Results 1 to 11 of 11
  1. Ok guys i got problem finding url streams on tv shows from this page: "http://www.giddyupnetwork.info/pages/live-shows-movies". I try using urlhelper, replaymedia catcher, wm record and etc etc but nothing seems to give some results. I don't want to record this streams i just need links so i can add to my list and play them on my media center because it seems its only page where episodes go automatically one to another. any ideas advice's or help will be appreciate. Thanks in fornt.
    Cheers!
  2. Originally Posted by patorce View Post
    Cheers!
    two way
    this site use two player, its own player or http://vaughnlive.tv player (Perhaps there are other player, I did not test everything)
    with site player you can use rtmpdump + rtmpdumphelper
    exemple community
    rtmpdump -r "rtmpe://198.27.75.99/folder/" -a "folder/" -f "LNX 11,2,202,418" -W "http://www.tgun.tv/embeds2/jwplayer.flash.swf" -p "http://www.tgun.tv/embeds2/index2.html?community01" -y "community01" -o "2015-01-30_05-07-33_community01.flv"
    for http://vaughnlive.tv player
    clic on the video and the video play on http://vaughnlive.tv site
    copy the url and use livestreamer (the latest development code)
    exemple simpsons
    livestreamer "http://vaughnlive.tv/111aaacharksimpson" best -o simpsons.flv
  3. so its possible to get the streaming link? like ex: #EXTINF:-1 tvg-logo=""group-title="24/7 Streams", Everybody Loves Raymond
    rtmp://192.99.38.122/ch01 playpath=elr02 swfUrl=http://www.tgun.tv/locked/player.swf live=1 pageUrl=http://www.tgun.tv/menus/players/dlock/playerindex4.php?elr02 timeout=15
    and load it in my playlist?
    i try rtmpdump but couldnt start it on xp sp3
  4. Originally Posted by patorce View Post
    what media center you use?
  5. Originally Posted by patorce View Post
    for this exemple try
    rtmpe://192.99.38.122/files/ playpath=elr02 swfUrl=http://www.tgun.tv/embeds2/jwplayer.flash.swf live=1 pageUrl=http://www.tgun.tv/embeds2/index.html?elr02 timeout=15
  6. u are the best. thank u mate. im still trying to make rtmdump start working on xp :/
  7. Originally Posted by patorce View Post
    what is your problem with rtmpdump? with xp it works fine normally
    did you try with rtmpdumphelper + rtmpdump
  8. i try even with google tutorial but nothing .
  9. Originally Posted by patorce View Post
    what is your problem exactly? did you extract rtmpdump in the same folder as rtmpdumphelper? did you use firefox?
  10. biezom ... dude u are genius.....everything workin like charm.
    Cheers!
