Ok so i had encoded a video using megui with xvid codec
here is the video file
Audio FileCode:General Format : AVI Format/Info : Audio Video Interleave File size : 164 MiB Duration : 23mn 9s Overall bit rate : 988 Kbps Video ID : 0 Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings, BVOP : 2 Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : XVID Codec ID/Hint : XviD Duration : 23mn 9s Bit rate : 983 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.044 Stream size : 163 MiB (100%) Writing library : XviD 1.2.1 (UTC 2008-12-04)
So i downloaded Avi Mux Gui to Mux These Two FilesCode:General Complete name : C:\Users\Administrator\Desktop\[HorribleSubs] Naruto Shippuuden - 396 [720p].mp3 Format : MPEG Audio File size : 21.2 MiB Duration : 23mn 9s Overall bit rate mode : Constant Overall bit rate : 128 Kbps Writing library : LAME3.99r Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Duration : 23mn 13s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 21.2 MiB (100%) Writing library : LAME3.99r Encoding settings : -m j -V 4 -q 2 -lowpass 17 -b 128
when i add both of them and press start its says to save the file but With Extension .mka Format and there is no option with .avi![]()
FFQueue.. Select video and audio as input files, tick the streams to remux, select a destination file with *.avi extension and a remux preset. You must create the remux preset with copy-codecs your self og copy the preset below and paste it into the preset manager.
//9gAAAAeNqLLihKLU4tieXlykyxzfHLNArOTnZydHQMSg50dP
Q2igQybW15ufISc1Ntg1JzSysUNJLzCyoVEnNyNHm5yjJTUvPj
k/NTUpNtQcK8XImlKZnIIgDdfiAPI'm the developer behind FFQueue. My posts might reflect this! ;-)
