  1. Hey guys, I don't know if this belongs here or not and I am a newbie with Movie Studio Platinum 12.0
    I have a problem with the "Audio being out of sync after rendering" This is a very common issue that I've seen on the internet, but I can't seem to find a solution for it.
    I.'m using this program primarily for Youtube and basically I.'m uploading my videos in the format "Internet 1920x1080" ( It comes in such amazing quality)
    Here are the settings I use
    MP4 (AVC/AAC) file for progressive internet downloads.
    Audio: 192 Kbps, 48,000 Hz, 16 Bit, Stereo, AAC
    Video: 29.970 fps, 1920x1080 Progressive, YUV, 12 Mbps
    Pixel Aspect Ratio: 1.000
    In the actual program, everything including audio is in Sync, but after rendering it to my drive and even youtube, the video is out of sync.
    People's solutions have been to move the audio in the timeline section. But that's not going to work either. Are there any ways to fix this out of sync issue? Anything to do with the preferences or options?
    Let me know if I need to give more information, thanks!
    -RV
    Have you tried export it in any format? Stilll sync issues?
    Is your video sources 29.97fps?
  3. Honestly, since I am still new to it I don't really know how to check or change formats. I did however found something called MediaArea and its suppose to tell you the media info. This is what came out of it. Also to get better visuals though you can check on this video, I have on there. https://www.youtube.com/watch?v=R-suumgLXiM I had a lot of people say the audio is out of sync and at times I don't see it. But this is all the info and hope it helps.
    General
    Complete name : C:\Users\Reckless Villen\Documents\Movie Studio Platinum 12.0 Projects\They Breathe - EVIL IN THE DEEP!.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 1.94 GiB
    Duration : 23mn 14s
    Overall bit rate : 11.9 Mbps
    Encoded date : UTC 2015-01-26 13:15:34
    Tagged date : UTC 2015-01-26 13:15:34
    Video
    Format : AVC
    Format profile : Main@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=24
    Codec ID : avc1
    Duration : 23mn 14s
    Source duration : 23mn 14s
    Bit rate mode : Variable
    Bit rate : 11.7 Mbps
    Maximum bit rate : 24.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.189
    Stream size : 1.91 GiB (98%)
    Source stream size : 1.91 GiB (98%)
    Language : English
    Color range : Limited
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 23mn 14s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : channel0
    Channel(s)_Original : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 31.9 MiB (2%)
    Language : English
    The frame rate looks ok.
    Have you checked that the source has NO sync issues?
  5. As far as from what I can tell it looks fine. Here is info before I rendered it as well. I do see it as Frame rate mode :Constant and Frame rate:30.000 fps could the issue be that it is at 30.000 fps? And not 29.97 fps? Also is there a difference to 29.970 fps to 29.97? I think I can custom set it if I have to, I am using Xsplit Broadcaster to record btw.
    General
    Complete name : C:\Users\Reckless Villen\Videos\XSplit Recordings\LocalRecording - RecklessVillen\2015-01-26_020137366.mp4
    Format : MPEG-4
    Codec ID : isom
    File size : 297 MiB
    Duration : 22mn 22s
    Overall bit rate : 1 857 Kbps
    Writing application : Lavf54.63.100
    Video
    Format : AVC
    Format profile : High@L3.2
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Duration : 22mn 22s
    Bit rate : 1 651 Kbps
    Width : 1 280 pixels
    Height : 800 pixels
    Display aspect ratio : 16:10
    Frame rate : 30.000 fps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.054
    Stream size : 264 MiB (89%)
    Writing library : x264 core 139 r2363 2ccee72
    Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 22mn 22s
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Stream size : 31.2 MiB (11%)
