Audio.vb:line 65
    at StaxRip.Audio.Process(AudioProfile ap) in D:\Projekte\VB\staxrip\General\Audio.vb:line 18
    at StaxRip.GlobalClass._Closure$__._Lambda$__31-1() in D:\Projekte\VB\staxrip\General\GlobalClass.vb:line 108
    at System.Threading.Tasks.Parallel.<>c__DisplayClass4 _0.<Invoke>b__0()
    --- End of stack trace from previous location where exception was thrown ---
    at System.Runtime.ExceptionServices.ExceptionDispatch Info.Throw()
    at StaxRip.GlobalClass.ProcessJob(String jobPath) in D:\Projekte\VB\staxrip\General\GlobalClass.vb:line 132
    at StaxRip.GlobalClass.ProcessJobs() in D:\Projekte\VB\staxrip\General\GlobalClass.vb:line 38
    when i selected flac i got this error
    ---------------- Error Audio encoding 2 using qaac 2.68 ----------------
    Audio encoding 2 using qaac 2.68 failed with exit code: 2 (0x2)
    It's unclear what the exit code means, in case it's a Windows system error then it possibly means:
    The system cannot find the file specified
    ------------------- Audio encoding 2 using qaac 2.68 -------------------
    D:\StaxRip-x64-2.0.8.0-stable\Apps\Audio\qaac\qaac64.exe --tvbr 66 "D:\StaxRip-x64-2.0.8.0-stable\Temp Files\abc.m4a
    ERROR: CoreAudioToolbox.dll: The specified module could not be found.
    D:\StaxRip-x64-2.0.8.0-stable\Apps\Audio\qaac\qaac64.exe --tvbr 66 "D:\StaxRip-x64-2.0.8.0-stable\Temp Files\abc.m4a"
  8. Originally Posted by stax76 View Post
    You can try:
    Looks like I managed to miss it.
    Thank you, that is the setting I was looking for!
  9. Does staxrip support any deband filter? don't see them in the options
  10. For ACKR:
    Hello,
    I'm just an standard user. Can you tell us what version of Staxrip do you use? I've got the StaxRip 2.1.0.6 Beta and the menus are not the same.
    Perhaps you can try the job with the last version...
    Regards.
  11. hello mkv file from videoredo once in staxrip the audio tracks are at 0ko
    Complete name :1x02.mkv
    Format : Matroska
    Format version : Version 4
    File size : 1.56 GiB
    Duration : 51 min 51 s
    Overall bit rate : 4 318 kb/s
    Writing application : VideoReDo (Lavf57.71.100)
    Writing library : VideoReDo (Lavf57.71.100)
    ErrorDetectionType : Per level 1
    Video
    Format : AVC
    Format profile : High@L4
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 4 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 51 min 50 s
    Bit rate : 3 848 kb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 FPS
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : MBAFF
    Scan type, store method : Interleaved fields
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.074
    Stream size : 1.39 GiB (89%)
    Default : No
    Forced : No
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Format : AC-3
    Format/Info : Audio Coding 3
    Commercial name : Dolby Digital
    Codec ID : A_AC3
    Bit rate mode : Constant
    Bit rate : 192 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 31.250 FPS (1536 SPF)
    Compression mode : Lossy
    Stream size : 71.2 MiB (4%)
    Language : French
    Service kind : Complete Main
    Default : Yes
    Forced : No
    Audio #2
    Format : AC-3
    Codec ID : A_AC3
    Bit rate : 192 kb/s
    Language : English
    Default : No
    Forced : No
    Text #1
    Format : DVB Subtitle
    Codec ID : S_DVBSUB
    Codec ID/Info : Picture based subtitle format used on DVBs
    Duration : 51 min 46 s
    Language : French
    Default : No
    Forced : No
    Text #2
    Codec ID : S_DVBSUB
    Language : French
    Default : No
    Forced : No
    Menu
    00:00:00.000 : :Chapter 1
    00:27:37.120 : :Chapter 2
  12. Hello i managed to figure it out. Is there a avisynth equivalent of vapoursynth for descaling
  13. Hello i have another question. Staxrip only encodes 2 audio tracks and doesn't encode any other ones. Anyway to ensure it encodes all tracks?
  14. @ACKR
    Under Options ŧ Audio you can select which audio tracks have to be demuxed.
