Does burning TAO perform better than DAO ?
I know you need DAO for overburning, but does anyone know if
Track at Once generally produces different results as Disk At Once, in terms of DVD Playback ? I'm having issues near the end of my SVCD's and I'm wondering if it's a media issue or the burning method (i've lowered speeds, and that helps, but still experience some issues). The media I am noticing problems with is a generic Black media type.
No. TAO is very inefficient. It probably doesn't even work for VCDs. On audio CDs, the reason there is a "two second gap" (sometimes longer) is because the laser actually turns off and back on for each track. Each "track" written using TAO has a heading which is more wasted space on the disc. DAO has one heading.
Darryl -
dphirschler is correct,TAO is for multi-session disks(cd-r/w)where you
want to add data at a later date.DAO is a closed-session disk for
mastering and playback on vcd,dvd,cd players. -
Thanks for the responses. It's odd, in another forum someone suggested that it shouldn't make a difference for the SVCD playback performance.
I have been trying to determine why I have playback issues near the end of my disks sometimes. Burn speed, media type, and now this setting I was wondering if it played into the issue... -
It shouldn't actually make a difference if you are making a S/VCD (as long as your burning proggy/burner knows what it is doing). However, as S/VCDs must be closed, there is no benefit in burning TAO (and some potential risks).
IMHO, DAO is better.
Regards.Michael Tam
w: Morsels of Evidence -
Hmmmm.... Ok, explain this...
I went to burn some BIN/CUE images (SVCD)... and every attempt on every media set on DISK AT ONCE using NERO 5.5.8.0 created nothing but unreadable coasters... on 2 different media types.
But TRACK AT ONCE produced perfect disks (better on silver media than black, because on the black I had some issues near the end of the movie when watching on my Apex AD-1100w).
It must be that DISK AT ONCE is a NO CAN DO when burning CUE images!!! -
CUE/BIN images are meant to be burnt as DAO.
There is probably something wrong with how Nero works with your burner.
I strongly suggest that you try CDRWin (Goldenhawk invented CUE/BIN format) or CDRDAO.
Regards.Michael Tam
Vegas 11, multicamera track only rendering to one video track
By CursedLemon in forum EditingReplies: 0Last Post: 29th Feb 2012, 03:11 -
need to equalize volume of a single track made by appending 3 track
By perfection in forum AudioReplies: 2Last Post: 23rd May 2011, 02:57 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 12:16 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 08:25
