I'm trying to get my head around EDLs in mplayer.
What I want to archive is that I want to only decode/analyse roughly a total of 100 frames across 9 different places across my input.
My input is 23.976 fps (so each frame is displayed ~41ms) and has a duration of 2710 seconds.
So my thought was to split the source into 10 sections using an EDL (http://mplayerhq.hu/DOCS/HTML/en/edl.html):
so that the frames between the sections gets analysed.Code:0 406.538 0 407.002 678.027 0 678.492 949.517 0 949.981 1221.01 0 1221.47 1492.5 0 1492.96 1763.99 0 1764.45 2035.48 0 2035.94 2306.97 0 2307.43 2578.45 0 2578.92 2710.75 0
In my case that would be 465ms which is roughly 12 frames.
So if everything works the way I understood it, the output should consist of roughly 100 frames.
With that in mind I saved my list into a file named cropEDL.txt and called:
Problem is that this doesn't decode/analyse just roughly 100 frames, but more like all frames.Code:"G:\Hybrid\mplayer_64.exe" -noframedrop -speed 100 -quiet br://10 -bluray-device "Y:\SULXMY~E" -tsprobe 100000000 -nosound -vo null -ao null -nosub -fps 23.976 -vf cropdetect=24:2 -edl "h:\cropEDL.txt"
Is someone here who has some experience with MPlayer and EDL lists who can shed some light on where I go wrong?
Cu Selur
Each of those listed are SKIPPED, so the part you are wanting are the parts in between? I see only 9 clips in between, and since the first starts at zero and the last is longer than the total duration that you mentioned, it looks like there are only 9 clips.
I haven't used this feature in mplayer, so can't help you too much. Too bad they didn't use industry-standard nomenclature (timecode notation, using elements to keep), would make for easier translation from other EDL files.
I would agree w/ pdr re:_same name & "edl" extension, though it shouldn't make a difference. Also, does your video file not have an extension?
Scott -
There is only one clip, and yes, I only want to analyze 9 sections of that clip.Each of those listed are SKIPPED, so the part you are wanting are the parts in between? I see only 9 clips in between, and since the first starts at zero and the last is longer than the total duration that you mentioned, it looks like there are only 9 clips.
"-bluray-device" is fed with a folder not with a file. "br://10" tells mplayer which playlist should be selected.Also, does your video file not have an extension?
Renaming the edl to the 'foldername.edl' doesn't change a thing.I would agree w/ pdr re:_same name & "edl" extension, though it shouldn't make a difference.
output says that the edls are read:
but since the crop detection doesn't stop, there seems to be something off.Code:Playing br://10. Read 10 EDL actions. libbluray/bdnav/mpls_parse.c:158: failed signature match, expected (MPLS0200) got (PK♥♦¶) libbluray/bdnav/mpls_parse.c:917: Failed to open Y:\SULXMY~E\BDMV\BACKUP\PLAYLIST\Archiv.zip libavformat version 56.19.100 (internal) TS file format detected. VIDEO H264(pid=4113) NO AUDIO! (try increasing -tsprobe) NO SUBS (yet)! PROGRAM N. 1 FPS seems to be: 23.976025 Opening video filter: [cropdetect=24:2] ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family libavcodec version 56.21.100 (internal) Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264) ========================================================================== Audio: no sound FPS forced to be 23.976 (ftime: 0.042). Starting playback... Movie-Aspect is 1.78:1 - prescaling to correct movie aspect. VO: [null] 1920x1080 => 1920x1080 Planar YV12 [h264 @ 0000000002367640]Cannot use next picture in error concealment [h264 @ 0000000002367640]concealing 7218 DC, 7218 AC, 7218 MV errors in P frame [h264 @ 0000000002367640]left block unavailable for requested intra4x4 mode -1 at 0 25 [h264 @ 0000000002367640]error while decoding MB 0 25, bytestream 7767 [h264 @ 0000000002367640]concealing 1129 DC, 1129 AC, 1129 MV errors in I frame [CROP] Crop area: X: 241..1678 Y: 0..491 (-vf crop=1436:492:242:0). [CROP] Crop area: X: 241..1678 Y: 0..493 (-vf crop=1436:494:242:0). [CROP] Crop area: X: 241..1678 Y: 0..495 (-vf crop=1436:496:242:0). [CROP] Crop area: X: 241..1678 Y: 0..501 (-vf crop=1436:502:242:0). [CROP] Crop area: X: 241..1678 Y: 0..506 (-vf crop=1436:506:242:0). [CROP] Crop area: X: 241..1678 Y: 0..506 (-vf crop=1436:506:242:0). ....
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Debug it step by step like you would for anything. Start by removing -vf cropdetect, test, then remove something else, test... etc...
I'm guessing it's because you're reading from a mpls and a problem with libbluray. So I would actually start with a test video
and work from there
libbluray/bdnav/mpls_parse.c:158: failed signature match, expected (MPLS0200) got (PK♥♦¶) -
Okay, so no-one sees a direct problem.
Using a clip with a play length of 6180 seconds, adjusting the last edl entry accordingly and shrinking the call to:
doesn't help and switching to a build from http://mplayerwin.sourceforge.net/downloads.html doesn't help either.Code:"G:\Hybrid\mplayer_64.exe" -edl "h:\wmpreperation.edl" "F:\soccer\wmpreperation.m4v"
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