    On the right side you can click on Container Options to alter them and add tracks/files.
  15. Hello i have a couple of more questions:-
    1)is there anyway to adjust memory cache for vapoursynth? i have error try increasing cache when only 50% memory is being used
    2) when adding plugins using profiles do i separate multiple line code using ; ? where the 1st line is import code for the plugin or script as it is not included in stax
    3) https://staxrip.readthedocs.io/gener...tml#finedehalo it says here that finedehalo2 is included but i couldn't find it anywhere?
    thanks
  16. 1) core.max_cache_size = 8000
    default for 64bit OS is 4096 (4GB)
    2)it should work, importing scripts(modules) example and dll:
    import vapoursynth as vs; import sys; core.std.LoadPlugin(r"C:\\my_vapoursynth_plugins64 \KNLMeansCL.dll")
  17. Originally Posted by _Al_ View Post
    is there anyway to add core.max_cache_size = 8000 to my vapoursynth profile so i don't have to modify each script?
    Edit: i am having another problem and this the worst of them all. whenever i try to use vapoursynth scripts the filters get copied into audio avisynth script as a result the encoder also crashes. why does this happen?.As a result whenever i choose no audio while using vapoursynth then only is the video encoded. any help is appreciated
    Edit:
    this is the error
    D:\StaxRip-x64-2.0.8.0-stable\Apps\Encoders\ffmpeg\ffmpeg.exe -i "G:\test_Audio02.JPN_DecodeFFAudioSource.avs" -y -hide_banner "G:\test_Audio02.JPN_convFFAudioSource.w64"
    clip = core.ffms2.Source(r"", cachefile=r"G:\.ffindex")
    #clip = core.std.AssumeFPS(clip, None, 25, 1)
    AudioDub(last,FFAudioSource("G:\test.dts", cachefile="G:\test_Audio02.JPN.ffindex"))
    clip = core.dfttest.DFTTest(clip, sigma=1)
    Audiochannels() >= 6 ? Down2(last) : last
    function Down2(clip a)
    a = ConvertAudioToFloat(a)
    fl = GetChannel(a, 1)
    fr = GetChannel(a, 2)
    c = GetChannel(a, 3)
    lfe = GetChannel(a, 4)
    sl = GetChannel(a, 5)
    sr = GetChannel(a, 6)
    l_sl = MixAudio(fl, sl, 0.2929, 0.2929)
    c_lfe = MixAudio(lfe, c, 0.2071, 0.2071)
    r_sr = MixAudio(fr, sr, 0.2929, 0.2929)
    l = MixAudio(l_sl, c_lfe, 1.0, 1.0)
    r = MixAudio(r_sr, c_lfe, 1.0, 1.0)
    return MergeChannels(l, r)
    [avisynth @ 000001d145ac3240] Script error: expected a , or )
    (G:\test_Audio02.JPN_DecodeFFAudioSource.avs, line 3, column 28)
    G:\test_Audio02.JPN_DecodeFFAudioSource.avs: Unknown error occurred
    edit: this is the avisynth file being generated
    LoadPlugin("D:\StaxRip-x64-2.0.8.0-stable\Apps\Plugins\AVS\DFTTest\dfttest.dll")
    LoadPlugin("D:\StaxRip-x64-2.0.8.0-stable\Apps\Plugins\Dual\ffms2\ffms2.dll")
    LoadPlugin("D:\StaxRip-x64-2.0.8.0-stable\Apps\Plugins\Dual\flash3kyuu_deband\flash3k yuu_deband.dll")
    AudioDub(last,FFAudioSource("G:\test.dts", cachefile="G:\test.ffindex"))
    clip = core.f3kdb.Deband(clip)
    the highlighted part shouldnt be there right
    whenever i try to encode video only its fine
  18. Member stax76's Avatar
    Nov 2009
    On thin ice
    2.1.1.1Beta
    2.1.1.1 Beta
    - mpv.net 5.4.6.0
    - MediaInfo.NET 6.3.0.0
    - x265 3.3+25-ga6489d2fb-gcc10.0.1 Patman
    - fix invalid --vpp-tweak nvenc command line generation (Patman86)
    - fix import of invalid color metadata into encoder VUI settings (Patman86)
    - fix taskbar indication of values below 1 (Dendraspis)
    - fix x265 preset (Dendraspis)
    - fix crash doing multi select drag operation in jobs dialog
    - fix showing the Apps dialog for a tool with non OK status in endless loop
    - the command line audio encoder uses cmd.exe directly without creating a bat file,
      this avoids creating a temporary bat file and adds full unicode support
    - portable support added and enabled by default, no need to install anything
    - nvenc --vpp-transform
    - setting to allow to use tools with wrong version,
      for this a Danger Zone tab was added in the settings
    Download
    https://staxrip.readthedocs.io/introduction.html#beta
    Apr 2020
    espaņa
    hello someone knows how to put the name like this in the coding library
    Librería de codificación : x264 core 159 r2991+50 ~ Encoded by Mocunaman in Portugal
  20. Member stax76's Avatar
    Nov 2009
    On thin ice
    Hi, you can set a MKV tag in the container options, there is a tab named Tags.
