This ffmpeg gain detection is used since a while so it's not a new feature, it is used whenever the audio encoder has no built in normalization, maybe try a different ffmpeg build, what target audio format and encoder was that? Maybe try an audio encoder that has built in normalization like eac3to. Maybe you can also upload a sample.
Results 271 to 300 of 720
https://www.dropbox.com/sh/4ctl2y928xkak4f/AAADEZj_hFpGQaNOdd3yqcAHa?dl=0Code:
### 2.0.4.5 Beta Thanks to Patman for providing the download links of the tools !!! - update: JPSDR 3.1.3 - update: nvenc 4.50 - update: AVSMeter 2.9.6 - update: DGHDRtoSDR 1.12 - update: mvtools2 2.7.41 - update: FFT3dFilter 2.6.7 - update: TIVTC 1.0.14 - update: RgTools 0.98 - update: havsfunc r32 - update: DFTTest r6 - update: TCanny r12 - update: BM3D r8 - update: L-Smash Works 2019-09-17 HolyWu - update: x265 3.2+3-fdd69a76688 Patman - update: ffmpeg 2019-09-27 Patman - new: x265 switch --selective-sao added - new: L-Smash Works parameters prefer_hw 3 HW auto added to menu - new: the way --vbr-quality works in nvenc was changed, if it's value is -1 the bitrate in the main dialog is used, if it's higher then -1 the bitrate is set to 0 - new: add support of video track title/name using MP4Box - new: simple QP mode added to nvenc to use one instead of three QP values - new: the menu renderer has now Win 10 style arrows for sub menu indication - new: icons added to filter list and script editor, shortcuts added to script editor - new: the preview can be closed by clicking in the top right corner - new: in the script editor there are now two players available, mpv.net and whatever is registered for mkv, mpc-be supports vpy playback - new: the way filters are added, replaced and inserted in the script editor was changed in order to improve the menu performance - new: in the main menu a sub menu was added: Apps > Script Info, it contains avsmeter, vspipe and avs2pipemod for showing info about the currently active AviSynth or VapourSynth script, vspipe and avs2pipemod show parameters like bit depth, colorspace and framecount. In the script editor there is a new 'Script Info' menu item (Ctrl+I) doing the same. - new: the mediainfo dialog shows the formats in the tab captions - new: the mediainfo dialog has a new feature to move to the next and previous file via menu and shortcut - fix: docs weren't built automatically - fix: some bugs were fixed in the nvenc command line import feature
https://1drv.ms/f/s!ArwKS_ZUR01gySQIE1QCL2i9F_uR -
Hello guys, I hope you can help me out.
I am looking for a new PC and would like to convert movies from TS to x265 with StaxRip.
My current graphics card is still sufficient for me, but it is not supported by StaxRip, i.e. the GPU.
As CPU I want a current Ryzen like the 3700x.
Would it make more sense to invest money in a new graphics card than in a faster CPU.
Is there an overview which graphics cards I can use with Staxrip / h265?
Or would it be better to use a Ryzen 9 3900x instead of a GPU?
Thank you Andi -
The Target Audio was mp3 and Encoder was libmp3lame I'm fairly sure.
Worked out that it was an isolated problem specifically with v4.2 of FFmpeg, as I cannot replicate\reproduce the Error on any other build of FFmpeg.
Hanging Issue seems to be resolved in v4.2.1 of FFmpeg, and IMO, v4.2.1 should definitely be implemented into the next Stable Build of StaxRip. Not only have I not encountered any Hangs or System I/O Errors but the Muxing Speed is noticeably faster when compared to v4.2 as well.
Thanks for the assistance, and also for your ongoing contributions to what's quickly becoming one of the best pieces of Open-Source Software on the Free Market Today. -
Hello, although I've been using StaxRip for quite some time, I have some questions regarding encoding a DVD but also questions in general about StaxRip that have been bugging me for quite some time, I hope you could help me!
1) Which filter should I use to deinterlace? Is yadifmod2 adequate?
2) Is QTGMC superior even in super fast or ultra fast presets? Does SelectEven(), to keep original framerate, reduce deinterlace quality?
3) Is there an alternative to QTGMC that offers better quality than yadif but is faster than QTGMC?
4) When denoising, is KNLMeansCL a high-quality denoiser?
5) When encoding audio in AAC should I keep normalize checked? What does it do? Also, which encoder is better for AAC, ffmpeg or eac3to? Why isn't it possible to specify bitrate in AAC but I have to use quality slider?
6) In the x264 or x265 options, besides tweaking the basic options(preset,mode,etc.), is it okay leaving the other options(rate control, analysis, slice decisions tabs) at their defaults? Are these options automatically set based on the video source?
