Hi all really hope someone can help me, apologies if this is an issue tackled before I have searched forums but cannot find this issue anywhere?! weird as I hope this is a common problem,
I have just downloaded avidemux and seems straight forward enough, BUT I am trying to cut a large video file in half, however when I save the video file it does not save as a video but as a normal file,
I can select my media player when opening on my pc and this will play but I am putting this file onto a usb to play on my TV but the file does not show and I cannot play it,
please can someone tell me there is a simple fix for this and when I save the files I can make sure they save as video files?
Any help massively appreciated...
Cheers![]()
What is the format of the original file, and what is your intended output?
In AviDemux you must select the type of file you want as output. Default is an avi file. Lets say that instead of an avi you want mp4 instead. Just under the Output Format is a dropbox where you can select the MP4 Muxer. In addition to selecting MP4 Muxer, you need to name the output file with the correct extension, in this case, .mp4. -
yep the same happened to me when i started with avidemux, the program doesnt add the extension.
Originally Posted by Avidemux official ForumLast edited by ricardouk; 27th Jan 2015 at 18:20.
I love it when a plan comes together! -
Plus if you are cutting a file in half, you'll be saving TWO times/files.....right?
Hi all
thanks so much for the replies,
@hech54 - Yes saving two files i actually managed to split the original file felt very pleased with myself but then couldnt get it to work on the tv....
@Kerry56 and @ricardouk - thanks for your comments, the file it currently mkv. and was copying the file output so assumed it would come back the same, i will try naming the file extention see if that makes a difference!
Thanks again all