    Apr 2020
    espaņa
    if I already know about the labels but those labels can be deleted with mkvtoolmix and what I am trying to do is that they cannot be deleted if it is not re-encoded
    thanks for your reply
  22. Member
    Aug 2013
    Central Germany
    Exactly like the sample above: Only by hacking your own personal x264 encoder, altering the internal version string. Don't expect StaxRip to help you here, it has no features to change this part.
  23. Member
    Apr 2020
    espaņa
    ok thanks for your answer you mean altering the library to insert the encodec name?
  24. Member
    Aug 2013
    Central Germany
    Yes, you would probably have to alter the sources to change the algorithm which generates the version string and compile your own binaries to achieve that.
  25. Member stax76's Avatar
    Nov 2009
    On thin ice
    You would have to modify the x265 source code, build it and replace x265 in staxrip.
  26. Member
    Apr 2020
    espaņa
    that sounds complicated lol some suggestion of how to do it or program?
  27. Member stax76's Avatar
    Nov 2009
    On thin ice
    2.1.1.2 Beta
    - if AviSynth or VapourSynth was installed then StaxRip will use
      the installed version instead of the included portable version.
    - fix x265 --limit-modes issue.
    - fix batch encoding issue.
    - mpv.net 5.4.8.0
    - VapourSynth r50
    - x265 3.3+27-g4780a8d99-gcc11.0.0 Patman
    - nvenc 5.01
    - mkvtoolnix 46
    - RgTools 1.0
    - AVSMeter 2.9.9.1
    - new docs page Features giving a comprehensive feature list
    Download
  28. Member stax76's Avatar
    Nov 2009
    On thin ice
    2.1.1.3 Beta
    - fix avs and vpy import adding unnecessary LoadPlugin and Import calls
    - new setting: 'Main Menu > Tools > Settigs > System > Use included portable VapourSynth',
      to force usage of included portable VapourSynth instead of installed VapourSynth
    - new chunk encoding feature for x265 parallel processing
    - DGDecNV removal, there are better open source tools,
      L-Smash-Source supports hardware decoding for NVIDIA, Intel and AMD
    Docs on Chunk Encoding:
    https://staxrip.readthedocs.io/usage.html#parallel-processing
    Download
  29. Member
    Apr 2020
    espaņa
    2.1.1.3 Beta
    Download
    thanks for beta versions for when a stable version
    regards
  30. Member stax76's Avatar
    Nov 2009
    On thin ice
    I've not yet thought about it, no interest in beta versions?
    Have been working on some requests and the docs, it's maybe the first time I can say the docs don't suck, I hope it can help a few people that don't have interest in StaxRip so far.
    2.1.1.4 Beta
    - dark color theme for built-in help.
    - improved built-in help for various dialogs.
    - various docs pages improved.
    - ffmpeg video encoder codec FFV1.
    - x264 and x265 dialogs have a new Bitrate option, the default value is 0 which
      means the bitrate of the project/template in the main dialog is used,
      this behavior is documented in the F1 help of the x264 and x265 dialog.
    - for file batch jobs only the file name is shown in the jobs dialog and not the full path.
    - audio encoder supports extracting DTS core using ffmpeg, generated name is _Extract DTS Core_.
    - the audio Copy/Mux profile has a _Extract DTS Core_ feature.
    - the command line audio encoder has a Default and Forced option.
    Download