Sorry for so many questions, I'd like to learn more about StaxRip, it's such a great tool, I find it more useful and significantly faster than Handbrake!
Last edited by expansefan; 11th Oct 2019 at 14:07. Reason: Removed unimportant questions
Haven't used staxrip in over a year. Decided to encode some videos. Started with the stable 2.4 x265
And had errors regardless of x265 or x264, went to the beta 10 version to see if the issue was fixed, and still get the error.
I noticed another user had this error on the last page as well.
Error Compressibility Check using x265 3.2+5-gfbe9fef31 Patman (2.0.4.10)
Compressibility Check using x265 3.2+5-gfbe9fef31 Patman failed with exit code: 1 (0x1)
The exit code might be a system error code: STATUS_WAIT_1
The exit code might be a system error code: Incorrect function.
------- Compressibility Check using x265 3.2+5-gfbe9fef31 Patman -------
C:\Users\Craig\Desktop\Stax\2.4.10\Apps\Support\av s2pipemod\avs2pipemod64.exe -y4mp "E:\Video\Planes, Trains and Automobiles\Planes, Trains and Automobiles_t00_temp\Planes, Trains and Automobiles_t00_new_CompCheck.avs" | C:\Users\Craig\Desktop\Stax\2.4.10\Apps\Encoders\x 265\x265.exe --crf 18 --output-depth 10 --frames 6664 --y4m --output "E:\Video\Planes, Trains and Automobiles\Planes, Trains and Automobiles_t00_temp\Planes, Trains and Automobiles_t00_new_CompCheck.hevc" -
& was unexpected at this time.
StaxRip.ErrorAbortException: Compressibility Check using x265 3.2+5-gfbe9fef31 Patman failed with exit code: 1 (0x1)
at StaxRip.Proc.Start() in D:\Projekte\VB\staxrip\General\Proc.vb:line 340
at StaxRip.x265Enc.Encode(String passName, String commandLine, ProcessPriorityClass priority) in D:\Projekte\VB\staxrip\Encoding\x265Enc.vb:line 65
at StaxRip.x265Enc.RunCompCheck() in D:\Projekte\VB\staxrip\Encoding\x265Enc.vb:line 105 -
x265 defines exit codes:
https://x265.readthedocs.io/en/default/cli.html#cmdoption-version
1 means:
1. unable to parse command line
your error output says:
I don't see an ampersand in your command line, it seems the forum software made modifications because there are paths that have a space that are not enclosed in quotes which is clearly wrong, please upload the full log file on pastebin.
Did you tweak your command interpreter cmd?
edit:
I tried to reproduce it using the same paths for the executable and the media file and it was working on my Win 10 system. What you can try is paste the command line into cmd to see if it runs there, if not try to enclose all paths with quotes.Last edited by stax76; 11th Oct 2019 at 09:48.
staxrip uses cmd for execution because piping is used in the command lines, both the 1 exit code and the "& was unexpected at this time." error message is coming from cmd and not from x265 I think. It's unclear what's wrong with the command line, it looks fine except for the spaces which probably comes from the forum software.
https://pastebin.com/embed_js/ukt4Humw
That is the old. Renamed the folders to have underscore instead of a space, and restarted the project and ran a compressibility check and received the same status wait 1 message.
C:\Users\Craig\Desktop\Stax\2.4.10\Apps\Support\av s2pipemod\avs2pipemod64.exe -y4mp E:\Video\Planes,_Trains_and_Automobiles\Planes,_Tr ains_and_Automobiles_t00_temp\Planes,_Trains_and_A utomobiles_t00_new_CompCheck.avs | C:\Users\Craig\Desktop\Stax\2.4.10\Apps\Encoders\x 265\x265.exe --crf 18 --output-depth 10 --frames 6664 --y4m --output E:\Video\Planes,_Trains_and_Automobiles\Planes,_Tr ains_and_Automobiles_t00_temp\Planes,_Trains_and_A utomobiles_t00_new_CompCheck.hevc -
at StaxRip.x265Enc.RunCompCheck() in D:\Projekte\VB\staxrip\Encoding\x265Enc.vb:line 105Last edited by craigl281; 12th Oct 2019 at 20:51.
I tried to replicate as good as I can:
https://pastebin.com/bNSCmDNP
It appears that it has something to do with your cmd because the error message "& was unexpected at this time" is likely coming from cmd. I think that there is something wrong with your system. -
Alright, I'll reinstall windows tomorrow and then let you know. Thank you for the quick replies and all of your help.
There was an article today that told deleting HKEY_CURRENT_USER\Console will reset all console settings.
2.0.5.3 Beta ------------ - update: mkvtoolnix 39 - update: mpv.net 5.4.3 - update: NVEnc 4.55 - fix: few UI issues - fix: avs MCTemporalDenoise/GradFun2DBmod - fix: VUI luminance issue
Details, details, details. There are so many different types of (and reasons for) "jerky playback", how you call it. The minimum support requirement are probably MediaInfo reports and log files, possibly even samples of the original source and the complained copy.
Please upload the full log file to www.pastebin.com
Hi! Stax76
I'm selecting output x264, ffmpeg mp4 with 2 passes, Preset: Medium (Default) I got output "Jerky Playback" video in result. I've downloaded Staxrip latest version and tried again with suggestions but the result same "Jerky Playback" x264 ffmpeg mp4 output video.
Appreciate any advise/suggestions for this problem.Last edited by deepfrayder; 15th Nov 2019 at 06:13.
You are right, there are discontinuities. For example, there is a clear scene cut in the original video at frame 866/867. In MPC-HC I saw a double scene cut here. And loading your encoded video in VirtualDub2 to inspect this position closer, I saw that frames 863 and 864 got repeated to frame 865 and 866, instead of the double scene cut I saw in the playback. There is definitely an oddity. And I suspect that LSMASHVideoSource, which relies on the MP4 internal keyframe index, may be the reason, relying on an index chunk with possible errors.
Unrelated to StaxRip, I would try to substitute LSMASHVideoSource with LwLibavVideoSource here in the generated AviSynth script, just to test how a fresh index works.
Alternatively, you could remultiplex the original video to MKV using MKVToolnix and process that one instead, this will use LwLibavVideoSource anyway.
__
PS: Another possible reason/solution - seeking errors when L-SMASH Works uses multi-threading in LSMASHVideoSource. Restricting it to Threads=1 might solve it as well.Last edited by LigH.de; 15th Nov 2019 at 06:07.
@deepfrayder
You can change the source filter by right-clicking on the source filter, it's possible to do this before and after you load a source but it's better to do it before.
Alternatively you can choose the manual workflow template from:
Main Menu > Project > Templates > Manual Workflow
This will popup several dialogs when you open a source and in one of these dialogs you will be asked what source filter should be used.
If you want to make this a permanent change to be used by the default automatic project template and automatic filter preset then go to:
Main Menu > Tools > Settings > Source Filters
FFVideoSource is another source filter you can try.
StaxRip supports ffmpeg both as encoder and muxer but typically neither is used but rather the x264/x265 encoder and ideally mkvmerge as muxer. -
I'm not sure if this is helpful or not, but if you open deepfrayders Staxrip encoded video (from above)
in Avidemux it gives the message about B frames and PTS "missing or monotonically increasing"
https://avidemux.org/smif/index.php?topic=18593.0 -
Hi! Stax76
Thanks for your support, I'd like to inform I'm using source filter "Automatic" as you said change the source filter. Would you like to advise what source filter I have to select before loading the source.
I uploaded the Full Log file of staxrip as said earlier if necessary on www.pastebin.com https://pastebin.com/bdRvuLEh -
Hi deepfrayder, the advice of LigH is one of the best you can get at VideoHelp.
@LigH
Since you already looked at it and HolyWu is currently active maybe you can report it to him. -
Hi! Stax76
First I'd like to inform I did the change of all available source filters before loading the source manually as you advised earlier unfortunately result is the same. Any advise
Hi! everyone,
Please accept my apology for late response regarding my "Jerky Playback" output encoded video in staxrip ffmpeg mp4. I am uploading the new source files as mentioned earlier and I don't have any idea regarding matching log. If anybody advise I'll upload that also.
Looking forward for resolved this issue. -
Problem exists in your source file at frame 466.
Try FFvideosource instead of LSMASHSource for the source filter
I tested it using a simple script in Virtualdub2; FFvideosource behaves better; seems like one duplicate frame Vs. back and forth motion -
Thanks for the response, I'd like to inform I have tried all the source filters manually as advised by Stax76 earlier and same recommended by you FFVideoSource. Unfortunately got the same "Jerky Playback" output video. FFVideoSource encoding video and log attached for your perusal.
Staxrip: DirectoryNotFoundException
By hisaishi in forum EditingReplies: 2Last Post: 1st Jul 2019, 14:25 -
StaxRip AudioTrim
By aradmey in forum EditingReplies: 7Last Post: 23rd Jun 2019, 12:24 -
StaxRip and A/V desync
By Krasnal82 in forum Blu-ray RippingReplies: 0Last Post: 21st May 2018, 13:00 -
StaxRip 1.7.0.0 with Vapoursynth ?
By locky in forum Video ConversionReplies: 6Last Post: 24th Jan 2018, 19:08 -
Where is 'sharpen' in new Staxrip?
By The.King in forum Video ConversionReplies: 0Last Post: 2nd Sep 2015, 07:44
